Question about Dishwashers
When I first contacted you, I couldn't get the soap door to close in my dishwasher. As suggested I got the part. I now have the door apart. When I work the soap latch I can't see what closes the door. The part I was going to replace seems to be working correctly. over
  • 12,061 Answers
Well IF the piece, the latch, seems to be working OK, then the only other thing it can be, is the Electronic "Drive" from the controller board, or a disconnection between the Controller and the Latch, Sometimes it can be a "Sensor" not allowing the latch to operate, as related you will have to work through the troubleshooting procedures to find out. It may indeed be efficacious, to get an Exact make and model of service manual, if the one supplied isn't good enough, say doesn't have your exact wiring etc.
http://appliancejunk.com/ge/dishwasher/31-3280.pdf
Above is a generic service manual, inside you have all service data troubleshooting procedures so one can isolate and hopefully effect repair.
Posted on May 26, 2010
Whirlpool dishwasher when operating does not open the soap dispenser and it remains open all the dishwasher operating cycle.
Dear Jesus,
Often water and/or soap gets inside the mechanism and causes the soap door to stop working.
The solution will be to take the door all apart and clean it all out.
Having done so a few times, I might suggest you know I have never been able to get one to work after taking it all apart.
God bless your efforts.
Jan 24, 2017 | Whirlpool Dishwashers
Why is my dishwasher leaking soap foam from the lower left area of the door?
A leaking dishwasher can be caused by excessive soapsuds. Excessive soapsuds are the most common reason dishwashers leak. Excessive soapsuds will cause dishwashers to leak from the door. Good dishwasher detergent will have no more than half inch of suds on top of the water. So any time your dishwasher is leaking from the door open the door, if there is more than a half inch of suds your problem is in your soap. One drop of hand soap, hand dish washing soap, or any other soap will cause dishwashers to leak. Now, I am not suggesting that you intentionally put this soap in the dishwasher because if you did the soapsuds would be from top-to-bottom of your dishwasher. Now if there are a lot of suds you can fix it by pouring vinegar or cold water into the dishwasher and running it, this will kill the subs.
Jul 08, 2013 | Computers & Internet
Soap cup not opening
You must take the door apart to lube / repair the linkage
Jun 11, 2010 | Kenmore 15529 Built-in Dishwasher
Brada dishwasher ef2401 wont start wash cycle
If it's under warranty, get someone to look at it. Probably a bad switch or sensor in the unit, could be something simple, and they're not hard to open up, but the soap dispenser mechanism has to be reassembled (it often falls apart upon taking the door apart). Last resort is the appliance serviceman. New house? New dishwasher? Warranty? That's your best option.
Mar 13, 2010 | GE 24 in. Profile PDW7800 Built-in...
Frigidaire dishwasher door squeaks when opened and closed
I had the same problem and this worked like a charm:
http://www.blog.applianceoutletservice.com/2008/12/frigidaire-dishwasher-door-squeaks.html
All you'll have to do is take off the kick plate, actually remove the cords, and lubricate with soap (lower tech than spray silicon, but it's worked so far...)
Aug 22, 2009 | Frigidaire PLD4555RFC Dishwasher
Soap door will not open
Chaney,
Make sure there is nothing in the way of the soap door when you close the dishwasher.
Close the dishwasher door slowly and look down in side with a flashlight, are any of the rack brackets or silverware basket directly in front of the dispenser door.
Take a look and let me know.
Regards.
Jul 21, 2009 | Frigidaire Dishwashers
KitchenAid dishwasher soap door won't open
I took the door apart and found the degertent door solinoid looking like it over heated and melted to the cover flap and the insulation. See picture. I can't post pic as the max is 150kb.
I applied power and it only got hot and wouldn't operate.
Next I go to Kitchenaid for a replacement - FREE it should be.
Oct 07, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Liduide soap
Hi mansim,
I'm Harvey the Master Plumber.
Your question is: how to use liquid dish soap in the kenmore dishwasher?and which place in dishwasher?
I think it prudent we are first clear on terminology. Based on your discription of your "dish soap", please be certain it says "dishwasher soap". If it doesn't say "dishwasher" on it then it's not meant for your dishwasher.
For a standard american dishwasher the soap goes into a small cmpartment in the door. Just open door fully and you will see the rectangular box on the left. Soap in, then close box. The dishwasher will open it on the second cycle.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 15, 2008 | Kenmore 15522 Built-in Dishwasher
Soap Dispencer Doesn't Always Open
We are having the same issue with a new dishwasher. One solution is to leave the soap dispenser box open when you close the door. This will at least get soap in the washer.
Jun 07, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Soap dispenser
A wax motor controls the opening of the lid. Also a seal that fits around the latch lever may be deteriorating and obstructing the function of the lever. Follow the link below for images and part numbers with cost.
Item# 1405...$20.30
Item# 1434...$ 3.95
http://www.repairclinic.com/SmartSearch/smartsearch.aspx
Jun 04, 2008 | Maytag 24 in. DWU9202 Built-in Dishwasher
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
