Question about Electrolux Ovens
Error E25 on electrolux electrical oven Model ESOPMSS I plug it in. Time appears ok. When I turned it on it said OFF and then quickly E25 I used to have troubles with pyrolitic mode. Door got stuck with error E05. Open oven, fixed it but now E25
  • claudou590 Jan 18, 2012
    bought a door lock and tried with no luck.
    found out that e error could be related to the citcuit loop. guessed the more li kely cause of failure in oven is the thermal sensor especially electrlux.
    decided to give it a try before buying a new oven!! my luck everything worked perfect after
    thanks for all inputs in various threads
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error E25 means a stuck door latch/switch, to start with check the door latch and door switch. To resolve this error you’ll have to replace the door lock mechanism. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 26, 2010
How do you set the clock on the Electrolux cooker?
You didn't specified the model of the oven so it is possible to set in a different way. There are several kinds of timer (with tree, four, five and six buttons) depending on the model of the oven. Here is explained how to set clock on the most common oven timer with three buttons.
First of all, the oven only operates when the time has been set.
When the appliance has been connected to the electrical supply or when there has been a power cut, the function indicator Time flashes automatically.
1. To change the time that has already repeatedly, until the function indicator Time flashes.
2. Set the current time using the "+" or "-" button.
After approx. 5 seconds, the flashing stops and the clock displays the time of day set. The appliance is now ready to use.
Dado
Mar 18, 2015 | Electrolux Ovens
Electrolux EOB 6632 oven trips main house circuit breaker if used above 180c. Installation electrician has done whole house test, says everything normal, must just be a particularly sensitive ciecuit...
Hi, welcome to FixYa! my name is Shaun. I hope i can help you out with your question. Your main house breaker is tripping over 180C because of the amount of current your oven is drawing. Keep in mind that an oven is capable of pulling up to 1/4 the amount of amperage of your total house current capacity, up to 50 Amps. This is assuming you have a typical 200 Amp main breaker. Add this in with your heating/air-conditioning, up to 30A, if electric, your water heater, 25 A if electric, and whatever lights and appliances you have plugged in and turned on, you can imagine how quickly those amps add up when your oven is on. Your oven breaker won't trip because you're not exceeding 50A on that circuit, however if your total household load is exceeding 200A, your main will trip. Also, breakers lose efficiency over time. Sometimes they can drop current capacity by as much as 25%. So your best bet is to replace your house main and see if that fixes your problem. Hope this helps out. Have a good day!
May 05, 2011 | Electrolux EOB6632 Electric Single Oven
EOU6330 grill doesn't heat-up all the time.
hi Step 1: Check the power cord, the plug, and the outlet. Then look for blown fuses or tripped circuit breakers at the main entrance panel or at a separate panel.
Step 2: If the range is receiving power, set the timer on the range to the MANUAL position.
Step 3: If the element still doesn't heat, turn off the power to the range and test it with a VOM set to the RX1 scale thank u................
Sep 11, 2008 | Electrolux EOU6330 Electric Double Oven
HI, MY ELECTROLUX SINGLE FAN OVEN EBO5665 DOES NOT HEAT UP TO ANY TEMP. THE OVEN IS ON, FAN ON,AND THE TIMER DIALS ARE SET. DOESNT HEAT UP. IT TRIPPED THE ELECTRIC SWITCH OFF AT THE TIME. ANY SUGGESTIONS!...
You probably have a bad ( or open ) heating element.. With the power removed.. look at the heating element and make sure it is connected properly and if after you check that it looks ok.. plug it in and try again.. if it fails to get hot..its probably bad.. Not sure what you mean when you say ' IT TRIPPED THE ELECTRIC SWITCH OFF AT THE TIME' but if it tripped the switch or circuit breaker .. your heating element may be shorting out to ground.. and would need to be replaced anyway... Hope that helps.
Aug 22, 2008 | Electrolux EOB5600 Ultrafan Electric...
Electrolux oven wont heat up after power cut
hiya
sounds like the fan element could have blown, causing the electrics to trip out. best thing to do is remove all the racking
and then the rear panel that covers the fan and element. if he element has blown most of the time it will be visible.
hope this helps
please dont forget to rate the helpfulness of this reply thanks kj
Aug 03, 2008 | Electrolux EOB6636X Ultrafan Electric...
Electrolux Icon Mystery issue
Check to be sure your racks are all slid in to the back. Are you getting a error code?
Dec 14, 2007 | Electrolux ICON Designer E30SO75ESS Oven
Oven not working
is this a gas oven or electric?
Oct 24, 2006 | Electrolux EOD5310 Electric Double Oven
Ovens Logo
138 people viewed this question
Top Electrolux Ovens Experts
ashburton
John Tripp
John Tripp
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
