Question about Dometic Rooftop RV Air Conditioner
My ac ices up and doesn't put out cold air - Dometic Rooftop RV Air Conditioner
  • 28 Answers
RV AC is not my specialty but icing up is caused by only one thing; a restriction in the refrigerant line. The restriction is usually caused by the unit being low on refrigerant (needs to be recharged) but could also be from another cause such as one of the lines being bent/kinked or a compressor problem that let oil or something else into the lines.
Since the unit is probably low on refrigerant charging it up will cure the problem, however you'll still need to determine why it's low - just older and the leak was over time or a leak in some component of the coil or line set.
You may be able to recharge it yourself or your RV service man can either do it or point you to an HVAC tech with the appropriate experience.
Good Luck
Posted on May 26, 2010
3 Suggested Answers
roniecon
  • 6927 Answers
SOURCE: AC not blowing Cold Air
take ac cage off or ac out of window so insides are exposed take out side and use water hose and clean out side coils and in side coils dont bend these coils or u will be sorry,,,clean out good if not stoped up have freon put in
Posted on Jul 03, 2009
  • 55 Answers
SOURCE: The inside RUUD AC unit has ice and no cold air is blown
it is likely low on coolant or as some say "freon" that or the indoor fan motor has not run properly. let it thaw completely by shutting it off and just turning on your fan switch from auto to the on positon. if you begin to feel air flow eventually you need coolant added b/c you probably have a leak from the system being old
Posted on Sep 13, 2009
Ice formation ac indoor unit
several issues can cause this problem.
1st. not enough air circulating the evaporator coil meaning dirt filters or obstruction.
2nd. low refrigerant charge.
3rd. the out side tempurature maybe to cold, some units don't funtion well in cold climites.
Nov 22, 2013 | Heating & Cooling
This is how the problem manifests itself now: - When I picked up the car from dealer two days ago at the border the AC was not at first ice-cold, but after a short while it got ice-cold. - I drove for 90...
Check to see if there is a thermometer built in to the ac controler. It could be dirty dusty or defective. Also check ac fans to make sure one or both are working well and check ac pressure to make sure you have enough freon.
Nov 10, 2012 | Air Conditioning and Heat for Lotus Evora
Air is not blowing cold ice on coils
Air conditioning is all about the proper airflow across the condenser and evaporator coil (coil panel). Be sure your filters are clean and there are not any obstructions such as a dirty condenser coil. Also check all tubing and fitting connections for signs of oil which would indicate a refrigerant leak and has now caused the AC to be insufficiently charged.This would cause ice build-up on the evaporator (coil panel) and the out-put of only 70 degrees.
May 31, 2012 | Frigidaire FAS156N1A Air Conditioner
98 VW Beetle AC acting up I have a 98 VW Beetle
without putting my machine on it and extracting the gas to see how much gas their is by weight then i couldnt even think of a reason for this sorry
Sep 13, 2011 | 1998 Volkswagen Beetle
Put new AC compressor on, ice cold air for 2 days then blowing cool to warm air. Compressor is working but air not cold. Sometimes will get a small burst of cooler air but doesn't last.
You did'nt mention if you got the system refilled with Refrigerant after the Compressor was replaced or not. If not, that could be the problem.
Jul 25, 2011 | 1995 Mercury Villager
My goldstar R2403 doesn't seem to be pushing out as cold as I feel it should we just had the unit refirbished and they claim it was running ice cold sitting on the bench in repair shop, however we have...
The link below is for the Owners/Service Manual for your model Goldstar AC unit. It should be of tremendous help in troubleshooting and solving the problem. Either by you. or your maintenance man.
http://www.appliancefactoryparts.com/content/pdfs/118630.pdf
Hope this helps you.
Jul 20, 2011 | Goldstar R2403 Air Conditioner
My central air unit comes on but it's not cool and
to me it sounds like filter are dirty, need to be cleaned or replaced, home systems, packaged or otherwise are hermetically sealed and should not need freon recharge. Always start with airflow and/or unit being set too low. An AC unit of any type will build ice if a) the filter is plugged up and can't move enough air, b) it has been run without the filter, clogging the coil, again, not moving enough air, c) setting an AC unit below 68 degrees F will almost ALWAYS cause icing, and d) running a standard AC when it's warm inside and cold outside (unless equipped for "low-ambient operation"). When in doubt, a bit of maintenance(thorough cleaning) by someone with AC skills can cure a b, common sense will cure c d.
Reply
Jun 23, 2011 | Goodman CKL42AR42 Air Conditioner
Jul 03, 2009 | Goldstar M5200R Air Conditioner
Jetta AC mixes hot and cold air
You won't get ice cold because it mixes to prevent evaporator ice up and cracked windshiels.
Jun 02, 2009 | 2000 Volkswagen Jetta TDI
Dometic Rooftop RV Air Conditioner Logo
264 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
