Question about Yamaha RX-V2700 Receiver
Only get low volume out of sbr and sr speakers.
  • bhayek May 27, 2010
    All are same anthony acoustic aDivas
  • 21 Answers
Without knowing what your speaker arrangement is I could not give any definite answer, but it could be caused by using speakers of differing efficiencies or impedance.
Posted on May 26, 2010
  • Raymond Thomson May 27, 2010
    OK, so all speakers have the same characteristics. My next suggestion would be to swap the front speakers with a pair that have low volume and see if that makes a difference. Assuming that it does not change, you can reset everything to the initial factory settings. The instructions for this may be found on page 149 ot the users manual.
No sound from Surround Back Right (SBR).
Bad wire, bad speaker or bad channel. Disconnect the wire from the amp. Using a 1.5v battery touch the wires to the battery briefly. You should get a pop from the speaker. If not get a different piece of wire and use it instead of the regular wire. If still no pop then the speaker is bad.
Aug 17, 2016 | Pioneer VSX921K 71 Channels Receiver
Denon problems
I'm not familiar with your unit. However, go to systems surround set up and turn up volume for those surround speakers you speak of.
Mar 22, 2014 | Audio Players & Recorders
Marantz SR-7200 volume -29dB blinking
Check Speaker connections at BOTH ends and double check to see that they are on the right terminals.
If you need a manual . the Marantz site will have one . PLus they may have FAQ notes for that receiver
Cheers
Mar 01, 2014 | Marantz SR-7200 Receiver
Low volume
If it's a new TV, then it might just be as high as it goes. A lot of HDTVs don't come with great speakers due to the small flat feature of the TV not allowing anything better.
You will have to get external speakers for the TV to experience better sound.
Here is a great sound bar that is well priced. http://www.amazon.com/Vizio-VSB205-32-Inch-Theater-Soundbar/dp/B004VGI2EK/ref=sr_1_2?ie=UTF8&qid=1359416740&sr=8-2&keywords=32+inch+sound+bar
I've personally heard that sound bar and they are surprisingly loud and hardly take up any room at all.
Jan 28, 2013 | Polaroid TLA-01511C 15 in. LCD Television
I have bose 901 series 2 speakers, marantz 8200 and 2 marantz ma700 monoblock amps how do i hook everything up? Thankd
Do you mean SR-8200? You can't omit the details of a model number if you want a good answer.
Assuming it is...
http://www.retrevo.com/support/Marantz-SR8200-Receivers-manual/id/511ci775/t/2/
Run the 901's with the Active EQ between the receiver Front L and R Pre-Outputs and the mono block amps, one chanel to each.
Pre Out Channel X >>> Bose EQ Amplifer IN, then Bose EQ Amplier OUT >>> Monoblock IN
http://community.klipsch.com/forums/storage/74/1341919/200w%20mono%2005.jpg
I can't find a manual for the MA700. Set them up to a certain volume and then use the speaker setup routines of the SR to match everything up volume-wise. Control will be in the AVR.
Aug 22, 2011 | Bose 901 VI Main / Stereo Speaker
How do i turn up my back speakers?
Grab the remote for your vsx1018 and press receiver at the bottom of the remote then press the number zero button (this button acts as the channel level function when remote is in receiver mode) you will then notice that if you repeatedly press the zero button that it will cycle through each channel on the vsx1018 display (L for front left, C for center, R for front right, SR for side right, SBR for sarround back right, SBL for sarround back left, SL for side left, and last but not least SW for subwoofer rca jack output to your sub amp. After you have selected the speaker volume you want change ( SBR and SBL in your case) then push the left or right of the circle that sarrounds the enter button on the remote in order the fine tune the volume for each speaker,and after you are finished setting the volume the way you want then push the return button that is to the lower right of the circle that sarrounds the enter button on the remote. Cool huh!! :-) Oh ya, somthing else that is cool about the vsx1018, you can put music from your computer onto a thumb drive and then plug the thumb drive in the the ipod usb and the music will play!! IE press ipod button on remote and then use the circle to change music tracks.
Aug 29, 2010 | Pioneer VSX-1018AH-K Receiver
Receiver Sr5200 shut down in 5.1 mode
chances are you have the volume too loud and the speaker wires are crossed.
all speaker wires need to be with the positive on the right and negative on the left if you have them anywhichway than it will work on low volume and not a very good sound.
look closely at the wires and they should have a red or so color on one side or the wire jacket itself will have a round side and a flat side
Apr 21, 2009 | Marantz SR-5200 Receiver
Sound coming out of speakers in spurts
speaker volume spinner i.e which is use to increase n decrease the volumn is not working and it has a ball in the end.
if you slowly turn the volume controller nob probably u will get clear sound at one point.
Apr 01, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Onkyo ht-r530 Receiver troubleshooting
the 7.1 sound not all the movies has that feature and u need to emulate it, doit in the dolby digital ex and the speakers must sound.
try the volume for the SBL or SBL maybe are to low.
decrease the volume for all the speaker less the SBL, SBR and check it out.
Good Luck
Jan 12, 2009 | Onkyo Audio Players & Recorders
Yamaha RX-V2700 Receiver Logo
107 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
