Question about Bosch HBN 7052 GB Stainless Steel Electric Double Oven
Bosch hbn 70 main oven doesn't heat up everything else works. Can it be repaired?
  • 1462 Answers
SOURCE: fan oven not heating, bosch hbn 202t
the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
Posted on May 04, 2007
SOURCE: Bosch HBN 455 Oven Cooling-Fan Issue
Our HBN655 had similar issues- the upper cooling fan would cycle on and off on a relatively quick duty cycle until the whole mess cooled off enough and it shut off.
My workaround is to turn the temperature dial off but leave the oven function dial on to BAKE. This seems to force the fan to stay on; then we shut it off a while later and avoid the annoying fan cycling.
(note- 2 years ago, our fan became intermittent, varying speed, etc... for about 2 months before it quit entirely. When that happened, the oven started to heat then the thermal cutout kicked in and the oven shut down entirely. We ended up replacing the fan and that fixed the bug... except now it's starting to act up again...)
(also note- the racks on this beast have a faulty design. if you have a heavy casserole and slide the rack out all the way, it tends push the sidewalls apart and the rack drops. I spoke with Bosch about this and they sent me new racks, no charge... so they know there's a problem. But the new racks don't fix the bug; they just make it harder to reproduce. I have actually had one rack fall with 2 piping hot casseroles on it. Fortunately no one was hurt.)
Posted on Nov 04, 2007
murdozzz2
  • 75 Answers
SOURCE: bosch electric single oven (hbn 4305)
hi there have you cheked that your timer is not set to auto function
Posted on Dec 09, 2007
Master_Tech
  • 770 Answers
SOURCE: Easy Off Heavy Duty Oven Cleaner on Self Cleaning Oven
NO..wont hurt it as loong as you got it all out.. but plz remind her that this is a self cleaning oven....Which does not mean you have to clean it yourself !!! it should be fine.. tell her next time to run it thru a self clean cycle for at least 3.5 hours on the timer setting..
Posted on Jan 27, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    Tip
    Common heating faults with Bosch HBN 560570B / 560550B single oven
    For all Free appliance repair videos visit our VIDEO TUTORIALS 1, If the Bosch fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
    To gain access to the BOSCH element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
    2, If your BOSCH fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
    3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your BOSCH oven thermostat
    4, A quite common and easily overlooked answer is if your BOSCH oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
    on Jan 19, 2010 | Bosch HBN 560570B / 560550B Electric...
    Tip
    Common heating faults with Bosch HBN 430560B / 430520B single oven
    on Jan 19, 2010 | Bosch HBN 430560B / 430520B Single Oven
    I HAVE A HBN 43M5.OB DOUBLE OVEN AND THE MAIN OVEN WILL NOT HEAT UP AND THE RED LIGHT STAYS ON .THE GRILL WORKS ON THE MAIN OVEN AND SO DOES THE SMALL OVEN WORK.
    Most likely the heater element has burnt out. This is accessible by removing the panel in the back of the oven.
    *** ENSURE POWER TO OVEN IS OFF BEFORE ATTEMPTING REPAIR ***
    Nov 14, 2010 | Bosch Ovens
    I purchased a microwave/convect oven combo last week. Installed today, everything works fine except that the lower oven won't heat. I tried turning the breakers off waiting a few minutes and back on. ...
    Ensure that the clock is set and that is not in auto mode, the clock is only linked to the main oven and therefore it will not opearte if the clock is not set correctly, all the best
    Sep 04, 2010 | Bosch HBN 9722 GB Electric Double Oven
    Tip
    Common heating faults with Bosch HBN 131560B / 131520 single oven
    on Jan 19, 2010 | Bosch HBN 131560B / 131520 hot-air...
    Tip
    Common heating faults with Bosch HBN 442 / HBN446 single oven
    on Jan 19, 2010 | Bosch HBN 442 / HBN446 Electric Single...
    Bosch double oven, fan and light work but won't heat.
    my lower oven wont heat on my HBN 70 got light and fan but no heat
    Oct 18, 2009 | Bosch Ovens
    MAIN OVEN DOESNT WORK
    Hi
    Pretty certain nofuse. Suspect switch. Guess would be as element blew it took out contacts on oven switch
    Feb 20, 2009 | Bosch HBN 7052 GB Stainless Steel Electric...
    Bosch hbn s gb
    oven element would need model and ENR No. to supply
    Sep 16, 2008 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
    Bosch HBN 7052 GB Stainless Steel Electric Double Oven Logo
    304 people viewed this question
    Top Bosch Ovens Experts
    ashburton
    Oloyede Monsuru
    Are you a Bosch Oven Expert? Answer questions, earn points and help others
