Question about HP PAVILION A6230N DESKTOP PC
Audio problems I am able to hear sound when i do a sound test but when i run an application there is no sound. what could be causing this and how do i fix this?
    Guru:
  • 55 Answers
Here is a solution to it
give a right click on the speaker option on the system tray(right hand side bottom of the page)
select sound....select the playback option....
clcik on the speaker and u will the default option will be highlighted ....click on that option and will hear sound
Posted on Apr 11, 2008
SOURCE:
I have no sound on my ipod and apopup say generic volume running
Damaged hardware is responsible for the most obvious iPod sound problems.
In such cases, Apple may be able to help you fix the problem, depending on the status of your warranty.
All iPods have a one-year warranty according to Apple's website.
Software problems can also affect your audio.
For example, downloading a non-certified Apple application can stop your sound from working correctly.
Returning your iPod to its original factory settings fixes many of these software glitches.
Plug in a different set of headphones and test the sound.
If that set works, your old headphones were the cause of your audio problems.
If your iPod still doesn't work, proceed.
Remove an application on your iPod Touch if you installed it right before your sound stopped working.
Hold your finger over the top left corner of the application.
It will shake.
Touch the "X." Touch the "Home" button.
Restore your iPod to fix other potential software problems.
Open iTunes. Plug the iPod into your computer with a USB cord.
Click on your iPod on the left-hand menu.
The iPod will be listed under the name you assigned it when you first set it up.
Click the "Restore" button on the menu.
Leave the iPod alone while it restores.
It may take several minutes.
Test the sound once the restore is complete.
The iPod syncs after restoration.
Once the sync is complete, the process is over.
Contact the Apple Technical Support line at 1-800-275-2273 if your audio still doesn't work.
Have your iPod with you.
Aug 01, 2013 | Apple iPod Audio Players & Recorders
Cant hear my music
Damaged hardware is responsible for the most obvious iPod sound problems. In such cases, Apple may be able to help you fix the problem, depending on the status of your warranty.
It will shake.
Leave the iPod alone while it restores. It may take several minutes.
http://www.apple.com/support/contact/
iPod Video Headphone Jack Replace Hold Switch Fix Sound in One
http://www.youtube.com/watch?v=slIo8PX06-s
Jul 21, 2013 | Apple iPod classic MP3 Player
My iPhone plays videos on the Internet but no sound comes out, why Is that???
If your having problems with no audio from youtube, myspace and flash video. I suggest this
When watching web pages with embedded Flash video or animation such as movie or video clip on YouTube and MySpace using Mac OS X, users may hear no sound. The no sound audio output problem happens despite video playback is fine, and the issue can happen on any web browser, i.e. Safari and Mozilla Firefox. Strange thing is that, when using other applications such as RealPlayer, QuickTime Player and VLC Player, the sound is played properly. And no audio output issue does not affect embedded QuickTime including HD contents on the web.
Apple Mac OS X support site explains that the no audio from certain multimedia content issue is caused by some audio applications that change the computer's audio settings to a sample rate that is too high for other applications to use. The notorious programs include certain versions of Real Player, VLC Player and Audacity.
The solution to solve the Internet movie no sound or audio output is to reset the audio setting in Mac OS X to original configuration:
  1. Open "Audio MIDI Setup" (/Applications/Utilities/), then check the "Audio Output" setting.
  2. Change the "Audio Output" setting to 44100.0 Hz.
  3. Quit Audio MIDI Setup.
If the Audio Output setting is grayed out or disabled, go to "Properties For" tab in Audio MIDI Setup, and select "Built in Output".
I hope this helps
Dec 14, 2010 | Apple iPhone 3G
My laptop speaker stop working from it self
After reinstalling/installing an Operating System you can lose the Audio Drivers or sometimes they just corrupt.. Try reinstalling the Audio Drivers from the disk provide with your P.C./Laptop. If you no longer have the disk just visit the website of the makers of your P.C./Laptop or Motherboard and download the Audio Drivers from there, after that install them.
Thumbs up please if this works for you, thanks..
Aug 30, 2010 | Acer (54.AA806.001) Sound Card
Problem with acer aspire t180, SOUNDCARD don't work0.
If running XP:
Two things to check
Open Control Panel and select Sound and Audio. In the new window select the Audio tab and make sure your sound card is selected as the default playback device.
or
Open Computer management, click the plus sign by "Services and applications" and highlight "Services".
Scroll down to Windows audio and check that the service is started.
.Its also possible that a windows update caused this (sometimes malware or virus)
Hope this helps
Oct 16, 2009 | Acer Aspire™ T180 PC Desktop
I can't hear others on Vent, but they can hear me.
I don't think the program is compatible with Vista. Were you running Vista when it worked a year ago ?
Sep 13, 2009 | Computers & Internet
Skype doesn't quite work...
I have the same hardware and application without problems.
If the internet connection shows no issues, but only the Skype application is having troubles, I would suggest to troubleshoot the Skype applciation.
Check in Skype for any possible other applications causing "load" on the Skype application;
- Advanced
- Settings
- Advanced
- Click on the sentence : manage other applications using Skype and see if there is anything "odd".
It would be nice to hear from you to see if anything helps.
Dec 31, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Video sound problem
Durring video conferencing with MSN Messenger, I can't hear my friend and he can't hear me. Or I can hear them but they can't hear me. What's wrong? trnsp.gif Answer This article applies to the following products:
All Logitech Web Cameras with MSN Messenger Support
This article applies to the following software:
Windows XP
Test the Microphone in Sound Recorder
  1. Click "Start," > "Programs" ("All Programs" for Windows XP) > "Accessories" > "Entertainment" > "Sound Recorder."
  2. Click the Record button and speak into the microphone of the camera. You should see the green line move, indicating the application is picking up sound.
  3. Click the Stop button.
  4. Click the Play button. If there is no sound at playback, check to make sure the correct device is selected.
    1. Click "Edit," then "Audio Properties."
    2. Make sure Logitech is listed as the Preferred device for "Sound recording."
If the microphone does not work in Sound Recorder, click here for help in determining the problem with the mic.
While using MSN Messenger it is the messenger program, not the camera software, that negotiates the audio streams between two MSN Messenger Clients. Although we cannot directly support audio issues in MSN Messenger, the following steps have been known to resolve and improve audio issues in MSN Messenger. For further information, please consult the help documents associated with MSN Messenger.
Test Your Networking Router
You can also test to see if your router is causing audio issues by either physically bypassing your router and connecting directly to your cable/DSL modem or by setting up your computer as the DMZ (de-militarized zone). If you are a novice networking user, it is not recommended that you leave your computer in the DMZ state for extended period as that may leave your computer vulnerable to attack. However, you may briefly configure your computer as the DMZ to determine if your network settings are causing the audio issues. For DMZ setup instructions, please consult your router's documentation.
Enable Universal Plug and Play (UPnP) on both Windows XP and Your Router.
If either of the above steps resolves the no audio problem, try the following steps.
  1. Open Add or Remove Programs in Control Panel. To open Add or Remove Programs, click Start, point to Settings, click Control Panel, and then double-click Add or Remove Programs.
  2. Click Add/Remove Windows Components.
  3. In the Components list, select the Networking Services check box, and then click Details.
  4. Make sure the Universal Plug and Play box is checked.
Notes: If you used a CD to set up Windows, you will be prompted to insert it into your computer.
If your router does not support UPnP or you still get no audio after enabling UPnP on both Windows XP and your router, you must manually open all UDP ports between 5004 and 65535. This is because the audio streams are sent dynamically using that range of ports. Without a dynamic way to open those ports like UPnP, there is no way for MSN Messenger to successfully negotiate the audio stream. Consult your router's documentation for instructions to manually open these required ports.
If you are still experiencing audio issues within MSN Messenger, and you have verified that the microphone is working in Sound Recorder, contact MSN Messenger Support.
This article covers Accoustic Echo Canncellation (AEC) and how it works.
QuickCam 10.x and RightSound supported cameras
QuickCam 11.x and RightSound supported cameras
Call Central and RightSound support audio devices
This article applies to the following platforms:
Windows® 2000 Professional
Windows® XP Professional
Windows® XP Home
Windows® Media Center Home
Windows® Vista
Accoustic EchoCancellation (AEC)'s purpose is to prevent sounds from your computer's speakers to be picked up by your microphone. This can be a significant problem with audio or video calling applications where the voices or sounds from other parties of the call is being inadvertently picked up by the microphone and fed back into the call, creating echo and other sound distortions. Without AEC, this echo can detract from the quality of a call and in extreme situations, the echo can degrade the audio experience to the point where the audio is useless.
To prevent this from happening, the AEC component monitors sounds being played by your computer's speakers while monitoring the incoming sound picked up by your computer's microphone. The AEC module takes the outgoing and incoming sound signals and compares them to determine if echo is present. If echo is found, it is subtracted before the audio from the microphone is sent to the requesting application. This will result in the remote party only hearing you speak, without being distracted by hearing their own voice echo back to them.
When enabled, echo is eliminated for the recipient of the audio/video message. For echo free chatting, both parties need to have a RightSound technology enabled web camera that supports the AEC feature.
Apr 05, 2008 | Logitech Quickcam Chat Webcam
No sound
When I video conference in MSN Messenger, I can't hear my friend and he can't hear me. Or I can hear them but they can't hear me. What's wrong? trnsp.gif Answer Test the Microphone in Sound Recorder
Mar 31, 2008 | Logitech QuickCam Chat Personal Web Camera
Audio connection problems
its all about your sound device not working at all! you can work it as before jus reinstall the proper drivers then its done restart your pc after reinstalling the drivers and your problem is solved
Nov 27, 2007 | Computers & Internet
HP PAVILION A6230N DESKTOP PC Logo
59 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
