Question about Toshiba E-Studio 310c Laser Printer
I have a toshiba e-dtudi 310c and when I turn it on it goes into the warm up mode and that is all it does. It does not go into the staring runing cycle and it does not get ready at all, all it says "wait warming up" What could be the problem please?
  • 493 Answers
Did you wait for a while to complete warming. It may take time.
If it doesn't start at all please make sure all the cables are in connection.
It means that the fuser isn't warming up. It could be a bad fusing assembly, or you might need a new power supply.
Let me check the other options if it continues that message.
Waiting your comments.
Posted on May 26, 2010
  • 2 more comments
  • Ibrahim OKTAY
    Ibrahim OKTAY May 26, 2010
    You may also check the paper jam if there is any paper inside the printer.
    (Maybe warming phase doesn't get to complete because of a paper jam which prevents the sensor to work, etc.).
    Hope this helps.
  • Ibrahim OKTAY
    And another simple test for solution.
    - Would you please un-install and reinstall the updated printer driver compatible to your operating system?
    - You would also have to have adequate power supplied to the central location. PC's will run on a low AC voltage, but printers might not be as forgiving. Try to plug in the printer in to another outlet.
    ioktay
  • premiercopie May 26, 2010
    I am a copier tech for 20 years and I come to you as a last resource. everything you are saying I have alredy checked I have even tried the hard drive but still not able to solve the problem.
  • Ibrahim OKTAY
    - There must be fuser sensors inside the printer. Please check and try to replace if they didn't work. As a technician, it might be easy to find and to check the sensors for you.
    - And try to understand whether the rollers are trying to turn. If something blocks the rollers or if any small part is broken inside the printer, it may cause that problem. the printer may not be able to initialize (can not complete the warming session) .
    - You may try to reset the printer (from the printer menu if works or look for a tiny button to reset it or check its manual how to reset even to its factory default).
    Hope this helps.
07 Nissan Titan blows cold when ac on then after an hour it so it blows warm when I turn the ac off for approx 5 minutes and turn on the it's cold again. On long trips in AZ ac is a must. Help!?
When it starts runing warm check to see if the compressor clutch is engaged and turning the compressor.. Check for lines freezing up.. look for ice where the line(Pipe) GOES THROUGH THE FIREWALL into the evap housing. There is a relay that turns the compressor clutch off at certain times (to save fuel) .. possibly this is malfunctioning.
Jul 20, 2014 | Cars & Trucks
Why is my toshiba e studio 350 staying in warming up mode
Possibly bad hard drive if copier stays in warm up mode.
Jun 24, 2014 | Toshiba e-Studio 350 Copier
Hoshizaki water dont stop runing
float switch is stuck in the "down" position. The unit goes thru a fill cycle and after 1 minute, the board "Looks" at the float swith to "see" if the sump is full. If float is stuck down, it tells the board that the unit does not have enough water and stays in the fill cycle. The compressor will not come on as long as the machine "thinks" there is not enough water. let me know if I can help further
Aug 02, 2012 | Hoshizaki Freezer Commercial Ice Machines...
We just installed a wireless router and now our computers are not able to print on the copier?
Check the IP-address that the new router assigned to the networked printer/copier.
If it has changed, then each computer needs to be reconfigured to connect to the "new" IP-address.
Jan 05, 2011 | Toshiba E-Studio 310c Laser Printer
I hear knocking when motor runing
WHEN COLD THEN GOES AWAY WHEN WARM. THATS NORMAL FORGED PISTONS SLOP WHEN COLD.I HAVE 01 SILVERADO WITH 390,000 RUNS GREAT 21MPG 40TO50 PSI OIL PRESSURE KNOCKS WHEN COLD THEN GOES AWAY. NOT A PROBLEM. IF IT DOSE IT WHEN WARM AND LOW OIL PRESSURE WORN BEARINGS NOT GOOD.
Jan 26, 2010 | 2003 Chevrolet Silverado 1500
Toshiba E-Studio 310c Laser Printer Logo
75 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
