Question about Dometic Rooftop RV Air Conditioner
Dometic rv ac freezes up - Dometic Rooftop RV Air Conditioner
  • 674 Answers
Check your air filters first. Then make sure the fans are running. If they are not let me know. If they are then get the refrigerant charge checked.
Posted on May 26, 2010
  • Brian Niten Jun 02, 2010
    Did this not help any or have you gotten your a/c fixed yet?
4 Suggested Answers
SOURCE: dometic ac in RV
IT NEEDS A RELAY BOARD IN SIDE
Posted on Jul 25, 2008
  • 2692 Answers
SOURCE: How do I clean out the vents in my RV Dometic roof
Take it off,the plastic inside vents, with soap water and a hose wash it.  Outside condendor and inside evapator, making sure the drain is open and outside shroad removed, brush off fthe loose stuff. wet both units, put liquid dishwashing soap on both. Spray then through , with a hose untill they rince clean.  While up there. Oil the motor if possible.  Keep the drain clear and open,making sure none of the water is getting into the RV.
Posted on May 10, 2009
motor1258
  • 6674 Answers
SOURCE: My Duo-therm Brisk-Air by Dometic rv ac wont cool.(The fan runs )
Usually just listening closely will give you a rough idea where to look for problem. When you have the fan on and switch to cool, (with temperature turned down low obviously) do you hear any type of "moaning" sounds from AC unit, or see lights in RV dim slightly indicating that compressor is trying to engage? Is the breaker tripping when compressor tries to engage? Do you hear a "click" from AC unit when switched to cool? If none of that happens, then I'd start thinking thermostat, or compressor relay. Normally if it's a faulty capacitor, the compressor will try to engage but will make a "moaning sound" and usually trip the breaker due to excess current draw. Someone experience in electrical should be able to test relays etc, but whoever does work on it, should be aware that those capacitors, as well as hydro in general are very dangerous to work with. The ("zap",- Shock) that you can experience from a capacitor or hydro, can be fatal.
Posted on May 30, 2010
Dometic AC cycles on and off
sounds like you don't have enough of a charge in the system of "free-on". that would make the a/c cycle and cycle to try and keep the pressure up and would also contribute to the lines frosting and freezing
Jul 04, 2012 | Dometic Rooftop RV Air Conditioner
I got a Dometic roof AC (2010) on my RV , the thermostat is givng me a E5 code, I changed 3 thermostats, opened the top and inside caps to check if there's any cut or burned wires and nothing that I...
E5 Open circuit or out of range Freeze Sensor. Air conditioner and dehumidification
operation will be locked out. Heat pump, furnace, heat strip and fan operation
can continue to operate but displays the last temperature set-point.
Sounds like your freeze sensor is defective and since it is still under warranty, you would void it if you replace it yourself.
Aug 26, 2011 | Dometic Rooftop RV Air Conditioner
I have a Dometic P/N Duo-Therm Model #59516-531 that started running more and more to cool my RV 5th wheel. I checked filter, drain, and noticed the unit was icing up. I turned off AC and let fan run to...
It is probably low on refrigerant. You can only check this if you have a set of gauges. Otherwise, take it to an air cond company and they will check it for you.
Jul 21, 2011 | Dometic Rooftop RV Air Conditioner
My coils inside of my Dometic roof top ac keep freezing up. How do I clean it? Thanks John
You can buy some coil cleaner at a heating and air supply. There are several brands. Some have to be rinsed off others don't. Use the kind that doesn't have to be rinsed on the evaporator coil.
Aug 18, 2010 | Dometic Rooftop RV Air Conditioner
Freezes up in less than an hour used 3 times and freezes each time model 59516 serial#93421578 installed 12-4-2009 dometic roof ac
You are either low on refrigerant, dirty coil or filter or your blower is not working or running at the proper speed. Make sure you have the blower on high speed, then, if it freezes up you are probably low on refrigerant. You need to have a HVAC service technician check it out, unless you are fimiliar with or work on air conditioning systems.
Jun 09, 2010 | Dometic Rooftop RV Air Conditioner
Rooftop RV Air Conditioner: my duotherm rv ac rooftop 15,000 btu the free...
If it's the pencil type, it just pokes into the fins (carefully)
If you look real close with flashlight you should be able to see where it poked in before, usually a couple of inches up from bottom. If it's the little round disc, it snaps in down in bottom corner, there should be a small hole for it in the frame.
May 17, 2010 | Dometic Rooftop RV Air Conditioner
Penguin 13500 ac short cycling
UNITS THEMOSTAT IS BAD REPLACE THERMOSTAT IF DONT SOLVE PROBLEM MAKE SURE UNIT IS NOT FREEZING UP AND BOUNCING OFF A "FREEZE STAT" CASING COMPRESSOR TO SHORT CYCLE
Jul 31, 2009 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
306 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
