Question about Coleman Mach III Air Conditioner
It runs cold briefly for about 4 to 5 minutes then
I have a Coleman air conditioner mounted on top of my cruiser, model 6759C707. It hasn't been used much in the past few years. It runs cold briefly for about 4 to 5 minutes then stops and the breaker panel trips. It sounds like the pressure builds and then it stops. It runs good and cold, I am thinking that there may be a rusty electrical connector for a pressure relay inside the cover that is corroded that I am going to check for. The fan blows good without AC an runs a long time. Could you tell me what to look for?
Thanks,
Harvey
  • 901 Answers
Check the compressor capacitor. It would have gone weak. Replace with the identical value and type.
Posted on May 27, 2010
I have a split system air conditioner that quit blowing cold air
either the compressor is not running or you have a leak and are low on freon. the outside fan running does not tell you the compressor is running.
Jun 18, 2014 | Coleman Outdoor Split System Air...
I have a 2010 30' cougar travel trailer, we have never used the air conditioner which is a coleman mach model, when I put it on auto and cool it blows cool air but never gets cold am I suposed to
Check the temperature of the air coming out the vent If it's more than 10 degrees below the air going in it's ok. If it's the same temperature, the condensing system may be not working. The compressor may just be a quiet one!
May 18, 2012 | Coleman Mach III Air Conditioner
Coleman mach 6759C707 quit on us, only the fan is running. What do i need to replace? The compressor? WHat part number?
my coleman 7330 fan only runs when ac unit is on and then sometimes shuts off and then restarts
Aug 18, 2011 | Coleman Mach III Air Conditioner
I have a coleman roof top a/c with no wall thermostat. can i put one on it? not sure which model i have. are thre some models which a thermostat cannot be installed on?
Yes, you can put a thermostat. Doesn't it have a cold/hot selector? The fan may still run when you turn it to warmer, but it limits how much the compressor kicks on and off. You will need to go to an electrical supply and tell them what you are doing, and whether or not they recommend you use a relay or wire into the one already in the unit.
Jul 11, 2010 | Coleman Mach 15 Air Conditioner
My coleman 13,500 roof a/c year 2000 does not blow as cold as used to. I have cleaned the top condenser coils, with no help. It also at times will seem to pull a heavy load when I assume the compressor...
if the compressor started and stoped means
1 thermostat need settings
2 compressor over heated due to low suction pressure need to check and repair the leak then charge the freon
Sep 14, 2009 | Coleman Mach III Air Conditioner
Ac fedders portable
Im not sure I understand the problem. Your AC runs about 4 minutes then the compressor stops and the fan stops as well? What is the model of the air conditioner?
Jun 29, 2009 | Coleman Mach III Air Conditioner
I have a coleman ac that cycles on and off , the
your system is shutting off on low pressure, you need to get it looked at to find a refrigerant leak
Jun 22, 2009 | Heating & Cooling
Recycling to soon?
sounds like the unit is low on freon. it will need to be serviced so the leak can be fixed then recharged.
Jun 01, 2009 | Coleman Mach III Air Conditioner
Wires not connected on mod# 6759c707
If you google Coleman rooftop air conditioners on your computer, it will give you some dealers that sell that air conditioner and they should be able to help you or tell you where you can get the help.
Apr 03, 2009 | Dometic Rooftop RV Air Conditioner
Coleman Mach III Air Conditioner Logo
327 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
