Question about Brother IntelliFAX 770 Plain Paper Thermal Fax
Where does paper go to receive fax?
Where to place paper in machine?
In the slot farthest back
Posted on May 29, 2010
Receive a fax
hi , please following the step , fax ring the time you take hand set & press the start button & place the hand set
Mar 24, 2014 | HP 2140 Plain Paper Fax/copier W/ink brand...
How do I unjam a fax machine 1010
to clear document jam:
1 Open the front panel.
2 Carefully remove the jammed document.
3 Close the front panel firmly until it clicks
into place.
If the fax paper jams while you are receiving or printing, Remove jammed paper and press
Cancel appears in the message.
if the paper is jammed in the printing area
1 Remove the jammed paper by pulling it out
smoothly in the direction of the arrow as
shown.
If the paper tears when it is being removed
check to ensure that no small pieces have
been left inside the machine.
2 Press Cancel.
3 If this was a fax, reprint the fax. For more
information, see reprinting faxes on
page 29.
if the paper is jammed in the paper feed
area
1 Remove the jammed paper as shown.
removed check to ensure that no small
pieces have been left inside the machine.
2 Reload new paper with the print side
facing toward you.
3 Press Cancel when finished.
May 04, 2012 | HP 1010 Plain Paper Inkjet Fax
Paper jam won't go away and its no paper in the machine
was there a paper jam in the first place where you had to pull the paper out?if so try and get in there and check if there is a little peice left as i believe these have little sensors that are affected very easily by the tinyest of paper. good luck!
Feb 07, 2012 | Sharp UX 355L Plain Paper Thermal transfer...
We are getting a Comms Error 0030 every time a fax is incoming. What does this mean and how can we stop it?
Are you receiving faxes only from one place? This error indicates that your machine is not receiving the "handshake" from the other machine. It knows a call came in and sent a request to the other machine for parameters, but did not receive a response.
If this happens with all incoming faxes, your machine may need to be serviced.
Mar 10, 2010 | Canon FAX L-120 Plain Paper Laser
CAN'T SEND OR RECEIVE ANY FAXES
HI.when u try to receive or send any fax.fax gives any msg r not.first check ur telephone line.u have to connect it in line.there are two places in fax .one is ext and second is line.check it u r putting it line.for receiving check auto answer .put it on fax only mode.u will receive fax.MIAN AKHLAQ.if it helps rate the solution.
May 16, 2009 | Panasonic KX-FPG381 Plain Paper Thermal...
Instructions on how to send and receive a fax.
For most fax machines:
1. Choose the "Fax" option
2. Place paper in feeder tray
3. Dial phone number
4. Press the start/go button, usually green
Hope that helps
Apr 30, 2009 | Office Equipment & Supplies
Canon Fax JX-500 will not print any faxes
Just press the on/off button once this should do it.
Jul 16, 2008 | Canon FAX-JX200
Automated Document Feeder Problem
It sound like the paper is not getting recognised by the original sensor. Check for an obstruction in the feedpath - piece of paper, paper clip, pin, cockroach, apple core, tube of cake decorator (I've seen it all). Do this by opening the control panel cover (the one you open when you replace your cartridge and look through where the original feeds. Also see if the original sensor arm is in place. In the white plate there will be a black arm. The original sensor arm will be directly behind this sensor.
Feb 12, 2008 | Brother IntelliFAX 560 Plain Paper Fax
Brother IntelliFAX 770 Plain Paper Thermal Fax Logo
35 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
