Question about Jenn-Air Dishwashers
Our jenn air jdb1095aws dishwasher won't turn on. None of the buttons across the panel work.
  • 13433 Answers
SOURCE: Whirlpool Quiet Plus Dishwasher
If your dishwasher doesn't work at all, check these:'
Power from the house Is there power getting to the dishwasher? This can be difficult to test, because dishwashers are usually wired directly to an electrical circuit, rather than plugged into the wall. But at least check for a blown fuse or a tripped circuit breaker.
Door switch The door switch is important because, if it's defective, the dishwasher won't work at all. To reach it, you need to remove the control panel cover, or sometimes the interior liner of the door. If it's defective, you need to completely replace it.
Wiring Often the main wiring connection from the house, at the dishwasher, burns and breaks the connection. If that's the problem, the wires must be repaired/replaced as necessary. If that's not the problem, check the wiring to the door switch, the wiring between the door and the lower part of the dishwasher, and the wiring to the timer. Repair any broken, burned, brittle, or defective wiring, using the proper appliance-grade wire and connectors.
Timer or selector switch Although it's uncommon, the timer or the selector switch may be defective. If so, you need to replace the defective part, because neither of these can be repaired.
Posted on Oct 27, 2008
  • 111 Answers
SOURCE: Buttons won't work on GE Profile PDW7980N10SS
You have the control lock activated. Press and hold the heated dry pad for 5 seconds and it should unlock it
Posted on Dec 18, 2008
SOURCE: Frigadaire Dishwasher PADLOCK Icon lit, dishwasher won;t run
I have an FDB1502RGB0 model but had the same problem. I reset the circuit breaker and its working fine now. I'm not sure what caused the problem but it seems to be fine now.
Posted on Feb 11, 2009
  • 22 Answers
SOURCE: Jenn Air dishwasher leaking
the emptying valve is underneath in the middle normally and it is what the drain hose connects to on the dishwasher. The drain hose itself is connecting with either a c clamp or hose clamp, check to make sure it is tightened all the way. Also do you have an idea of what part of the dishwasher the leak is coming from? If it is not the drain valve, then check to make sure it is not leaking from the door itself, as the door just has a rubber gasket that seals it and it might be that the gasket is bad. If it's not the door and not the drain valve, it could then be coming from the drainage pump or the motor for the dishwasher, which means the seal is broken and the motor or pump would need replaced. If you are unsure of how to do so then i would contact a repair technician to fix it for you.
Posted on Jul 19, 2009
SOURCE: Maytag Jetclean Dishwasher EQ Plus - Lights flashing
either the control board or the control panel needs replacement. Most likely the latter. There is a possibility that both parts failed also. Usually water gets inside the touchpad, corroding and shorting the touchpad. Good luck
Posted on Mar 03, 2010
We have replaced our control panel PN 99003139, THREE times. Each time same thing happens. The lights and buttons gradually and intermittently go out. The dish washer will still run, so long as the st
Whirlpool parts come with a one year warranty WP owns Jenn Air take it back I have replaced this panel then had to go back and change again in 3 days it failed yes could be a bad batch of panels the panel is powered by the control is the control taking out the panel can't say it is a computer maybe sending to high a voltage to panel no way to test that
Jan 30, 2015 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Door opens beyond horizontal hitting floor
There may be a second mounting hole on the hinge to reposition the spring but more than likley you have broken door cables
Mar 05, 2014 | Jenn-Air JDB1095AW Built-in Dishwasher
Dishwasher won' t start. None of the lights are coming on
dishwasher wont start. none of the lights are coming on.
Nov 09, 2012 | Jenn-Air 24 in. JDB1080AWS Built-in...
Dishwasher displaying L# what do I do??
press start and light will not come on and start
jenn-air dishwasher jdb-5
Nov 14, 2010 | Jenn-Air JDB1095AW Built-in Dishwasher
What is the best product to use to clean the outside of my dishwasher. It is stainless steele..We bought this from someone who had stored it new for a ;year in his garage. There are some dirty spots and...
Mineral oil or baby oil on a soft cloth is very effective. A basic spray on furniture polish can be used but make sure it's wax-free and not coloured.
Test a small area at the side or back - anywhere that wont be seen - before attempting the front.
Oct 16, 2010 | Jenn-Air JDB1095AW Built-in Dishwasher
Same thing happened today
with the door open when your dishwasher was working normally Did the lights light up on the keypad? I am wondering because if the answer is the keypad only worked with the door closed .....you possibly have a bad door switch.
or it could be a blown fuse inside the dishwasher. are any lights on at all?
Jun 12, 2009 | Jenn-Air 24 in. JDB1100AWS Built-in...
We own a Jenn-Air JDB7900. This morning the
More then likely the washer control panel has failed.
Apr 24, 2017 | Jenn-Air 24 in. JDB7900 Built-in...
Dishwashers Logo
120 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
