Question about Palm Zire 31 Handheld
How do i perform a hard reset on my palm pda - Palm Zire 31 Handheld
    President:
  • 1,285 Answers
  1. Step 1 Straighten a paper clip into a single line.
  2. Step 2 Locate the "Reset" button by spotting a small hole on the backside of the Palm Zire 31.
  3. Step 3 Push the power button on the Palm Zire 31 with your finger and hold it down steadily.
  4. Step 4 Push the paper clip into the "Reset" button's hole while holding down the power button.
  5. Step 5 Release the power button once the screen displays the "Palm Powered" logo.
  6. Step 6 Push the navigational key in the "Up" direction to complete the Palm Zire 31 hard reset.
Posted on May 31, 2010
  • Dvdcdlaser
    Dvdcdlaser May 31, 2010
    feel free to rate the help
PDA will not perform any of my commands..its frozen
Hello, Tallman.
I'd suggest to perform a soft reset then a hard reset, if the soft reset doesn't work.
Then if necessary, as this may or may not be a simple solution, depending on your particular brand and model:
Remove the back of the PDA. Remove and reinsert the battery.
Hope this helps.
Jan 09, 2010 | Palm Computers & Internet
Tip
Visor Deluxe does not start
Hi.
The procedure below shows how to reset the PDA to factory settings after backing up all your personal data.
After backing up your data with HotSync, perform a hard reset, this will erase all applications and returns your device to its factory default settings.
To perform a hard reset:
1. Hold down the power button on the front panel of the PDA.
2. While holding down the power button, use a paper clip to press the reset button.
3. Release the power button.
4. You will get a message warning that you are about to erase all the data stored on the PDA, do the following:
Press the top scroll button on the front panel
to complete the hard reset and display the startup screen.
If you press any other button you will do a soft reset, that will not fix the problem. In that case restart the procedure.
5. After doing hard reset the unit will return to the initial factory state. All third party installed applications will be deleted, and setting will be reported to factor default.
Connect to HotSync and do a backup of the PDA, then do hard reset on Palm.
If the PDA is not detected by Hotsync, then there is an additional problem.
To troubleshoot problems given by third party application you do a backup, then rename the backup folder containing third party application data to Backup.old, and do hard reset.
After that you start restoring applications from backup.old one at the time, when one application jams the Palm, that is the responsible for the error message.
Procedure is described here.
Regards.
G.
on Apr 09, 2010 | Handspring Visor Deluxe Handheld
Iam trying to remove the owners form a second hand palmOne TX pda
You need to Perform a Hard Reset on the Handheld; 1 Press and hold the Power Button 2 While Holding the power button you need to use the stylus and press and release the reset button on the back of the palm 3 Wait until you see the Palm Logo to release the power button 4 When you see the "Erase all Data" then hit the up on the 5 way button to finish the reset, this will Erase all Data and the Username..
Oct 24, 2009 | Palm TX Handheld
When you do a hard reset:
Yes I would remove first
Aug 07, 2009 | Palm TX Handheld
After a soft reset, my Palm TX becomes stuck on the "Palm Powered" screen. I have tried all of the resets, including the hard reset. The PDA does not respond to any of the resets. I can not turn the PDA...
You need to perform full reset which will erase all personal data and set everything to factory default. You need to press reset and power button to perform full reset.It will give you confirmation once you choose yes it will perform hard reset If issue persist you may disconnect and reconnect to internal battery
Aug 02, 2009 | Palm TX Handheld
How do I make a hard reset on my Palm Zire 31 PDA?
I did not write the posting attributed to me. I have a Palm Tungsten E. My Dad had been using it and I needed to know how to do a hard reset so it would accept my info. I found that on the Palm site after looking on your site. I performed the hard reset and hot synced the Palm with my info.
Thank you, Sue Nutt
Nov 12, 2008 | Computers & Internet
No display
Hello LyMaBa
Do you have an SD card inserted in the PDA?
If so remove it and restart your PDA.
Did the problem go away. If so, please, go HERE for the Zire 71 Expansion update or HERE for the SD/SDIO update.
You can find all the manuals for the Palm Zire 71 PDA HERE.
If you don't have a SD card inserted, you might want to try performing a WARM RESET of your PDA. Youtube has a video on this process HERE.
You can find instructions HERE for performing a reset ("warm" or "hard") on your Palm PDA.
You can find other software, info, downloads, etc.
HERE for your Zire 71.
If performing a "warm" reset doesn't work, try performing a "hard" reset.
*** WARNING!!! ***
YOU WILL loose ALL of your data on the PDA by performing a "hard" reset so make sure it's data has been synchronized w/ your computer software (Palm Desktop, Microsoft Outlook, etc).
* If the information I provided you w/
* resolved your problem or lead you
* to a resolution for your problem or
* an answer to your question, then, a
* "FixYa" rating would be most
* appreciated. @:)
* (You can assign the same rating to
* more than one expert who participated
* in solving your problem.)
* It is best to wait until the problem
* has been resolved b4 rating the experts'
* solution(s). Once you enter a rating,
* the problem will be closed and we will
* not be able to continue to assist you.
* Very often it will take more than one
* exchange of information between you
* and an expert in order to resolve your
* problem. If a proposed solution doesn't
* work for you, don't rate it yet. Instead,
* post back here letting us know and we'll
* continue to work w/ you until we find a
* solution that does work for you.
* Thank you
* BJ @:)
Apr 09, 2008 | Palm Zire 71 Handheld
Palm OS-based PDA freezes up
If you’re not sure what file or application is causing the problem, you’ll need to perform a hard reset. Before you do this, be sure to perform a HotSync so your data is properly backed up (the hard reset will erase all data on the PDA). To perform a hard reset, press the power button while performing a soft reset. Replace the power button when you see the Palm/PalmOne logo and press the Up button when prompted.
Next, find your Backup folder on the desktop. You’ll usually find this folder located within your user folder, which is usually located in either C:\Program Files\Palm, C:\Program Files\palmOne, or C:\Program Files\Handspring. Your personal folder will resemble the user name you selected for your device. If you used your first and last name, for instance, your user folder will likely be the first six letters of your first name followed by the first letter of your last name. Rename the Backup file to Backup.old and HotSync your Palm to restore personal data. Because you renamed your Backup folder, no applications or additional files will be restored at this point. Instead, an empty new Backup folder will appear. Move applications from your Backup.old folder into the new Backup folder one at a time and HotSync your Palm. After each HotSync, try to reproduce the problem. If the problem doesn’t reappear, move on to the next file. Delete any files that cause a problem after they are moved onto your PDA.
Enjoy! Pls.rate me if it's done. Thanks.
Kindly regards,
-micro
Feb 29, 2008 | Best Software ACT for Palm OS - Instantly...
Palm TX Handheld - Delete all records
Hi, the best option would be a hard reset. Before doing so, i would suggest doing one lase hotsync.
at the back of your pda, there is a reset button. press this. be prepared. as it is resetting, press and hold the power button as well as the up button. hold these for like 3 seconds then release. it will then ask you whether you wanted to reset it. press the up button once again and release. it will then reset the pda.
if these instructions are still difficult there are some at palm.com. best of luck.
Nov 19, 2007 | Palm TX Handheld
PDA is totally black; not charging
The easiest solutions are easily overlooked. 1. Check your charger; a cheap multimeter will do for the voltage check. If the voltage (dc) written on the back of the charger is what you get at the plug, go to (2),if not, change your charger,problem solved. 2.You either have a messed up screen or battery. 3. Check the voltage at your battery terminals after charging the battery for like 1hr. If you do not get a resonable read; 2-5v ,just trash the battery and head for the nearest shop to get a fresh one.In case your battery reads okay,your screen or worse, one of the components on the board of the set has gone kaput.
Nov 14, 2006 | Palm Zire 71 Handheld
Palm Zire 31 Handheld Logo
480 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
