Question about Hayward 1 Hp Max - Flo Swimming Pool Pump
I have a Hayward super pump for inground pool and after 4years it went out. It is plugged in to a 110 out let for that is what the guy wired it to.
  • Hayward Master
  • 1,363 Answers
WELL IT WILL WORK OK ON THAT . 230 IS THE BEST 115 IS THE CHEAP WAY. PUMPS NEED SERVICE NOW AND AGAIN , TAKE THE 4 BOLTS THAT HOLD THE MOTOR TO THE TANK BODY ,UN-PLUG IT AND BRING IT TO YOUR LOCAL POOL PUMP MOTOR REPAIR GUY.. BEARING & SHAFT SEAL AROUND $75. ..USE YOUR ZIP CODE IN YOUR SEARCH .. AND PRIME THAT PUMP AFTER ANY REPAIRS !!
HEY IF'N I WAS OF HELP ..VOTE .. JAY
Posted on May 29, 2010
How to install hayward motor?
Just the motor? Three things you must consider: There are 4 bolts that fasten the motor to the pump housing. You need to determine 110 Volts or 220 volts - 220 will run the pump more efficiently. Bonding. Your motor must be bonded to all other metal parts of your pool system.
Aug 22, 2010 | Hayward 1 Hp 2 Speed Super Pump Inground...
Turn filter on, pump turns on then trips breaker?
NOT A MOTOR TO TAKE LIGHTLY 2 SPEEDS ARE BIG $$$ . TAKE 4-6 . 9/16 BOLTS OUT OF PUMP DISCONNECT POWER (LOOK) WRITE DOWN COLOR OF WIRES AND PLACE THEY GO TAKE PICTURE ! ! AND DO NOT TRY TO TAKE ANYTHING ELSE APART ! SEARCH FOR YOUR LOCAL POOL PUMP REPAIR GUY WITH FREE TESTING USE YOU ZIP CODE IN YOUR SEARCH .COULD BE JUST A BAD BREAKER BUT NOT WORTH THE CHANCE..HAVE A PRO LOOK AT IT. BEST OF LUCK .. VOTE IF'N I WAS OF HELP
Jul 24, 2010 | Hayward Pool Products HAYWARD 1.5 HP 2...
Pump will not draw water in from skimmer.the pump seems to work fine except that need help?
ON A HAYWARD #1 BROKEN IMPELLER OR PLUGGED ,#2 SHAFT SEAL #3 LID SEAL #4 TANK CRACKED.. LOOK FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY USE YOUR ZIP IN YOUR SEARCH .. YOU WANT THE IMPELLER WITH THE BRASS SHAFT ! ASK FOR IT HECK DEMAND IT !... YOURS IS PLASTIC = PLASTIC THREADS (JUNK) . IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 23, 2010 | Hayward 3/4hp Super Pump Inground Pool...
Does the live black wire need to be on the jumper side of the hayward super pump direct wiring ??
It does not matter which side it is on as long as hot is on one side and the neutral the other.
Jul 01, 2009 | Hayward 1HP Super Pump II Inground Pool...
New 1.5 hp super pump hayward, blows circuit when turned on...
Recheck your wire connection on the motor. You likely put both your line wires on the same terminal. If not, try finding a local warranty center for a repair or replacement... http://www.haywardnet.com/locator/
Jun 11, 2009 | Hayward Pool Products HAYWARD 1.5 HP 2...
Inground pool question. How far away can I position my skimmer.
you don't say the volume of the pool, but if the 1.5 was working before and you are not adding too many turns, it will work.
David
Apr 28, 2009 | Hayward Pool Products HAYWARD 1.5 HP 2...
Hayward 1 Hp  Max - Flo Swimming Pool Pump Logo
154 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
