Question about GE (PSS26MSRSS) Side by Side Refrigerator
Why freezer section has too much ice? does the method of one day a year of completely shuting off the refrigerator and unpluging it for one full day the best solution each year? The refrigerator I have is 18 years old and no problems till water started coming out at the bottom of the refrigerator and freezer front coils one year ago. Right now Wednesday May 26 2010 the refrigerator has been off for 3 hours and there is a big piece of ice in back of panel of freezer God Bless you all for your didicated service? Thank you for your patience and cooperation. Yours in Christ, Roger H Frost 508-797-3466 home 508-981-2513 cell rhfrost@verizon.net
  • 1 more comment
  • rhfrost590 May 26, 2010
    Praise the Lord
    Thank you Jesus
    We will pray for you at the Bible Study tonight at 70 James Street, Suite 106 Worcester MA 01603 508-832-3844
    PS We will leave the door open to the freezer section for 6 hours. The ex wife is using a hair dryer to the coils after I took off the panel in the back of the freezer Thanks
    Praise the Lord
    Thank you Jesus
    Praise the Lord
    Thank you Jesus
  • GE Master
  • 11,800 Answers
Actually the freezer should be defrosted every time the ice gets thicker than 3/8 of an inch. Yours has too much ice simply because you didn't defrost it in time. Luckily all it can happen if it has too much ice is that the compressor has to run longer to cool things down - increasing your electricity bill.
BTW it must be unplugged from the wall just enough time to melt all the ice - usually less than 12 hours, in the summer even less than 6. Just make sure the freezer is dry before plugging it in .
Posted on May 26, 2010
Where can I get a repair manual for a Hotpoint Fridge
First of all, the model number you gave is not complete. But check you defrost system in the freezer, when the refer section stops cooling, your evaporator in the freezer is possibly full of ice and the fan won't move air through ice. When the refer sections fails to cool, check for a fan in the freezer. If it works, you have a defrost problem and is occurs every 3 - 5 days. The unit should defrost once or twice a day. Good Luck
Apr 20, 2016 | Hotpoint Refrigerators
Whirlpool side by side refrigerator
Could be blocked up in the shute. remove all ice from the freezer and check that the ice shute (leading to the dispenser outlet) is clear. Let the freezer create a batch of ice (normally about 4 to 5 hours) and see if it dispenses then. If not , it could be a failed auger motor. That is the main corkscrew looking drive which pulls the ice into the shute. Check the icemaker in the freezer, and look for a button on the side or underneath the icemaker. Most manufacturers put one there to test the icemaker. Press the icemaker ice dispenser button and see or hear if the auger is turning.
Aug 26, 2014 | Whirlpool ED5FHEXVS Side by Side...
Water Shute freezing up in ice maker
freezer maybe turnedup to high ck manufacturing recommendations
Feb 06, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Fridge section not cold, freezer section o.k.!
Normally, the cold is only generated in the freezer compartment, and then the cold is pulled or pushed throuch cooling tubes from the freezer section to the refrigerator section. So if your cooling tubes become blocked by ice (usually caused by a defrost circuit failure) then the freezer will seem to work fine but the refrigerator section will not receive the cold air it should.
Suggest you remove the food from the freezer section, then remove the shelves and then the back panel of the freezer. If there is a lot of ice on the evaporator then you should manually defrost the unit. Unplug it from the wall and use a hair dryer to melt the ice. There will be an entrance to a cooling tube right below the evaporator make sure the you keep blowing the hot air from the hair dryer down than tube until you can feel it in the refrigerator section.
If there was ice, you also need to troubleshoot the defrost circuit and find out which component failed. It is normally made up of the defrost heater, defrost thermostat and defrost timer and troubleshooting methods can be found in the tips section.
NOTE: There will be a lot of water to deal with when you defrost your freezer so make sure you are ready to handle it with buckets and large sponges or a wet/dry vac.
Jul 13, 2011 | Frigidaire Refrigerators
Over the past couple of weeks, my Side-By-Side Refrigerator freezer has not been running properly. It thaws out for a day or two, then it starts freezing again for a couple more days.
The defrost is not working.This happens due to the evaporator coil in the inner section of freezer is got blocked by ice .--------
Try manual defrost reset procedure: ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. If the same problem occurs then it's defrost problem. The defrost board and the defrost thermostat/heater is not functioning properly and it has to be checked and replaced.
Check the damper if there is too much water collected in the damper then press the damper and remove the water collected in it. The procedure of this unit is as follows: --- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the refrigerator section and the refrigerator section gets cold. The air from freezer to refrigerator passes from the section, in that section the damper is located. Now this problem which you mentioned. In this problem the freezer thaws, this happens if the thermostat is not functioning or the heater is not heating. Then the ice starts getting collected on the evaporator coil. The evaporator coil is at the internal section of freezer. If too much ice gets collected then this ice blocks the fan in the freezer section from functioning and this blocks the damper section with ice getting collected there. This all procedure is controlled by the main defrost board of the unit. Now if the damper is not got blocked with too much water or if the ice is not got collected on the damper area then check the evaporator coils. If there is too much ice got collected on the coils, then takes a hair dryer and melt the collected ice. Then see if the problem returns again. But if there is little bit ice collected on the coils and fan is running properly then it's not a problem. In that case main board is faulty and it has to be replaced. The main defrost board is working but its not controlling the functions as required so the freezer thaws after couple of days.
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
So first try reset procedure.If that is not helping then defrost assembly parts are to be checked and replaced.The defrost thermostat is located in the freezer section beside the evaporator coil.The defrost heater is located in the freezer section beside the evaporator coil.And the defrost control board is located in the fridge section.-------------
you can get the required parts from online sites like:---
www.repairclinic.com or from searspartsdirect online site.---------This will help.Thanks.Helpmech.
Feb 21, 2011 | Amana ASD2625K Side by Side Refrigerator
Freezer works but refgrigerator section keeps barely cold
remove the back plate. check to see if the evaporater coils is completely iced over. If it is then your problem is the defrost system. the solution is either you timer, thermostat or element heater. very cheap to fix. if not, then check your damper. it may be that the mechanisim is not shuting or opening correctly and thus regulating air control to the right side of the refrigerator.
Dec 07, 2009 | Maytag MZD2766GES Side by Side...
Whirpool Refg Mark 1side by side with Ice Maker..... Freezer OK..Temp. OK Ice maker maes make Ice When ice release is pressed=no ice comes out//and the motor sounds as if is trying work but somrthing is...
3 posibilities. Remove bucket, dump the ice and check the auger (the metal part that spins the ice forward. 2. There is a motor behind the ice holder with 2 ears sticking out. See if you can turn it both ways with your fingers. Stiff, but it does turn. If not, many times it can be removed and left on a counter for a day to dry out. If it will then turn reinstall, and try it. If no luck, you'll need to replace it. 3. Open freezer door and inspect the shute for an obstruction including ice. If the shute is full of cubes, could be a flap door hanging up. The flap is necessary to prevent air from entering the freezer compartment.
Oct 22, 2009 | Whirlpool Refrigerators
I have whirlpool refrigerator model# et9fhtxmq01 with the freezer section to the top and refrigerator section the bottom .The refrigerator section is not cooling and freezer section is not freezing ok.I...
Thaw it with a hairdryer and it'll work til you can get it fixed.
check defrost heater, defrost thermostat
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. If the heater and thermostat are ok it’ll be the control.
Sep 13, 2009 | Refrigerators
Ice in bottom of frost free freezer
the heaters to defrost the coil may not be working
Jun 24, 2008 | Maytag MSD2454G Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
Top Refrigerators Experts
Sal DeAngelo
dweatherby
