Question about Maytag MDB7100AWB Dishwasher
Want to replace the door on Kitchenaid dishwasher
I have a Kitchenaid dishwasher, model KUDP02CRBT0 in biscuit and want to change the door to black to match my other new appliances. I've looked online and see the panel, but do I need to order separately the toe panel, overlay and handle or is there a kit I can get that has everything I need to change the color of the front. Thanx to anyone that can help me on this!
marsha
    Champion:
  • 246 Answers
Definitely, check out www.applianceart.com - they have alot of black options
Posted on Jun 01, 2010
Can I purchase a new door (color change) for my KitchenAid dishwasher?
Yes. Go to Searspartsdirect.com and enter the model number. If other color panels are available it might list them in the parts list. If not, you have to figure out the model number of the same dishwasher in the color you want.
Aug 26, 2014 | KitchenAid Dishwashers
KitchenAid Dishwasher Model KUDS24SEAL F Leaking out front door panel
It's a little tedious. But normally do able for a do it yourselfer.
Mar 17, 2014 | KitchenAid Dishwashers
I found some black plastic under the dishwasher and then found some more... it appears to be long as if it was the seal or something across the bottom of the door. Can you tell me what it is and what I...
Its hard to tell from the description what it is. Does it like item #4 in first link OR item #31 in second link. If it is item #31 in second link its soundproofing insulation that attaches to kick plate and has come loose,a couple dabs of super glue would reattach it to kickplate
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Dishwasher-Parts/Model-KUDS30IVWH3/0593/0130000/W1005148/00003?blt=06&prst=&shdMod= item #4
http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Dishwasher-Parts/Model-KUDS30IVWH3/0593/0130000/W1005148/00005?blt=06&prst=&shdMod= item #31
If it is item 4 thatsa seal on bottom of door and needs to be there to prevent leaks
Gene
Aug 13, 2011 | KitchenAid KUDS30IVWH Builtin Dishwasher
The handle opener on my my Kitchenaid whisperquiet dishwasher is completely loose and I can't open the dishwasher to remove my clean dishes. What can I do???
The idea is to lift up on the part of the latch that is fixed to the body of the washer. The door part of the latch slides under this peice. If the handle mechanism is broken, it will not depres the door part of the latch to allow it to open. therefore, we have to pickup the latch part fixed to the body.
To get the door open, take a clothes hanger and cut off a 12" peice with a pair of pliers. Bend the last 1.25" at 90 degress angle. Make another bend about 4 " from that to make another 90 degree angle. This will give you leverage. Insert the first bent end between the top of the door and the counter. Rotate it so that the end is facing down. Feel for a metal plate. When you hit the plate with the probe, turn your hanger so that it lifts up the plate and simultaneously pull on the door handle. The door should come open.
Now you have to get the handle repaired, but at least you know how to open the door.
Oct 25, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Hello -- We own one of these KitchenAid dishwashers. Our model has a black exterior. We are thinking of re-doing parts of our kitchen. Is it possible to change the color of the main front panel? (Not the...
YES THIS IS POSSIBLE IF YOU ENTER YOUR FULL MODEL NUMBER ( YOU ARE MISSING SOME OF THE NUMBER) ON THE SEARS SITE THE ILLISTRATED PARTS BREAK DOWN WILL GIVE YOU CHOICES OF COLOR.
Apr 25, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
Is there a replacement door for a Kitchenaid kudi01tjwh0 dishwasher made of stainless steel? Maybe another model with the same size/layout of the door?
Applianceart.com has stainless steel options for door panels as well as a faux stainless steel that was on HGTV. I'm not sure if the panels they have would fit your model, but their rolls of stainless would definitely help.
Nov 24, 2009 | KitchenAid 24 in. KUDI01TJ - Multiple...
Are white front door dishwasher replacement panels available?
yes but you would be better of removing panel and taking it to your nearest powdercoater may be cheaper cheers
Nov 05, 2009 | Dishwashers
Need to replace stainless steel outer door something etched in stainless will not come out on kitchenaid dishwasher
I'm not sure if they have the solution for your model but applianceart.com has faux stainless covers and they sell stainless dishwasher door panels.
Oct 17, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Where can I buy the cable repair kit for my Kitchenaid dishwasher
OK, pretty easy fix. Look at diagram 10 here: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164885
The link (#24) probably broke and the spring (#18) probably shot off and is lying somewhere behind the dishwasher. Just pull out the dishwasher (careful not to disconnect or crimp any of the hoses) and check to see if both springs (one on each side) can be located. Just replace the old links and re-hook the springs and all should be well.
You can order the link replacement (part #8194001) from kitchenaid at 1-800-422-1230.
Jan 19, 2009 | KitchenAid 24 in. KUDP01DLBS Free-standing...
Maytag MDB7100AWB Dishwasher Logo
339 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
