Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool washing machines f35 - Whirlpool Duet GHW9150P Front Load Washer
  • 15,935 Answers
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 27, 2010
huuum
  • 750 Answers
SOURCE: washing clothes all day have an F35 flashing
F35
ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer
component detected by the Steamer Electronic Board.
Possible Causes/Procedure
1. Check if pressure hose is fixed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
Check these problems.
Plesae leave a solved rating before you leave the site
Posted on Jan 30, 2009
  • 4090 Answers
SOURCE: The washing machine (Whirlpool Duet) quits with a
Change the pressure switch or blow the hose for restriction But enerally this is a faulty pressure switch
Posted on Aug 11, 2009
blueextc3221
  • 15935 Answers
SOURCE: HE5t washing machine flashes F35
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!
Posted on Sep 11, 2010
blueextc3221
  • 15935 Answers
SOURCE: F35 failure code
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*(*&^
Posted on Sep 26, 2010
KevinWhite
  • 1902 Answers
SOURCE: my whirlpool duet washing machine
Hello & Welcome to FixYa
F35 error means that there is some sort of issue with the steamer electronic board and analog pressure sensor has gone bad. Check that the hose is firmly attached with the washer and is not blocked. You can also check the water level pressure switch operation. Please get back to me if you have any other questions.
Kevin
Posted on Apr 16, 2011
I have an "F35" message
The only Whirlpool washer with an F35 code that I know of is the Duet. For that washer, the code indicates a failure of the analog pressure sensor. Check if the pressure hose is connected properly. Check that the hose is not blocked. Finally check for a blockage in the airtrap. If the hose and airtrap are fine, then the sensor or the related circuitry is bad.
I hope this helps.
Jul 24, 2011 | Whirlpool Washing Machines
My whirlpool washing machine keeps reading F35 what is that?
It is a computer problem and you can get it fixed free, due to a recall by Whirlpool. Call the company and complain. My daughter had the same problem.
Jul 16, 2011 | Whirlpool Washing Machines
My whirlpool duet washing machine displays code F35 and won't complete the washing cycle.
Kevin
Apr 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
CODE F35 COMES UP
No F35 there is an F33 and an F32 both of which are saying you have too much or too little water in the machine . Check to make sure your fill valves are not plugged.
Nov 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirlpool front load is making error of F35 and sometimes would say SUDs. I don't understand why it saying that. It won't do any washing at all.
The F35 error meams there is a problem with the Analog Pressure Sensor. This sensor is near the back right of the machine (viewed from the front) when the top is removed. It has a hose going to it and an electrical connection.
Replace the sensor
Thank You
Sep 06, 2010 | Whirlpool Washing Machines
Error code washing is delayed wil wash half the clothes
Mar 06, 2010 | Whirlpool GHW9300 Duet Washer
Washing clothes all day have an F35 flashing
F35
Jan 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Steam washer
HELLO.F35 IS A ERROR CODE WHICH NEEDS THE ASSISTANCE OF A WHILPOOL SERVICE AGENT.THE CONTROL BOARD MIGHT NEED TO BE REPROGRAMED BEFOR YOU CONSIDER REPLACING IT.GOODLUCK.MOHAMED
Sep 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
191 people viewed this question
Dan Webster
Dan Webster
Sal De
