Question about Enermax 431W Ultra Quiet ATX Power Supply: EG465P-VE (FCA) Whisper Series - replace 400 or 450 watt (CSPSEM465FCA) Power Supply
Dishes do not come out dry and this has just begin happening.
    Genius:
  • 1,027 Answers
I'll assume you refer to a dishwasher and not a PC. If the internal pump does not get all the water out, then the resulting pool in the bottom will inhibit the dry cycle. When it has reached the end of the washing cycles, open the door and see how much water is left. Then you will need to find out why that is, if there is a lot remaining. Could be a clogged screen on the pump.
Posted on May 27, 2010
Why is our zsf6128 dishwasher is stuck in dry mode and cannot start it
I'll try to explain how drying works generally in the dishwasher.
Dishes absorbs heat and cools more slowly than a very thin wall of stainless steel.
The consequence is that water evaporates and in accordance with the Mollier diagram begins to condense on the walls of the stainless steel whose temperature is lower due to faster cooling of the dishes.
Now drying can be divided into two categories. Active and passive.
Passive way of drying the natural circulation of moist air and condensation in the condenser, which is usually located on the left or right side of the dishwasher.
Active way of drying works on the principle of forced circulation humid air with fun helping quickly condenses and thus speeds up the drying of dishes.
In passive mode the drying process can speed up the partial opening of the door.
Dado
Sep 22, 2014 | Zanussi Dishwashers
Dx 302 wont dry dishes
The model you specified is unknown to me and I'll try to explain how drying works generally in the dishwasher.
Dado
Aug 08, 2014 | Electrolux Dishwashers
Why are my dishes dry with water spots?
may need some rinse agent. verify the liquid level in the rinse agent bottle.
Jun 16, 2014 | Fagor Dishwashers
LG LDF6810 not drying dishes
I have also found this happening. I have found that if you switch the dishwasher off 2-4 minutes into the dry cycle and leave it for a few hours or over night the dishes are completely dry
Jun 12, 2012 | LG LDF6810 Built-in Dishwasher
I have a Danby DDW1899WP portable dishwasher. I just got it yesterday. I had a lot of dirty dishes so I did 1 cycle first and it worked perfectly, I was impressed. I then started a 2nd cycle for the rest...
I realize the above question is almost 4 years old, but I am sure others are still having this problem. My Danby was behaving the same way: drying cycle light would flash like it was having a myocardial infarction, and the cycle would stop. I could only get the light to stop flashing by turning the unit off. What you didn\'t say above is what happens then: everything most likely returns to normal-- or at least, so it seems. I have now had this happen to me two times in a row with my Danby 1899WP. Each time the machine has started up just fine, drains water out, loads in fresh water, and begins the wash cycle, only to freeze up with that damn flashing red light on the dry cycle and the dishes not clean. I have owned it for about two months, and so far this is my only complaint. I am running it again right now, for the third time, and we shall see what that light does now.... Will report back afterward!
Nov 14, 2010 | Danby DDW1899WP Portable Dishwasher
Our dishwasher is linking suds after the cycle begins BUT ONLY 1 of 10 loads does this happen. What could cause this problem? Thank you.
Use dry powder soap and just enough to clean the dishes. Usually around 2 tablespoons is enough in a modern dishwasher and soft water after giving the dishes a good scrape. If you prerinse, use much less soap!
Dec 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Lights flashing at end of cycle, dishes not clean
I switched it off at the wall and left it for a minute and set the dial to Stop and then set it again from the beginning and so far it has been fine. Thanks, DCD
Oct 02, 2009 | Miele Dishwashers
Dishes don't get clean and don't dry
Hi reesbag
I'm Harvey the Master Plumber.
You're question is why the dishes don't get clean and it is not drying at all even though jetdry is full?
To begin with "jetdry" does not dry your dishes, It is a product that you can choose to use if you have a problem with spots on the clean dishes when the dishwasher is done.
Your problem is serious! If still under warranty then you're covered. If not and it has some years on it, it doesn't pay to throw good money after bad. If it came with the house it will be better in the long run to replace it. If you choose to repair, this problem doesn't lend itself to home handyman and it is likely in this case that after paying a repairman to come out you'll end up buying new anyway.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 11, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
Doesnt dry dishes
The heater on this unit only comes on twice, once in the wash cycle, and again in the Sanitary rinse. During the drying cycle all that happens is a vent opens and a fan comes on. The fan removes the hot moist air from the unit and the dishes dry off. If your water is not hot enough, this is why your dishes are still wet. Rinse aid also helps to sheen off the excess water as well.
Sgt 48
May 06, 2008 | LG 24 in. LDF7810 Built-in Dishwasher
Problem with dishwasher
dishwasher cleans dishes but doesnt seem to dry water from dishes
Nov 04, 2007 | Zanussi ZT485 Built-in Dishwasher
Computers & Internet Logo
63 people viewed this question
Top Enermax Computers & Internet Experts
David Payne
David Payne
Are you an Enermax Computer and Internet Expert? Answer questions, earn points and help others
