Question about Sharp AL-1655CS Laser Printer
Black lines running vertically through resulting copies
Less than 60 days ago I replaced both the toner and drum units...now we are back to the original problem, distinct black lines running the entire lengeth of the finished copy.
  • 1 more comment
  • ventureruby Jun 05, 2008
    I have the same problem only when I feed through the RSPF
    Anne N
  • efb001 Oct 29, 2008
    I too have this problem (one vertical line) only when feeding throught RSPF. It is not on the glass since my other copies are fine.
  • Anonymous Jan 29, 2009
    I have the same problem. I happens every time when I print or copy. I replaced the toner but it is the same.
  • Sharp Master
  • 2,794 Answers
Clean the scanner glass. a small particle will cause this to happen.
Posted on Jun 06, 2008
Canon irc4580i print dark problem
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing ...
The common print quality problem Canon IRC-4580 printer
Currently, The Canon IRC-4580 is the laser printer have high speed, easy to use, friendly for user and printing clear text.
However, we can not avoid the damage of some components of the printer when used.
In this article, I will introduce some basic errors with printing quality problems of Canon IRC-4580 printer and "How to fix it".
After viewed artical, you know:
- How to fix (repair/solve) Vertical line (black or white) in Canon IRC-4580 printer
- How to fix (repair/solve) Poor fusing (loose toner) in Canon IRC-4580 printer
- How to fix (repair/solve) Uneven Density in Canon IRC-4580 printer
- How to fix (repair/solve) Light image in Canon IRC-4580 printer
- How to fix (repair/solve) Ghost in Canon IRC-4580 printer
1. Fix print quality problem "Vertical line" for Canon IRC-4580 printer How to fix print quality problem Vertical line
This plobrem "Vertical line" is usally error of Canon IRC-4580 printer. For this "Vertical line" error, technicians divided into two smaller error are: Vertical black line and band and Vertical white line.
Description:
- Vertical line and band: On the printed image appear some straight thin black vertical.
- Vertical white line: On the printed image appear some white vertical voids.
Error location:
- Surface of the charge roller
- OPC drum
- Cleaning blade
- LSU unit
- Developing roller
Cause of error "Vertical line" on the printed page:
- May be surface of charge roller scratched or dirty by toner powder.
- May be have some grooves on the OPC drum.
- May be cleaning blade is damaged.
- May be LSU window or LSU lense has dirty.
- May be surface of developing roller has scratched.
How to fix(repair) "Vertical black Line and Band" for {{SPkey1}} machine:
- Replace the charge roller of toner cartridge.
- Replace the OCP drum.
- Replace the cleaning blade
If printed page are not improved
- Clean the LSU unit by soft cotton cloth and try to print. If Vertical line is not clear on the printed page you should replace LSU unit.
- Replace new axis developer and try to print
2. Solve print quality problem "Poor fusing (loose toner)" for Canon IRC-4580 printer. How to fix print quality problem loose toner
Description loose toner: Toner is not properly fixed on paper, use to hand rubbing lightly on the printed image toner powder may be stick in hand
Error location: toner cartridge or fuser unit
Cause of error "Dark Image or black" on the printed page:
When toner cartridge is empty. You toner refilled by toner powder ware not compatible. This is makes toner cartridge components demaged and temperature of fuser unit is not enough melt to toner powder
How to fix(repair)"Poor fusing (loose toner)" on the printed page for Canon IRC-4580 printer:
With this error, you should replace toner cartridge or fuser unit to fix it.
3. How to fix print quality problem "Uneven Density" for Canon IRC-4580 printe How to fix print quality problem Uneven Density
Description: The printed page has one half light and one half clear.
Error location: Toner cartridge, transfer roller, springs, doctor blade
Cause of error "Uneven Density":
- The pressure force on the left and right springs of the transfer roller is not even.
- May be toner low also causes this error
- Doctor blade has bent
How to repair error "Uneven Density" on the printed page for Canon IRC-4580 printer:
- Replace springs and transfer roller.
- Toner refill toner cartridge Canon IRC-4580 and reset toner cartridge chip (replace new chip) or replace new genuine toner cartridge.
- Replace doctor blade.
4. How to solve print quality problem "Light image" for Canon IRC-4580 printer How to fix print quality problem light image
Description: The printed image is all light and no Ghost.
Error location: Toner cartridge, Developer, HVPS board
Cause of error "Light image" on the printed page
- Enabled toner save.
- Toner cartridge is low
- OPC drum may be faulty by strong light intensity
- Temperature in room is below than 10*C
- Bad contact caused by the toner dirty between the high voltage terminal in the HVPS and the one in the set
- Abnormalities output from the HVPS
How to fix(repair) error "Light image" on the printed page for Canon IRC-4580 printer:
- Disable toner save by change in printer driver.
- Replace the OPC drum.
- Replace developer.
- After printer is power on, wait 30 minutes then start printing
- Clean up the contact between the high voltage terminal in the HVPS and the one in the se- Replace the new HVPS if the problems are not solved by 4 away above.
5. How to fix print quality problem "Ghost" for Canon IRC-4580 printer How to fix print quality problem Ghost
Description: Ghost occurs intervals of the OPC drum or transfer roller.
- OPC drum has fauty.
- The life of the transfer roller has been expired
- The high voltage terminal is contaminated by toner powder or
- Replace OPC drum
- Replace transfer roller
- If performed 2 away and the error does not clear, you should replace ganuine toner cartridge .
- Replacce HVPS board.
Oct 29, 2016 | Canon Office Equipment & Supplies
Canon LBP 2410 Lazer Colour Printer -
Printing not dark enough or varied in darkness
If the print is a dismal gray rather than a sharp black, you are probably almost out of toner. This can manifest itself evenly across the entire page or in splotches or stripes, depending on the printer.
Sometimes you can wring a little bit more out of a toner cartridge by taking it out and gently shaking it from side to side (never up and down, as toner can spill out). You can also try turning up the printer’s contrast adjustment, if it has such a knob (usually on the back side if it exists). Faded print can also result from a dirty corona wire, because a dirty wire inhibits a full electrical charge from being passed.
If the printouts are consistently varied in density, and you have to frequently remove the toner cartridge and shake it to redistribute the toner inside it, make sure the printer is sitting on an even, flat surface.
Horizontal black lines
A horizontal black line on the printout is probably the result of a dirty or damaged roller. There are lots of rollers in the printer, and you can use the space between the lines on the page to determine which roller is causing the problem. Measure the distance between the errant black lines on the page and then use Table A to determine which part might be causing the problem. Table A
Distance between lines
Faulty part
0.5”
Registration assembly
1.5”
Upper registration roller
1.75”
Lower registration roller
2.0”
Toner cartridge developer roller
2.56”
Lower fusing assembly roller
3.16”
Upper fusing assembly roller
3.75”
Toner cartridge photo drum
Regularly spaced splotches
If there are evenly spaced black spots but they don’t extend all the way across the page, the problem is probably a scratch or flaw in the drum or a build-up of toner on the fusing roller. If the spots are less than three inches apart vertically, it’s probably the drum, because the drum has a larger diameter than the fusing roller.
Vertical black line on edge of page
This can indicate an almost empty or faulty toner cartridge or (less frequently) some spilled toner inside the printer.
Jun 07, 2008 | Canon Office Equipment & Supplies
Tip
When u print if u r getting the Horizontal or vertical line then follow these...
Faulty part
0.5”
1.5”
1.75”
2.0”
2.56”
3.16”
3.75”
on Aug 28, 2008 | Lexmark X5470 All-In-One InkJet Printer
Canon 2016, vertical black lines.Print and copy, not always
Dear. first change the drum cleaning blade and clean the waste toner from the drum unit safely and then try to copy if the black lines still appears then change the drum then it must solve the issue , If still the problem comes then check the laser unit if there is anything which produce the black lines on the pages.
Aug 14, 2013 | Canon imageRUNNER 2016 All-In-One Laser...
Black Vertical Lines
This can be caused by a damaged fuser or drum try to change the cartridge and if that does not resolved the issue then its the fuser
Mar 27, 2009 | Sharp FO DC500 Plain Paper Laser Fax
Black Streaks
pull drum unit out and clean corona wire by sliding blue plastic tab from side to side, making sure you put the tab back on the side that it was. if that doesn't take care of problem, then i would say you need a new drum unit.
razors
Jan 27, 2009 | Brother MFC-8440 All-In-One Laser Printer
Lanier 5622 Prints vertical lines
You could remove the color and black&white drum units and check from below the units to visually observe lines on all the 4 drums. If so, you have to change the drum unit/units. Drums occassionally get damaged before life this way due to solid toner particles inside the toner bottle.Always "shake the toners very well" before replacement, and if you print rarely, then remove the toners and do the shaking to prevent clogging due to inactivity.
Aug 28, 2008 | Ricoh CL4000DN Laser Printer
Bad copy quality on my brother MFC-9600. I have replaced the drum unit and still have vertical lines on the copy
Its not the drum,,, the toner cartridge has the black line pathc on the photosynthetic drum and that is causing the problem. check it by taking it out and roll the drum using your finger you will notice the vertical black patch. Get the toner replaced
May 30, 2008 | Brother Office Equipment & Supplies
POOR COPY QUALITY
Here is the scoop! There are two (2) components to the fax machine, one is the scanner portion which is located just past where the paper you are copying or faxing enters the machine, separate the two sides and access the imaging plate, clean this area with denatured alcohol.
Step two is to clean the toner and drum unit, get the mirror at the back of the toner and under the toner. If after this you are still getting lines on the prints you will have to replace the drum unit KX FA-84 about $85. Happy faxing, Ken
May 15, 2008 | Office Equipment & Supplies
Sharp AL-1655CS Laser Printer Logo
133 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
