Question about Brother IntelliFAX 4100 Laser Fax
The 4100 we have had for 4 or 5 years has stopped working - does not send or receive, and when I dial, the number is sporadic 3 digits, then 3 more, then 3 more, etc. sounds dire to me. but checking anyway.
  • 821 Answers
Hello,make sure the papers are placed correctly before you start faxing,and also make sure all connections are in the right places.
Make sure the telephone wire is plugged into the line jack (not ext jack) and should go straight to the wall, without splitters or extensions. If you still cannot send a fax, try another wire or jack.
wish you good luck,
take care.
Posted on May 26, 2010
  • 4 more comments
  • deb2trvl May 26, 2010
    I have done all that,,, we have worked with it for many years and know how it should look. I think it is dead, and I have asked the charge to be reversed.
  • Hammid Disu May 26, 2010
    HELLO,kindly check the charge very well,and i will also like to know if the fax machine powers on at all to allow you dial numbers or to fix the documents in it.if it doesn't power on,i will suspect the fax machine is dead as said.
    wish you good luck,
    take care.
  • deb2trvl May 27, 2010
    Power is on, and it dials, but dials the numbers like I said 3 numbers, pause and then 3 more, pause, and then 3 or 4 more.. and nothing comes in or goes out. Just beeps as it tries to go thru in sending.
    Here is more:
    The display says "telephone" sleep. The mode is set to FAX. Any ideas?
    Every mode displayed shows "sleep" under it.. "dialing" etc. But then switches to "On LIne" instead of sleep And still nothing. Shall I give up?
  • Hammid Disu May 27, 2010
    hello,i will advice you update the firmware or you reinstall the driver and see if the problem persist,if it does then i will suggest you contact their customer service session before you can decide on weather to lose hope in it.
    for customer care support visit the site below,
    http://www.brother-usa.com/Support/
    you can visit the link below to download your driver,
    http://welcome.solutions.brother.com/bsc...
    take care.
Can't send or receive fax hagans@loadednet.com.au
Check the cable, i.e. plug an analogue phone into the cable and listen for a dial tone. If none, are you plugged into a digital line?
If a dial tone is heard, is it an intermittant dial tone (message waiting) because this can stop the fax from working. If so, resolve this and try again.
Do you need to dial a number to get an outside line? If so this needs to be entered before the fax number on outgoing faxes.
Nov 17, 2009 | Canon MP830 All-In-One Printer
Brother 4100 fax m\c
http://www.brothersupport.com/Facsimile/User/um_zlefax.pdf
Setting Station ID
You should store your name or (company name) and fax number to be printed
on all fax pages you send. The telephone number you enter will be printed only
on your cover pages and call back messages. (See Composing Electronic Cover
Page
, Page 6-6.)
1 Press Menu, 1, 3.
2 Enter your fax number (up to 20
digits), and then press Set. You must
enter a fax number to proceed.
3 Enter your telephone number (up) to
20 digits), and then press Set.
If your telephone number and fax
number are the same, enter the same
number again. The number appears
on Cover pages.
4 Use the dial pad to enter your name
(up to 20 characters), and then press
Set.
(See Entering Text.)
5 Press Stop/Exit.
The LCD returns to the date and time.
If your Station ID has already been programmed, the LCD prompts “1” to make
a change, or “2” to exit without changing.
Aug 25, 2009 | Brother IntelliFax-2820 Laser Fax
How do i program speed dial phone numbers into my brother intellifax 4100
Per Intellifax 4100 manual:
Storing Speed Dial Numbers
Press Menu, 2, 3, 2.
2 Enter a three-digit (a two-digit for
FAX-4100) Speed Dial number, and
then press Set.
3 Enter a number (up to 20 digits), and
then press Set.
4 Enter a name (or leave it blank), and
then press Set.
5 Press Stop/Exit.
I hope this answers your question. Thanks for using Fixya and best of luck!
Greg
Jun 12, 2009 | Brother IntelliFAX 4100 Laser Fax
Brother Intellifax 4100 unable to send fax but can receive
Is the fax sensing the paper you put in to send out? Check the little black levers that poke into the document area. They should move freely when you touch them gently with a finger, and return quickly when you take your finger off. If it can't sense the paper it won't try to send a fax. If, when the paper is inserted, the display changes from whatever it said to anything else, the paper is being sensed.
Let's try dialing manually. Just left of the 1 key is a button labeled "Hook." Pressing that will take the telephone line "off-hook," like picking up the receiver of a phone. You should hear a dial tone -- if not, try adjusting the speaker volume with the buttons just right of the numbers. Once you get a dial tone, dial a number, whether it's another fax, or your own cell phone. As far as the phone company is concerned, your fax is just a phone, calling another phone. If you can make a call, and the phone at the other end rings, we're closing in on the problem. If you can dial another fax machine manually, you can still turn this into a fax call, assuming there's paper ready to fax. After the distant fax answers, touch the Start button, and your fax should take over. If you can't dial manually, try unplugging your fax from the phone line, and replacing it with a regular phone. Can you make calls with it? If not, the fax is no longer a suspect - you have a phone line problem.
Are you at a business where you need to dial 9 to get an outside line? It's easy to forget that detail when you're using a fax, but it has to dial out just like any other phone on the system.
If you can't get a dial tone at all with the fax, but it works with the phone alone, the main board in the fax is probably bad. If you can dial manually, using the Hook switch, but the same number doesn't work when you dial xxx-xxxx-Start, that sounds like a main board problem, too.
May 05, 2009 | Brother IntelliFax-4100e Fax
NEED THE MACHINE TO ANSWER WHEN THE PHONE SENDS THE SIGNAL.
After making my post, I went to the official Brothers website for the 4100 FAQs and "Operating Instructions." Here's what I found. Set your 4100 set to the "Fax/Tel" mode. Press "Menu", then the number 2 (Fax), then number 1(Set-up Receive), then number 1 again (Ring Delay). Use right arrow key to increase. Once increased, press the "Set" key. You'll see the message "Accepted." Now press the "Stop" key to exit "Menu." This will now give you up to 4 rings before the fax auto answers. Inorder to send a signal by phone to remote start the fax just follow the instructions I copied directly from Brothers instructions for the 4100: If you answer the call on an extension phone (this is any phone plug into a phone jack on the same line) and hear a beep every 3 seconds (automatic fax) or just silence (manual fax), press *51(remote activation code) on the telephone keypad, wait to hear the Brother machine turn on (chirping sounds) and then hang up. I don't have anyone that can send me a fax right now to test it out. I'll have to try it in the morning. Hope this works for you.
THEOH
Feb 23, 2009 | Brother IntelliFAX 4100 Laser Fax
Will not let me dial.
Did you try unplugging the power cord?
Sep 10, 2008 | Brother IntelliFAX 4100 Laser Fax
Broadcast Faxing with a Access Code
I contacted the Brother web site and they said it can be done, but has to be done using the speed dial feature.
Jul 11, 2008 | Brother IntelliFAX 4100 Laser Fax
Receiving multiple page fax on Brother Intellifax 4100e
it may be the memory, try switching to direct printing instead of going into memory, if it prints you should change the memory.
Jul 01, 2008 | Brother IntelliFAX 4100 Laser Fax
Phone keeps sending message
see if the message is in the drafts folder or the sent items if so delete phone will stop sending
Jan 09, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Brother IntelliFAX 4100 Laser Fax Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
