Question about GE Nautilus 24" Built-in Dishwasher
DISHWASHER PROBLEM HI, Last night I ran the dishwasher down in our kitchen down stairs. Four hour later I heard a humming sound coming from down there. I noticed the dishwasher went through the cycle perfectly , except on the hot drying cycle the timer knob was stuck and won't budge. I cannot move it either way. So I just unlatched it. Want do you think happened?
  • WOODALYN Apr 07, 2008
    I do not have a digital diplay. There is buttons, they are flat with a plastic clear coated . then there is dial for the cycles. thank you for a quick response.
  • 4,889 Answers
Do you see any error message on the display?
Posted on Apr 07, 2008
    Genius:
  • 3,422 Answers
HI,
A humming or grinding sound may indicate debris is jamming the motor and pump assembly. Check the inside for debris from broken dishes or glass. Carefully remove any broken dish debris. If the grinding sound continues, debris may have entered the circulation pump. This requires an authorized servicer to correct.
Goodluck,
Please don't forget to rate the solution..
  • 655 Answers
This looks like a physical damaged you should call your service centre to get it serviced.
Thanks
Iqbal
Dishwasher hums but does not start
sounds like the pump is shot.
Feb 08, 2018 | Maytag Dishwashers
Dishwasher starts then pauses and drains.
Fixed! I had the issue where the cycle would start, the KUDS30IXBL8 would hum 4-5 times and then drain. Plastic folk pieces jammed in the disposer. These instructions took a few minutes (only 5 screws and a couple clips) to figure out how to take it apart, and it only took 60 seconds to put back together. How To Repair Dishwashers KitchenAid Repair Chopper Replacement
Apr 25, 2012 | KitchenAid Dishwashers
When you turn the Dishwasher on all you hear is a hum. No water is entering the machine.
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
May 15, 2011 | Kitchen Ranges
F1 Error code
Hello, here is link to F&P repair video. This video explains how to repair a F1 error code and replace the rotor
http://www.appliancerepairlesson.com/shop/dishwasher-videos/fisher-paykel-dishwasher-repair/
Dec 10, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Kitchen Aid dishwasher will not start
Can not start KitchenAid dishwasher..."child lock" light keeps coming on. Help!
Aug 24, 2009 | KitchenAid Dishwashers
New Danby dishwasher - no water flowing into it
it sounds like the shut off valve has failed and not letting water into the unit, change the valve and it should work, even if it turns like it is working doesn't mean the washer isn't stuck keeping water from comming thru
May 26, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Dishwasher runs for 3 hours
Are you using the high wash temp setting? I was having the same problem with my dishwasher while using that setting. Apparently, it will run until the temp gets to its required number. And my hot water heater was set to not go that far. So my dishwasher would run and run. I fixed it by not using that setting any more.
Aug 14, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Kenwood Slimline Dishwasher KDW8ST2A
I have a Kenwood Kdw8st2a and have been constantly plagued by the E4 overfill error.
Lifting the front of the dishwasher and tilting it backwards seemed to clear the E4 error only for it to come back after the next wash.
I found eventually that the connection to the U bend under the sink was too narrow and was almost blocked hence the dishwasher was not emptying properly.
I disconnected the dishwasher waste pipe and ran the waste into a bucket for about 6 cycles and it worked fine.
Eventually drilled through the kitchen wall and fitted a lower direct waste pipe to the drain. Overkill maybe buit it hasn't done an E4 since.
May 21, 2008 | Dishwashers
Dishwaster Viking VUD141
The floatswich down the bottom tray has aktiwated there must be a leak,(.water in the tray)
whether, upper conection nut between chamber and hose circulationpump .I had tha problem.
Greetings Frank
from Germany
Apr 30, 2008 | Viking 24 in. Professional Series VUD141...
Ultra Wash
Sounds like your not getting water to it. Turn on and let run for a few minutes then open door and check to see if you have water in it.
If not check to be sure water to it is turned on. Check float in front corner of dishwasher to see if moves freely up and down and that there is nothing underneath it. If these check ok you probably need a water valve.
Nov 03, 2007 | Kenmore 24 in. 15689 Built-in Dishwasher
GE Nautilus 24" Built-in Dishwasher Logo
323 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
