Question about Hotpoint WMA76 Front Load Washer
The machine fills up WMA76. It dosnnt appear to wash but empties. Then it displays ON on the display board and will not do anything else. The only thing it will do is if I forward it manually to the spin cycle but it has not washed.
Apologies - I don't have a solution but I do have exactly the same issue and wondered if you'd found the cause since it's been three months since you posted?
TIA.
Posted on Aug 22, 2010
My WMA76 front loader is emptyng as it is filling
hi you can try disconecting wires from presure switch then putting them back see if this helps
Feb 20, 2013 | Hotpoint WMA76 Front Load Washer
We live in NZ and no one here deals with Hotpoint! I can't find a repair person who will look at our WMA76. We have power, the machine fills up and then the timer seems to add time on. The machine then...
The timer will add on time if the water is cold or the heating element is taking too much time to heat the water. Check both inlet water screens in the back of the unit (clean as necessary) and.... do a continuity test on the heating element with the power secured / OFF. If the heating element is open you will most likely experience the symptom you currently have. Stokes AU can get your parts: http://www.stokesap.com.au
FYI if you can find a GE Appliance dealer they also work on Hotpoint. (Other than the name they are pretty much the same unit)
It appears the only GE dealer is in AU here:
Andi-co Australia ' www.andico.com.au They would also be a source for parts.
Thanks for choosing FixYa,
Kelly
Jun 30, 2011 | Hotpoint WMA76 Front Load Washer
Hotpoint WMA76 - been on a normal wash cycle but wont spin to drain water - cycle finished, drum full of water and cant empty. How do we empty it to open machine?
Remove drain outlet hose from point where it discharges into waste pipe, and lay the hose down into a bucket or bowl, this should let the water syphon out, enabling you to open the door.
Dec 29, 2010 | Hotpoint WMA76 Front Load Washer
Hotpoint wma76 stops and displays ON
Could be rinse water valve ..Faulty Solonoid coil
Nov 10, 2009 | Hotpoint WMA76 Front Load Washer
Faulty Hotpoint WMA76 washing machine
it may be 1) a connection loose at the motor 2) motor brushes are worn out 3) a pcb fault check in that order.
Feb 16, 2008 | Hotpoint First Edition WMA12 Front Load...
Wont work, flashes LR
rapoyner The "LR" error code means "locked rotor". It appears on the display after the machine has repeatedly tried to turn the motor. The cause of the problem could be the motor itself, the motor control board, the main control board or the wiring. If your washer is less then five years old most likely the parts are still under Maytag warranty. It has very sophisticated design and I wood recommend to call the Maytag authorized repair man even if the warranty is already expired. Gendos
Jul 06, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Hotpoint WMA76 Front Load Washer Logo
112 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
