Ruud UBHC Air Conditioner Logo
Posted on May 26, 2010
While the central air unit is on, water is leaking
While my central air is on, water is leaking from the bottom of the furnace. What is causing this problem?
WatsHVAC
Level 1:
Loyalty:
Visited the website for 30 consecutive days.
  • Contributor 35 Answers
  • Posted on May 26, 2010
WatsHVAC
Contributor
Level 1:
Loyalty:
Answers
35
Questions
0
Helped
53388
Points
87
Any time you have an HVAC problem the best solution is to call a qualified tech. While many problems (and quite possibly this one) aren't that hard to fix the repair cost if you screw something up can be very high. My disclaimer out of the way, here you go:
the condensate (water) is not draining properly. This is either because your pump (if you have one) isn't working, the drain line is clogged (most likely), the gravity drain has been knocked around and feeds back into the furnace, or something more sinister (crack in the evaporator coil pan, for instance). If you have a pump (you'll see PVC running into it and vinyl tubing running out, make sure it's plugged in and the lines are not clogged or kinked. If you have a gravity drain try disconnecting it and blowing it out and making sure it always runs downhill, even if only a little. Other than that, call the HVAC service guys.
Good Luck
1helpful
Water leaking from base of unit
Check the drain it must be plugged. Check the evaporator coils for exessive ice build up on the coils, you may have a dirty filter and not getting enough air flow to keep ice from forming on the coils. The unit should have a drain built in it under the evaporator coils inside the unit. If it is a central air the evaporator is usually above the furnace. This drain pan may be rusty and leaking as well. You may have to unscrew a panel or two depending on how your unit is installed to get to the drain pan.
If this was helpful a vote on the thumbs up would be greatly appreciated for the free advice.
Thanks for using Fix Ya
1helpful
2answers
There is water leaking out from the bottom of my furnace. It leaks whenever the ac is running.
Hello, sounds like a clogged condensate line or a faulty condensate pump if the unit has one. Cleaning the drain line should fix the problem.
1helpful
2answers
I have water leaking out the bottom of my furnace when the aprilaire 700 is working. I have tried everything to resolve. It was working fine last month. I changed the water filter, cleaned the lines...
How old it your Aprilaire 700?
Eventually they all need maintenance, cleaning or replacing dirty or inoperative parts. The bottom Water tray has a drain tube that needs to be cleaned or replaced every fall as it will plug up with mineral deposits washed down from the unit. Adding a water filter to the inlet line (if you don't already have one) will reduce mineral scale build up and reduce the need for cleaning and maintenance. Some water filters may bypass uinfiltered water when very dirty. If thats OK, then the solenoid valves could be dirty, worn and now leaking all the time (not shutting off at end of operation cycle) These valves, 2 usually 1 Low volt operated 24 VDC supplied by thermostat and or humidistat when caling for heat, and 1 High volt 120 or 240 VAC suppiied by furnace fan delay switch, All Gas furnaces have a fan delay to allow the heat exchanger to warm up so the furnace does not blow cold air at the at the start of every cycle of heating. Both have to br powered on to allow water flow.
Click on the link below and read the Aprilaire Manual maintenance page. This Manual covers several models, so disregard parts not pertaining to your model number.
Remember to turn of electrical power to unit, furnace, air handler if a split unit, and don't attempt anything your not exceeding your experience level.
Vote for Patrick Mot, Thanks
http://www.aprilaire.com/themes/aa/en/manuals/AA-Humidifier-Owners.pdf
There is water leaking from the bottom of the new gas furnace. This happend last year and they said a hose was plugged. It is happening again this year and they are saying now it is because we didn't have...
No. The installers did not properly plumb you hose. You have a high efficient furnace which is really nice. However, this furnace takes out moister from the air when heating, causing condensation. I would look at the installation manual and see if they installed them properly. They might of installed the wrong unit for you home. Most Goodman furnaces can only be installed up-flow meaning in the closet or horizontal installed meaning in the attic. Look at the installation manual to see if they installed the right unit for your home. www.fastacservice.com
My unit is leaking water from the inside central unit.
yes you must get the clog cleared. you nee to clear the 3/4" pvc drain
Water dripping from furnace while air conditioner is running.
you need to have a drip line that take away the water when the ac is on so the water does not goes into the furnace ,also check for leaky line that could causing water to leak back
1helpful
My Air conditioner leaks water
All A/C units drain water and need a clear path to drain water.
If window unit the unit MUST lean to the outside so the condensation water can drain that direction and insure the drain hole is clear of debree.
If an indoor central a/c unit the drain must be clogged the unit is leaning away from drain or the pipe going to the drain is clogged somewhere as it exits house. Cant drain if doesn't have a clear path to do it's job. Doubt it's a problem with the brand.
1helpful
2answers
Aprilaire 700 leaks water from bottom of case
Install new water panels yearly. On the new panel make sure that the painted dot on the edge of the panel is on the top when you install it.
Always clean the distribution tray and the frame. Make sure the notch on the edge of the distribution tray faces away from the furnace. Make sure the humidifier was installed level. Keep the drain tube opening clear. Insure there is no blockages in the drain tube.
Good luck
HVAC Teacher
5helpful
Furnace is leaking water
This is not a lot to go on.
I assume since you called it a furnace, you have hot air heat and central air conditioning. If so, the only way a furnace/AC unit can generate water is by condensing moisture from the air. This is common to all air conditioning and removes humidity from your home. If so, this water, called condensate, must drain. The condensate is collected at the AC cooling coil that is typically located on top of a vertical upflow furnace or downstream of a horizontal furnace. If the drain is clogged, it will overflow and create a mess in and around the furnace. If this is your problem, cleaning and clearing debris may solve the issue. I suggest starting with the easiest accessable part of the drain path. You may need to open the panels enclosing the AC coil and clean the small pans at the bottom of the coil and clear openings from above that look similar to a laundry tub drain. If you get that far and find rust holes in the pan, repairs are needed. If you have an electric condensate pump that may also be the cuprit and require cleaning. Check and clear all drain lines from the coil connection to the final dicharge - sump pit or outside.
Central air conditoner unit doesnt blow cool air into home has some ice on the inlet heat and cooling lines going into the central air unit
Change the furnace filter. Make sure you use a cheap one when air conditioning, as the better ones restrict airflow when they filter out so much stuff and then plug up, not allowing enough air to pass over the cooling coil in the furnace's air plenum. Turn the A/C off for a few hours (with only the furnace fan on if possible) to melt the ice off the cooling unit inside the furnace.
Top Ruud Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
