Question about Fujitsu LifeBook S-4572 Notebook
Updating the RAM memory
I have just got some ram for my laptop,
i inserted the ram (256 mb)
and the screen wont turn on ,
the laptop wont do anything unless i insert my old ram in
(64mb)
its a pc100 sd ram
for a fujitsu S-4572
many thanks
  • 77 Answers
Http://www.memoryx.net/fulisme4.html
click the link above for the correct ram to purchase
Most likely your bought an incompatible ram for your unit. Return it and buy from the link above
Posted on Apr 08, 2008
Is there a way the memory in a toshiba satellite 1005-s157 be increased to more than 512MB?
Yes you can, at least to 1 Gb maybe possibly to 2 Gb.
There will be two memory slots in your laptop. To increase the RAM to 1 Gb install another 512 Mb RAM module in the empty 2nd memory slot. Make sure you use the same make and speed RAM as the one that is installed.
If you have two 256 Mb RAM modules installed in your laptop then you need to replace the two 256 Mb RAM modules with two 512 Mb RAM modules to get a total of 1 Gb RAM.
Aug 04, 2012 | Toshiba Computers & Internet
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
After adding 256 MB with existing 256 MB showing only 256 MB in BIOS instead of 512 MB
The problem could be One of the 256MB RAM is not deatected as not inserted properly or due to malfunction.
Download this small application.
Here is the link
http://www.cpuid.com/download/cpuz/cpuz_153_setup.exe
Download this application and run (you don't need to install this software).
Check in which SLOT your RAM is Working using the above application.
Try to insert it properly again.You can also try by interchanging The RAM, yso that you can pin point whihc of the RAM is malfunctioning in case of MALFUNCTION.
Rate this Solution.
Jan 07, 2010 | IBM ThinkPad T30 2366 Notebook
I want my Laptop Dell Latitude C800 physical memory upgraded to 128 mb to 256 mb I myself already installed 256 mb Ram but it still showing 128 mb of memory...can I get help in this regard ?
I assume you installed another 128Mb of RAM to give you a total of 256Mb.
It is most likely the 2nd RAM module is not compatible with the other RAM module. Try using the same make.
OR
Purchase and install a single RAM module 256Mb or 512Mb these are not expensive.
Dec 20, 2009 | Dell PowerEdge 2600 Server
I would like to nwom how much of memory this laptop support
The Thinkpad is installed with 128 MB SDRAM is standard, and is expandable to 512 MB
There are two memory slots, to expand it to 512 Mb you need two 256 Mb RAM modules and throw away the 128 Mb RAM module, but if you don't throw away this module and you insert a 256 Mb RAM module in the 2nd memory slot then your total memory would be 384 Mb.
Nov 20, 2009 | IBM ThinkPad T20 2647 Notebook
Change ram from 512 to 1 gig bios cannot read added ram
The original 2 sticks of 256 Mb of RAM gives you a total of 512
Mb of RAM. Two 512 Mb of RAM gives you a total of 1 Gb of RAM.
With two sticks of 512 Mb of RAM are you sure you got a total of 192 Mb of RAM, this is a lot less than the original RAM total of 512 Mb?
Should this be 1920 Mb of RAM?
If this 192 Mb is correct then the RAM modules are either not compatible with the laptop or if the RAM modules are not from the same manufacturer then they may not work together.
Most laptops have video cards that use part of the main RAM for video RAM, that is why the available RAM is less than the installed RAM modules. The amount of RAM the video card grabs depends upon the type of video card and in some cases the amount of video RAM can controlled in the BIOS setting.
Nov 07, 2009 | Sony VAIO PCG-K25 Notebook
Burned RAM
just remove the 256mb ram it is the main problem only insert equal memmory of rams in 2 slots, if u insert 1gb ram in one slot try to insert also 1gb ram in other slot, donot inser 2 unequal rams in one time
Sep 28, 2009 | Computers & Internet
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Want more ram
Check if your new RAM is properly inserted. Also, see if the speed matches the other, original one. You might be mixing speeds that gives you some trouble. Another way is to swap the RAM, place the new one to the slot of the old one. Also, check if your motherboard will allow more memory to be added in your system. You may have reached the maximum memory capacity.
Sep 08, 2008 | E-Machines eMachines Desktop PC
Upgrade ram on 12XL125
Specifications for the Compaq 12XL125 state that the system memory is:
64 MB 100 MHz SyncDRAM, shared memory architecture, upgradable to 192 MB - 4 MB dedicated for video memory
This system will not be able to use the ram you are trying to install.  For more about this system go to this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00013744&lc=en&cc=us&product=95040&dlc=en
Aug 16, 2008 | Compaq Presario 12XL125 Notebook
Fujitsu LifeBook S-4572 Notebook Logo
126 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
