Question about Mitsubishi WD-60737 60 in. HDTV
My Mitsubishi WD-60737 randomly detects devices in empty ports. I wll be watching TV and the screen will go blue and bring up the option to label the new device found. At first I had something plugged into a port and it said new device so I unplugged that device the problem just continued in the next port (input 3) which was never even used from day one. How can I fix this? Is there some kind of factory reset so I can start from square one again and just double check my lines when I hook them up
  • trecsean May 26, 2010
    Thanks, Ill try troubleshooting but if not ill go to some pros. Ill post back as soon as I have good or bad news.
  • Mitsubishi Master
  • 12,061 Answers
Http://www.eserviceinfo.com/equipment_mfg/MITSUBISHI_2.html
http://www.scribd.com/doc/17849622/V23-Training-Manual
I have seen similar problems before in my shop. It can be a couple of things, I have had, the IRed remote control receiver, glitch, and step through inputs.It can be the Input multiplexer, It can be the "Jungle" chip, itself.
You indeed may be able to reset your set, but this will NOT Fix it, sorry. You are going to have to troubleshoot, and isolate the exact problem, The manuals above will show you how to troubleshoot and hopefully repair your unit.
So, if you get stuck, or just don't really wish to do it all. in that case, it is nearly always my professional opinion that one should always get a "Quote" from the manufacturers recommended service center, Mitsubishi, in your case, please contact a local or head office and ask for a referral to an Authorised service center. I cannot stress how important that last point is. It is even worth the cost of shipping. You see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace. Often my clients,do not go through with repair, unless it is moderate, but in some of the more costly jobs they see it, as do i, that a replacement, with a warranty, is a better option. As an aside here, one could then tear the TV down, and sell the Known Good bits. You'd be surprised who needs parts, i myself often must by from third party sources to effect a repair. So money could be recouped, somewhat,and help out someone else.
Posted on May 26, 2010
Mitsubishi WD-60737 balast replacement
Hi, take a look at this video to see if this helps.
https://www.youtube.com/watch?v=Wuy75C_HRb4
Jul 11, 2016 | Mitsubishi WD-60737 TV
Mitsubishi wd-60737 fan problems
i have the same tv i replaced the lamp n now its a oange blinking light on
Feb 27, 2014 | Mitsubishi WD-60737 TV
Flashing light mean yellow
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 15, 2014 | Mitsubishi WD-60737 60 in. HDTV
Wd-60737 mitsubishi blinking yellow status light ?
Oct 25, 2012 | Mitsubishi WD-60737 TV
My mitsubishi Model # WD-60737. It is lesss than a year old. The status light flashs green, the Mitsubishi blue start up page comes up the the tv cuts back off. I have unplug from the wall for an hour....
Tv under a year old call Misubishi for a warrenty repair.Flashes staus light mean could be any these parts have problems power supply board,Ballast board or the pojection lamp itself.
Jan 11, 2011 | Mitsubishi WD-60737 60 in. HDTV
When i power my tv on it will not go past the blue welcome screen
i had the same problem and called mitsubishi they said it is a software malfunction and they are sending me an update to install via flash drive. i am now awaiting the email
Dec 09, 2010 | Mitsubishi WD-60737 60 in. HDTV
My mitsubishi Model # WD-60737. It is lesss than a year old. Maufactered Feb 2010. The status light flashs green, the Mitsubishi blue start up page comes up the the tv cuts back off. I have unplug from the...
i had the same problem and i called mitsubishi they said it is a software malfunction and they are sending me an update to install via flash drive. i am now awaiting the email
Nov 28, 2010 | Mitsubishi WD-60737 60 in. HDTV
White dots on my tv screen
this problem is coming from your DMD board it looks like some LCD chips are getting stuck in the on or off position you need to replace the light engine system to fix this problem check this link out
Please rate this solution as I do this for free!!!!
http://forums.cnet.com/5208-7596_102-0.html?threadID=257865&tag=forum-w;forums06
Sep 20, 2010 | Mitsubishi WD-73733 73" HDTV
Mitsubishi WD-60737 60 in. HDTV Logo
42 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
