Question about Kenmore 56612 Side by Side Refrigerator
Model # 970-566321 water is leaking f/ fridge when door is closed what would cause this?
SOURCE: water gushed out freezer door, possible solenoid problem?
The drain is clogged. The drain is usually located inside the freezer on the bottom shelf to the rear. Use a meat baster and a solution of 1 tsp. baking soda and 2 cups of hot water-not boiling to unclog the drain. You probably also have about 1/2 inch of ice build-up on the bottom shelf. This will have to be removed first.
Posted on Feb 15, 2009
  • 363 Answers
SOURCE: 07kenmore elite bottom drawer gaps when fridge is closed
clean all of the freezer seals and all contact points.
Posted on Jul 22, 2009
  • 93 Answers
SOURCE: We have a Kenmore Coldspot
It is probably your defrost cycle causing this. Obviously if you shut the water line off then it is not coming from there so there is only 1 other place it could be. Every 8, 10, or 12 hours depending on you defrost timer the refrigerator will defrost itself.......the frost melts into water and drains into a pan under the fridge. If the drain is plugged then it will just run into the refrigerator. If you have a freezer on top model then just remove the back wall inside the freezer, it will be a few 1/4 inch screws....If you have an icemaker then remove that too, it will be held on with 3 screws. Just look behind that wall and you will probably see ice at the bottom.....defrost the ice and pour a cup or 2 of water into the drain to make sure it is unclogged. If it is still plugged up then you have to find the clog....either in the back of the fridge behind the lower cover or in the refrig compartment near the back of the roof.
Posted on Sep 12, 2009
  • 555 Answers
SOURCE: water in the fridge
It is usually caused by a clogged drain line. It needs to be replaced or cleaned.
Posted on Nov 06, 2009
  • 454 Answers
SOURCE: my stand up fridge (freezer up)has water pooling
The drain in the back of the freezer is clogged with ice. Turn off the refrigerator, remove everything from the freezer, remove the back and lower panels, and you will see what I am talking about. There will be a lot of ice everywhere. All of this ice should be removed. In the very back of the freezer, there is a drain. Make sure it is clear, then put everything back. This should solve the problem.
Posted on Jan 31, 2010
Leaking water on floor
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
Apr 08, 2015 | LG LRFD22850 Bottom Freezer Refrigerator...
LEAKING WATER UNDER CRISPERS, NOT COLD
Jul 18, 2014 | Kenmore Refrigerators
Kelvinator Cyclic 330, Model No: CS334A-R
Tonight, get a battery flash light, turn it on, put it in the fridge and close the fridge door. Then turn off all the lights in the room. If you can see any light escaping around the fridge door, the door seals aren't working properly, and need replacing.
This is the main reason why too much water is being condensed and causing your fridge drip tray to overflow.
May 25, 2014 | Refrigerators
Overflow reservoir
Defrost water trays are often made of flimsy plastic and likely to crack. Yours may have cracked. Another possibility is that the tray may have become mispositioned so that the water is not draining into it. The improperly closing door may have to be adjusted.
Nov 01, 2013 | AEG Dishwashers
When i close the door on the freezer side the water trickles down the front panel
This could be a leaking water valve. First thing I would suggest is to turn the water supply off under the sink or behind fridge wherever its located and see if the leaking stops.If so then you'll need to replace the water valve on fridge. If this doesn't work look up inside the ice chute on front of door and make sure the flapper is closing all the way when you get ice. Warm air coming up into freezer because the flapper is not sealing tight can cause water to run down front of fridge.If this is the case there is usually frost buildup on the ice chute on the inside of door.
Oct 25, 2013 | Refrigerators
Fridge leaking
check door gaskets are in good condition Open and close door quickly Wait for maybe 10seconds and try and open the door . If the gaskets are working there will ne a marked resistance to opening
May 13, 2013 | Bosch KSU49630 Top Freezer Refrigerator
Have a magic chef refridgerator and the water is leaking on the items below. Fan is working fine in the freezer compartment. There is icicles on the divider board. Checked the hole where the water...
at the back of the fridge there is a water drain hole. this will be blocked. you will have to unblock by pushing a thin wire etc down it, then pour a little warm water down to confirm it has been unblocked. if otherwise
There are two issues that may cause leaks near the door of your fridge. The fridge door may not close in full or the rubber gasket which encompasses the door frame may be clogged or torn, thus causing condensation and leaks. To repair this problem, you need to discover the faulty component. If the gasket is dirty, clean it by rinsing with a sponge. Check if an item in the refrigerator is preventing the door from closing properly. If the gasket is somehow impaired, replace it. When buying a new gasket, it is best to buy one that matches your fridge model or type of door. The more general the gasket, the harder it is to install it.
If the leak caused by the gasket, you may have to check the door and ensure that it closes tightly. If it does not close well, you may use the door screws and bolts to fix the problem. Another remedy is to put the refrigerator at a slight angle. Some fridges have adjustable legs, but if your model does not have such, you may want to buy some wooden shims or sheets of plywood and put them beneath the fridge.
Fridge Leaks due to the Drain Pan
The drain pan functions to catch water from condensation so that it does not leak over the floor of your kitchen. If the drain pan is somehow damaged, it may be the reason why you have a puddle of water around the fridge. The pan is located underneath the fridge. Pull it off, drain the condensed water from it, and check if there are any punctures into it. If there are some, you should buy a new pan or somehow repair the current one. One possible way to check your drain pan is to fill it with tap water once you have cleaned it.
Hope this helpout.......
Jul 28, 2010 | Refrigerators
Refrigerator does not produce ice or water. Kenmore Elite Refrigerator Model Number: 795-775-69600
If you have both ice and water stopping you have a water supply issue.
Water enters under city pressure through an eighth inch supply line.
Start simple and work from there.
If the fridge was moved the line can get kinked. Slide the fridge out and check you have water to it. You can loosen the supply line connection just a little and you should see water leaking. If not it is a plumbing issue in the house. Most likely a the supply line is kinked or possibly someone closed the shutoff valve to the fridge.
OK so we have water to the fridge.
Water comes in and connects to a water filter and then to the door.
If the filter is badly clogged it can cause low pressure to the door and that would cause the problem. Check the filter.
If no go still then check where the water is stopping.
Remove the from cover from under the unit. That is the plastic grate at the bottom of the fridge. It will just pull off but be gentle and take your time so as not to break anything.
Water supply will run through a clear plastic hose. It runs to the filter then to the bottom of the freezer door and up through the door.
You can sometimes see where the water has stopped and clear or replace parts as needed.
There is a connection just before entering the door from the filter. You can loosen that to see if you have water to that point.
If you have water past the filter the problem is in the ice maker and water supply inside the freezer door. Water can leak here, expand, and crack plastic parts easily.
If there is water to the door then you need to dig into that. This gets a little more complex to describe but in short take the ice maker out and check for water supply or broken parts. The problem is probably before the ice maker as your water in the door is not working. This indicates it is not just the ice maker.
Hope this helps.
Mar 12, 2010 | Kenmore Refrigerators
Water leaking from the roof of the fridge inside.
That is condensation. The rubber insulator (gasket) on the door may be damaged or worn. The door does not close and seal properly.
Make sure that nothing that is on top of the refrigerator is "hanging" into the path of the door seal (like a bread bag ponytail).
Also to consider:
Door hinge is loose so that door is not aligned for proper door seal.
Refrigerator is not "level" so that door is not ...
Freezer is defrosting (heating elements will warm up the coils, so "dew point temperature" may have been reached.
Check the door gaskets.
Sep 21, 2009 | Kenmore Refrigerators
Kenmore 56612 Side by Side Refrigerator Logo
79 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
