The fan is not blowing air but the power is coming on
  • 901 Answers
Check fan rely, fan motor, fan capacitor.
Posted on May 27, 2010
1977 Buick blower / fan comes on however NO heat blower / fan also blows very low.
Buick LeSabre Heater - RepairPal
repairpal.com > Problems > Buick > LeSabre
Buick LeSabre Heater blows only cool air...even w/ defroster on. This is a ... Heater fandoesn't come on . ... The blower works but there is no heat coming out.
Blower Motor Problems ' Auto Repair Help - YouTube
? 4:22
https://www.youtube.com/watch?v=2vmfxYg8LoY
Sep 27, 2009 - Uploaded by mgittelman
The blower motor is a common heater/AC repair within the skill level of ... However if the power wire is a single light purple wire and the ... for blower motor and fuel and relay good but no powercoming on both any ideas? ... my o5 seira, when i start the engine with the air switch on it blows my blower fan ...
Car Air Not Blowing, Heat & Air "How to" Test Testing ...
? 6:22
https://www.youtube.com/watch?v=hgar6Q1lV6A
Apr 5, 2013 - Uploaded by Fixbook
Here I show how to determine the problem if your air, or blowermotor is not ... Click here to check out the the "Car Runs on 2 cylinders" series: ... How to Fix Over-Heating engine & No Heat in car - Buick (2000 yr) Park Ave . ... Car fan / AC only works on high - Replacing the Blower Resistor - Duration: 4:24.
Buick Park Avenue Questions - NO HEAT!!! - CarGurus
Jan 30, 2016 | 1977 Buick Electra
My 2002 trane XE 1200 gas &electric unit stopped blowing air
it may be the blower motor not working inside the house check the cap for the motor & the power to the motor
Apr 28, 2014 | Heating & Cooling
My air handler fan does not come on, the outside unit turns on fine. Is their a way to reset the fan?
Check for fan operation by turning the fan control at the thermostat to "on". If the fan blows, it works. If not, check a circuit breaker or fuse.
If the fan blows when forcing it on with the thermostat but not in automatic, check the fan control circuit in the air handler. Danger: high voltage, beware! There should be a system wiring diagram inside the air handler somewhere.
Mar 30, 2014 | Rheem 4 Ton Air Handler - RHLLHM4821JA
Air Conditioner fan problem. AC fan very noisy and doesn't blow with full power
bushing in motor is probably shot,or some critter put it's nest in there ,either way the motor has to come out.
Jan 11, 2012 | 2003 Chevrolet Malibu
It turn on , revolve but no air comes out
I am having the same problem. Did you ever fix your fan?
Aug 29, 2010 | Lasko 48" Xtra Air Tower Fan with Air...
My Home Ac Unit Is Not Blowing Any Air
This sounds like the fan not turning during cool. You will have to check the fan relay for power during the cool cycle. The fan relay is run by the low voltage side, but still there is hi voltage present. When in heat the power goes thru the relay on one set of points then in cool goes thru the opposite side. You should have a digram present, and then on the main circuit board there is a code light. Check the light for blinking or (flash) read the bottom of the board for the code ( very small print)
May 17, 2010 | Goodman CKL24AR24 Air Conditioner
Blower/Switch Problem with Air Flow?
The extra air flow most likely turns the fan motor, check the fuses, check the fan motor switch for power if O.K. check the fan motor for power..
Aug 15, 2009 | 2002 Isuzu Rodeo
Air Conditioner no longer blows
Is the fan blower getting power to it? Check the blower motor fuse to see if its blown.
Aug 06, 2009 | 2000 Acura TL
Fan motor
have u checked the capacitor for the fan if might be damaged, is the fan getting power i.e 120 vac or 220vac
Aug 02, 2009 | Comfort-Aire RAD-81 Air Conditioner
Gateway 340UI Overheat
Well, I can tell you this. With most laptops the fans **** in air and blow it into some copper fins. These fins are very close together so dust and dirt clog the the air flow over the fins. Try this, get some canned air and go outside. Look for the copper fins (should be where hot air use to come out). Use the air to blow out the dust. Also blow air into the fans. Good luck.
Jun 23, 2009 | Computers & Internet
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
