Question about Dell Latitude D600 Notebook
I cant get the touch pad and mouse to respond long enough to change settings and not sure where to go to do that.
  • 23 Answers
If mouse stops working shortly after booting up, sounds like driver conflicts, reboot and enter Safe Mode (normally press F8 on startup, but key may vary between systems) Drivers can normally not conflict with eachother in Safe Mode, Next enter Device Manager through the control panel and find your tochpad or mouse drivers, typically they will be marked with a yellow warning triangle if they are improperly configured or conflicted, rightclick and select uninstall, scan for hardware changes and let it automatically reinstall the touchpad or mouse drivers.
If driver still not working, there may be old, hidden drivers, some systems may be able to show these by pressing view->show hidden drivers in the device manager, older systems typically windows XP will have to run cmd.exe and type in the following lines to show the 'ghost' drivers:
SET DEVMGR_SHOW_NONPRESENT_DEVICES=1
DEVMGMT.MSC
this will start up device manager with added parameter, you must still enable 'show hidden devices'.
Note: it is pretty safe to uninstall drivers under the sections:
Keyboards
Mice and other pointing devices
Monitors
Network Adapters
Sound, Video and Game controllers
Storage Volumes
Universal Serial Bus controllers
However, understand the risks of uninstalling and editing system components, if you do not have a way to restore your system to factory settings, or reinstall your system completely, of if you have important information stored on the computer, you should thread extra carefull- hope for the best but prepare for the worst.
Posted on May 26, 2010
I have a Compaq Presario f700, whenever I click on something it jumps to bottom of page. I click pg up, arrow key, side bar and it responds then goes to bottom again. It seems to be worse when I first turn...
sounds like your synaptic touch pad settings have been tampered with. make sure driver is installed the go into control panel and click on the synaptic touch pad and check the settings
May 24, 2011 | Computers & Internet
The cursor bounces around when I type, especially in Word. Do you know how I can correct this problem? I read that disabling the touch pad might remedy the problem; if so, how do you disable the touch...
As you type, your wrists could be close-enough to the touch-pad to move the mouse-pointer.
Click Start
Click Control Panel
Click Mouse
Change the setting to disable the touch-pad.
Dec 20, 2010 | Dell Latitude D610 Notebook
My computer comes on opens windows all looks ok as soon as i touch the cursor, nothing responds,
Make sure that the track-pad (mouse-pad) is not disabled. There should be a button located above the track-pad that allows you to disable or enable the track-pad. If not, I would use a USB mouse and then go into the Control Panel, mouse and change settings there to enable the track-pad.
Nov 08, 2010 | Acer Aspire 4720 Notebook
Sony vaio AR51E mouse cursor doers not move as touch pad not respoNding, EXTERNAL usb mouse works fine any ideas??
Go to Control Panel
SEE mouse icon... OPEN this
see if the touch pad is disabled
Try to go to the site Sony VAIO model specofic download latest driver for the touch pad
there are specific setting to enable the pad somehate it some love it but you can sort it out by looking at Control Panel /device manager etc
if USB mouse is working at least you can navigate to find issue
Jun 11, 2010 | Sony VAIO VGN-AR720E/B Notebook
Mouse arrow no respond & touch pad oso cannot respond
download driver max, it's free and will scan your pc for all hardware and update all drivers, but allow you to choose what and when so you can fix any bad drivers.
Aug 24, 2009 | Daewoo DVRS05 DVD Recorder/VCR
My touchpad mouse won't work. it does not respond
If you are using XP, check your mouse settings under Control Panel. Make sure that your Touch Pad is enabled. If it is but it still won't work, have a mouse plugged into a USB port that will work correctly. Then download the latest driver from the Acer site for your touchpad. Uninstall the driver that is currently being used by your system. Then install the updated driver that you downloaded. This should allow you to use your Touch Pad. If not, you may have to take your laptop in for servicing.
Jul 15, 2009 | Acer Aspire One PC Notebook
Netbook touch pad quit working after attaching a USB mouse
Go into the mouse options in the control panel and make sure that the touch pad is not disabled.
May 31, 2009 | ASUS Eee PC 900 Notebook
Do you unlock your mouse on a dell xps m1530
There is no way to check the touchpad settings. Either she has removed the touch pad driver, or she has changed the settings. See if you can find the dell touch pad icon on your system tray(circled in red in the picture below)
If you cant then connect an external mouse and download the driver from the link below
Click here
If you can see the touch pad icon in the system tray then you just need to change the settings. I have set mine at correct levels and posted a screenshot below
Set them to the levels shown above and you should be fine.
Let me know if you need more help.
Sai.
Apr 09, 2009 | Dell XPS M1530 Laptop
Touchpad is not working
You didn't mention an OS but the following is for Windows:
You may want to reinstall the touchpad driver for your unit. You may also want to check whether the touchpad is enabled under the mouse settings. Good luck!
Feb 24, 2009 | ASUS Computers & Internet
Toshiba satellite 1805 windows xp touchpad does not respond to one or two clicks although it does move the arrow around
Go into your controll pannel then click on mouse. On the mouse properties click on Touch Pad, then you can change the settings for sensitivity of the touch for double clicking with the touch pad.
Apr 28, 2008 | Computers & Internet
Dell Latitude D600 Notebook Logo
93 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
