Question about E-Machines eMachines Desktop PC
EMACHINES DESKTOP MY PC DOES NOT FUNCTION WHEN I INSERT A CD /DVD .. NOTHING HAPPENS
  • Anonymous May 11, 2010
    is it listed in the device manager under cd/dvd devices?
    1. Start
    2. right click on my computer
    3. left click on properties
    4. left click on hardware
    5. left click on device manager
    6. click on + sign by cd rom/dvd
    What model E-Machines do you have?
    service tag/serial number/part number/series
    Genius:
  • 1,027 Answers
Which operating system do you have?
Posted on Apr 09, 2008
SOURCE:
I need to reset password
The experience forgot admin windows password happened to me few days ago. And I searched in the Internet to find the solution. Then I found a windows password reset tool called Windows Password Reset Deluxe have a good evaluation.
I tried it as the steps:
Step1:Download and install Windows Password Reset
Step2:Burn Windows Password Reset ISO file to CD/DVD,or USB.
Step3:Put in my newly created CD and remove my Windows Password.
It really great help to me reset windows admin password.
Hope it help you too.
Jun 27, 2012 | E-Machines eMachines Desktop PC
Dvd doesn't work in PC
Check if autorun is active. In Windows 7, this is found by Start > Control Panel > Hardware and Sound > AutoPlay. (In previous versions, it is in a similar location under the Control Panel.) The next thing to try is cleaning the lens if you can. Open up the computer and check if the data cable is loose (either from the optical drive or the motherboard). If these don't work, replace the optical drive. (Internal optical drives are about ~$20-30 for DVD R/W.)
I hope this helps.
Jul 21, 2010 | E-Machines eMachines Desktop PC
EMachines Desktop PC: when inserting a cd drive,nothing happens...
First thing to do is check whether your optical drive is visible in Device Manager:
Right-click on "My Computer" and select "Manage".
Click Device Manager, then look for a DVD/CD-ROM drives section on the right and expand it (click the plus).
If you dont see your optical drive listed there, or you don't have a DVD/CD-ROM drives section in Device Manager then your PC is not detecting the presence of the drive. In this case if it is a desktop PC you need to make sure both power and data cables are securely connected. If it is a laptop, you may need to just reseat the drive (due to its connector no longer making good contact with your mainboard). This would be a case of unscrewing the relevant screw underneath, pulling the device right out (possibly cleaning the contacts, if dusty), then pushing it back in firmly before putting that screw back in.
If on the other hand you DO have an entry in Device Manager for your drive but it has a yellow exclamation symbol next to it then that means there is a driver issue. This is commonly caused by uninstalling some particular cd burning software. It can be fixed by a simple registry edit...
Run Regedit (Start Menu->Run. Type "regedit", press Enter.)
go to "HKEY_LOCAL_MACHINE_SYSTEM \CurrentControlSet \Control \Class \{4D36E965..."
Delete the "UpperFilters" and "LowerFilters" entries. (These will get regenerated...)
Then reboot your computer. Hopefully problem solved.
May 18, 2010 | E-Machines eMachines Desktop PC
Cd dvd door wont open.i push the button to put in cd and nothing happens.i do see a little cd on screen ,then it goes away.
On the front of most CD or DVD drives there is a small pin hole that you can use to open the drive if it gets stuck. Grab yourself a strong paper clip, straighten one end, insert the straight bit into the hole and push firmly once you feel some resistance.
This will partly open the drive tray to either allow you to remove a cd or insert a new cd or dvd.
Question, Is there a light lit on the front of the drive when you are:
a. trying to eject (instead of using the front button on the drive try using the "Right Click and then Eject" option when selecting the dvd drive in My Computer), If not the drive may be stuffed (broken) or perhaps the 4 pin power connection lead at the rear of the dvd drive has fallen out.
b. is the drive tray sticky when opening or closing? (get a new drive...very easy and very cheap to buy and replace)
Good luck,
Steve (Melbourne,Australia)
May 14, 2010 | E-Machines eMachines Desktop PC
Cd rom and cd/dvd drive won't work. I inserted MS Flight Sim x and nothing happens. I have also tried to run the d: drive, but nothing happens.
Check the the connection cables to the CD/DVD drive inside the computer (make sure they are seated). Enter the BIOS using the DEL or F1 key at startup and make sure the CD/DVD drive is detected. If not, try replacing ribbon or sata cable going to drive.
Jan 31, 2010 | Dell Dimension 3000 PC Desktop
MY EMACHINE DESKTOP RECOVERY CD DOENT WORK
Hello
When booting up pc have you held the delete key or f2 key down to bring up the boot menu?Should be a option of cd dvd or hdd to boot first.
You want the cd dvd boot option on top or first.tThen reboot pc.
When asked hit any key to boot from cd, hit a key.Should start install.
If youve done this, clean the dvd or cd install disc with some windex and a paper towell,try again.
You can also do a system restore from control panel recovery option.
Jan 23, 2010 | E-Machines eMachines Desktop PC
Emachine t6216 cd rom wont read
update your driver software for the cd/dvd drive that you have just go to the emachine support website lookup your computer and download the drivers for the drives if that doesnt work it might be a loose connection in the case open the case and make sure all the connections in the case are connected tight and right to the cd/dvd drive
May 28, 2009 | E-Machines eMachines Desktop PC
I insert restore disk and nothing happens
Hi there.
If you don't have the option of hitting F12 to change the boot order to the CD/DVD just as the computer starts up then you will have to enter the bios to change the boot order.
Restart the machine and hit either Del or Esc to enter the bios, look for the boot order and set the CD/DVD as first boot device, hit F10 and exit the bios, the computer will restart and you should now be able to boot from the CD/DVD.
Please post back with the results and if you need anymore help.
Good luck and thanks for using FixYa!!
May 24, 2009 | E-Machines (T2824) PC Desktop
I cannot copy pics or text to dvd
Assuming you have a DVD writer installed and functioning in your computer, check the format of your dvds. If you have a writer that uses dvd-rw it may not recognize dvd+r discs. Your label on the dvd package should have the disc format and your documentation for the writer should say what formats will work in the writer.
Dec 31, 2008 | E-Machines eMachines Desktop PC
Emachine w4682
go to control panel>system>device manager and see if the cd/dvd drive is shown there. If it is click on the + sign, right click the drive and go to properties, click on update driver and see if this helps.
Oct 23, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
21 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
