Question about Hitachi Computers & Internet
Hitachi, Prodrive, 1tb, not working. Light comes on but doesn't register in computer (imac G4). do I need to try a new case and if so how do i go about dong that?
    Top Expert:
  • Hitachi Master
  • 79,186 Answers
If the drive was sensed before by the PC then the problem is with the drive, it is defective, most likely the hard disk has failed.
Posted on May 26, 2010
  • jonathangrey May 27, 2010
    Thanks. I have determined it is the external drive. (SimpleTech ProDrive 1tb {Hitachi Hardrive}). However, I hear it spinning and it gets warm, but it doesn't really click or get recognized on the Mac (Tiger 10.4.11) desktop. This has happened before but I ran a disk utility on it via Tiger OS install disc, and was able to repair it no problem. Now it won't even show up. It did have a tendency to get very hot and in the past I have turned it off without ejecting it a few times. (not sure if that means anything) I"m at the point of an opened case hard drive intact, ready for my next move...Can I just buy another case for it and connect the drive to that case to see if it boots up and if so, how do you recommend I go about in doing that? Thanks
  • yadayada
    yadayada May 27, 2010
    it is a waste of time to try and repair the drive, u can't buy the parts only a repair center can get them, just replace it, it is considered a throw away component when they fail.
How to take a back of imac
The back does not come off the new iMacs. The front glass is held on with magnets. If you search Youtube you can find demonstration of dis-assembly with suction cups.
May 20, 2014 | Apple iMac 27in Desktop i5 3.1GHz 4GB 1TB...
Imac G4 0s 10,4.11 need a flash to watch hulu free tv
You can't watch Hulu on a PowerPC iMac G4. You need an Intel processor based Mac to watch Hulu and Netflix.
Dec 19, 2012 | Apple A1106 Powerbook G4 15", 1.67 Ghz,...
Hallo. My simple drive hitachi 1TB 96300-41001-170 dont appear in my computer. I need driver but i cant fint it.
This should be plug-n-play. Have you tried restarting the computer with the hard drive plugged in? If that doesn't work, I would return it.
Apr 14, 2011 | SimpleTech 1TB SimpleDrive Pro Duo...
Hi i'm from greece and i bought a hitachi simple drive external hard drive 1 tb about 4 months ago it worked fine but now suddently it stopped . i tried to take it of the power and i also removed the cable...
you must have short in the wire hooked up to external try jiggling the base of wire pluged up to port on the external see if you see the light on hard flicker on off if thats the case its your wire for right intell you get a new wire prop something underneath wire intell you see the light stay on.
Feb 24, 2011 | Hitachi 1TB External USB 2.0 Hard Drive
I have a 1TB Hitachi HD i used on my Imac. now my son has it but he has Windows XP..How can i format this to window so he can use it. We plug the Hitachi on his comp. but do not show any help?
Connect the Hitachi
Click Start
Right-mouse click My Computer
Click Manage
Click Storage
Click Disk Management
Right-mouse click the icon for the Hitachi
Click Format
Assign a drive-letter
Done.
Oct 18, 2010 | Hitachi 1TB External USB 2.0 Hard Drive
IMac G4 Mac Desktop: imac g4 wont boot up scree's just blue?...
If it only boots to a blue screen, try booting up in Safe Boot mode:
http://support.apple.com/kb/ht1455
If this does not work, boot from your install DVD and use Disk Utility to repair the disk:
http://support.apple.com/kb/ht2956
If this does not resolve the issue you may need to use your isntall disc to perform an Archive and Install:
http://support.apple.com/kb/ht1710
May 18, 2010 | Apple iMac G4 Desktop
Sims 3 won't install on my imac G4. I have Leopard 10.8 so I have the correct system requirements. When I click on install it keeps coming up Not supported on this architecture?
If you read the system requirements of Sims 3, it says that you need at least an Intel Core Duo processor, which the iMac G4 does not have. The iMac G4 has a PowerPC processor.
Jan 31, 2010 | Apple iMac G4 Desktop
Powermac g4 shut down
OK it's a G4 iMac.
Burning smells coming from macs often indicate a failure in the power supply module. That said, the G4 iMac (in my experience) has been the most reliable iMac ever and power module failures are very rare.
Your best option is to find a Mac repair centre near you and take in in for a quote. But be warned - it will cost. For some reason known only to Apple power supply modules are expensive (but not as expensive as the equivalent volume of HP ink) and replacing them is not as easy as on many of the other computers.
If it is the power supply, you will not be able to switch it on again. Your data on the HD should be safe (unless the smell was coming from that - - I've had it happen!). So when you get to the workshop and you've had your quote, if you decide not to go ahead with the repair, ask the workshop to remove your HD and put it into an external case so that you can plug it in to another Mac and continue using it.
Let us know what the outcome is.
Oct 07, 2009 | Quicksilver Power Mac G4 (Quicksilver)
IMac G4 starts, but programs close with errors
open the applications folder go to utilities folder open program called disk utility select the main disk in the list on the left and click repair disk permissions if that doesn't work please send me the error message
Apr 06, 2009 | Apple iMac G4 Desktop
Computers & Internet Logo
Top Hitachi Computers & Internet Experts
Alun Cox
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
