Question about Proform Perspective Es Treadmill PFTL99806
Proform treadmill doesnt work
Console lights up but no controls work pulse and hart rate work no beeping noise when buttons pushed
    President:
  • Proform Master
  • 832 Answers
Press the Stop and the Speed Up keys down while inserting the safety key and try to get this unit in calibration mode if you cannot then, the upper console will have to be replace.
Posted on Jun 01, 2010
  • ramtazz
    ramtazz Jul 18, 2012
    I have a 550s... in reg mode it won't start when you press start or a speed increase with safety magnet attached... if I put it into calibration mode both the incline and speed do their calibration, but afterwards I still have no function . Do I have a dead console? Thx
Control panel lights up but not responsive on any function
The proform console sometimes freezes up and refuses to take the input from the user. Replace the console. The manufacturer do not sell parts for this console.
May 19, 2013 | Proform Pro Form 785ss 785 Ss Treadmill,...
I have an Ifit treadmill. I was changing speeds and it turned off and won't restart. It beeps when i turn it on but no lights on console.
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
Jun 02, 2012 | Proform Exercise & Fitness
The board lights up, but when you attempt to push a button (speed, program select) nothing happens. I do however have the stop and pace button beeping 3 times when you touch, but nothing works.
i think your console is shot check connections on the controller board. when pressing buttons, and some commands or none work, its the console
Feb 28, 2011 | Proform Exercise & Fitness
Proform 8.5 ifit treadmill will not start. Power is on all electronics appear to be working, but when key is placed on, the treadmill beeps quickly 4 or 5 times in a row and will not respond to any buttons...
Hello There, Unfortunately the sound are hearing is caused by a stuck button on your console assembly. When this happens you will be unable to select any buttons due to this condition.
The only fix is to replace the console assembly.
If you go to iconservice.com you can get parts and pricing information.
Get your model number before going there. Should be (PFTL788072) and is located under the walk belt on the lower frame assembly.
Good Luck! Tim
Dec 18, 2009 | Proform Exercise & Fitness
Proform 515s treadmill motor won't start
If the colse buttons make a chirping noise when you push them the console should be Ok. If there is no chirping noise with the push it is a bad console. If everything but the speed works it will probably be your motor controller that is bad.
Apr 14, 2009 | Proform CrossTrainer Treadmill
Console buttons don't work,only ifit button works
Has anybody found the solution for this? I'm having the same problem on my 850T treadmill. It's really annoying..
Feb 14, 2009 | Proform 540ls Treadmill Walking Belt
Open Questions:
See all Proform Perspective Es Treadmill PFTL99806 Questions
Proform Perspective Es Treadmill PFTL99806 Logo
989 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
