Question about Black & Decker Tools & Hardware - Others
I have a black and decker 3x24'' #7451. The drive wheel is loose and rubs against the motor housing. is it possible to replace? I suspect the wheel bearings are worn and causing wabble. Belt slips due to this. Not certain if I can even take that wheel off. Is the sander shot?
rowdy45176
  • 2176 Answers
SOURCE: slipping belt
OK the belt tensioning mechanism is spring loaded. First what is the quality of the belts are they real flimsy or stiff. You say the rollers spin but my question does the rear roller still spin and the belt remain stationary. If so the rubber belt on motor is bad. I would take a look for excessive wear on the rear roller. Does the yoke mechanism snap forward or move slowly, look for a build up of sawdust in this area that might be restricting movement on the yoke. The wear plate in still good condition. One other thing on the belts are they directional? Do they have an arrow on the inside if so that has to point toward front of tool. I looked at a breakdown and could not see anything else to suggest. I never had this problem except with belts when I was at Makita.
Posted on Jan 19, 2009
Editor925
  • 285 Answers
SOURCE: belt won't stay on belt sander
Check first that you have retensioned the belt... i.e. when you removed the other belt, you would have had to pull on a spring-loaded lever to remove the belt tension before you added the new one... make sure the tension lever is flipped back in to ensure the new belt is tensioned...
Next, and the likely problem you are having, is belt tracking... There should be an adjustment knob up near the front of the sander near the front roller, either on top of the front part of the sander, or to the side near the front roller... When you turn this knob, it makes the belt track either left or right over the sander's base. This knob will allow your belt to run square and true and not spin off to one side...You need to adjust the tracking using this knob while the belt sander is running and with the new belt tensioned and in place, so turn the sander upside down, and power it on with one hand, then turn the knob with the other hand whichever way is needed to have the belt track square and in the middle of the rollers. Make small adjustments on the tracking knob to begin with. They can be sensitive at times.
That should stop your belt spinning off to one side.
Posted on Mar 18, 2009
  • 384 Answers
SOURCE: The belt slips off my Belt Sander
All sander will have two adjustments. The first is to release the sanding belt by retracting the position of one of the rollers. The second adjustment moves one of the rollers belt tension from side to side. The roller angular position is changed, sometime by a single knob or screw, and sometimes by two separate adjusting screws.
Posted on Jun 19, 2009
  • 8 Answers
SOURCE: Describe your Black & Decker BR318
This is a good sander but no portable belt sander is really a floor sander.
Posted on Mar 11, 2010
SOURCE: broken drive belt on belt sander
My answer comes almost a year after the original question, but I'll post it anyway for those who end up here after a search.
Black & Decker no longer supplies drive belts for the BR400 sander, but you can get a replacement elsewhere if you know what to ask for.
The belt is a synchronous, single-sided "XL" series belt, and mine had 120XL031 printed on it. The belt width is 0.31in or 5/16in or 7.9mm. Its pitch (distance from tooth to tooth) is 0.20in or 1/5in or 5mm. Its total height is 0.09in, and tooth height is 0.045in. It has 60 teeth, making the total length 12in.
I found a replacement at sdp-si.com, part number A 6R 3-060031.
Look here for timing belts (inch), then narrow the search for single-sided, .200 (XL) pitch, 60 grooves, 5/16 width.
Posted on Jun 16, 2010
09 AWD Ford Explorer airplane sound humming underneath the car definitely not a wheel bearing what could this be
Loose exhaust pipe? Loose wheel housing liner? Loose front air dam under bumper?
Driveshaft rubbing against loose insulation or touching something? don-ohio (:^)
Feb 21, 2017 | Ford Cars & Trucks
B&D Elct mower crapped out today,rock?? started making a funny sound. and the same noise with a lttle white smokeLooks like th a belt of some sort under the blade is out of place. Any suggestions?
You've either broke the motors housing moving the motor out of alignment or the impact on the blade has snapped the drive belt by the sudden torque or it's been jerked off by the sudden stop of the blade it's been yanked off the drive pulleys and the nose is the motor running free with no blade resistance you will need to open up and inspect the drive belt assembley system the blade drive shaft pulley access area and the motor access area to either replace the broken belt or refit the belt if it's not been chewed or damaged by the free spinning motor pulley the smoke it was proberbly the belt rubbing against the motors drive pulley or wrapping up around it burning it through friction
Or your broke the motors drive shaft HOUSING allowing the driving motor and pulley to become misaligned dropping drive belt off
The motor funny noise if a banging around sound then is was the still running motor pulley is bouncing around and rubbing against the deck ect. Causing the smoke if this has happened the impact with the stone has caused a kickback effect on the motor twisting it out of its housing breaking it's secure mounts meaning the decks motor is loose the housing has gone, the MOWER extremely dangerous as the motor can at the speed it's running at 3000rpm it will chew thought the rest of the deck in a matter of seconds throwing and ripping itself from the machine sending chunks of broken deck and the motor flying in all DIRECTION possibly causing injuries to any one within range and as the wires rip apart and a possible nasty and even fatal electric shock please for your own safety do not use the lawnmower
Until it's been inspected by qualified personnel
It is highly unsafe and should either be repaired or replaced which ever the cheaper
Advice to check the area your cutting esp when using a high impact resistant plastic deck lawnmower for hidden foreign objects large and small stones as the small ones can be thrown by the blade like a "bullet"! small toys esp metal cars etcetra will make excellent shrapnel and cut the fabric grass box to ribbion it's also you if directly in the debris path Also not good for your lawnmowers blade or deck
Pavement slabs are defiantly known as the silent MOWER DESTROYER YOU can't hear it, as you aproch you can't see it before it's too late, there's a Loud bang the MOWER stops that exact same instant and the MOWER IS NOW KNOWN AS BROKEN "!
Esp on petrol mowers slabs tend to stop the MOWER dead bending the crank shaft the mowers with a slightly bentccrank will jump Round like it's on steroids or vibrate so badly it will shake itself apart as well as leaving a, very odd sensation in your arms
Deposits from animals are just nasty to clean off the deck and wheels so I clear them up too if THERE are any just in case
Jun 02, 2016 | Black & Decker Black and Decker Mm575 18"...
Front wheel rubbing when brakes applied rim rubs against caliper then wheel locks up
sounds like caliper is loose or missing hold down pins also possible wheel bearing is damaged. ,take wheel off and start by really checking brakes
Oct 03, 2014 | Cars & Trucks
I have a 2002 gmc sierra 2 wheel drive and when I take off initially and when I turn left I hear a grinding/grumling noise.
Loose or damaged Wheel-Bearing causing other parts to rub together, like the brake components or your wheels are too big or shocks weak, or exhaust hanging and are rubbing against something.
Perhaps oil is leaking from your rear axle housing dut to bad seals (check inner of wheels) and around axle housing - remove plug and check that your finger can reach in and touch it. Could be a sign of rear end failure or simply the backing plates on the brakes behind the rotors and the drums (steel disk) sometimes rust on the drums can grind against the backing plates if they are weak or warped (clean this area).
Jun 15, 2010 | 2002 GMC Sierra 1500
I have the black and decker grasshog (non cordless) which long turns. i've replaced the line, and it powers up but no turning of the wheel.
possible stripped plastic reduction gear (just inside bottom of motor housing). Make sure that no grass is bound up between moving and non moving parts. This is a chronic problem and will lock up the unit.
Apr 11, 2010 | Black & Decker String Trimmer Cordless 12"...
Noise coming from my blower sounds like something is loose
HI.The blower fan or squirrel cage is rotated by the blower motor shaft, thus, forcing air through the heater core or A/C evaporator core and into the passenger compartment. it is housed in the blower compartment shroud. If the motor shaft becomes unstable, this will cause the cage, or blower wheel, to rub against the shroud, or housing. This will cause the noise you are hearing. The shaft screw may be loose, or the shaft, itself, may be faulty as well.
In most cases, replacing the blower wheel will correct this issue.It would be wise to inspect the blower housing for any loose mounting screws before replacing the wheel.
Nov 18, 2009 | 2005 Pontiac Grand Prix
HOTPOINT WASHING MACHINE - BELT IS RUBBING AGAINST BACK OF DRUM & WEARING BELT + INTO PLASTIC DRUM CASING. I HAVE TRIED MOVING THE BELT TO THE FRONT EDGE OF THE MOTOR PULLEY DRIVE, BUT AFTER A FEW...
if you have gotten that far your good
now try to look at the motor it sounds like your belt might be a lil off track on the mortor shaft
there is a adjustment srew on the top left of the motro its hidden under things but its there
you can looses this and swing the motor
make sure you have it lined up on the motor shaft and it should stay aligned on the pully
Oct 08, 2009 | Hotpoint Aquarius WD63 Front Load...
You have missed a screw about half way, there is one under a sticker.
Sep 03, 2009 | Black & Decker 14" Grass Hog Xp...
Goodman GMT115-5B, loud noise when turned on
In the lower portion of the furnace you'll see where the blower housing is hung in the center of the furnace. There are two bolts you'll need to remove to pull out the whole housing. Depending on the size furnace you have you may have to unmount the control board and set it aside. Don't worry there is no need to remove the wires from the board. Once you have the housing out set it on its side (motor side down) and you'll see a shaft where the blower wheel mounts onto the motor shaft. There should be a bolt you can tighten. first loosen the bolt and put the housing right side up. after that center the wheel on the shaft so that neither of the sides of the wheel are rubbing on the housing once you find that spot where the wheel spins without rubbing tighten that bolt on the shaft and reinstall. should the problem persist you may need to replace the blower housing and/or wheel. I doubt the motor will have to be changed.
Aug 15, 2009 | Goodman GMS90703BXA Heater
Noisey fan
In my case noise was coming from the plastic blade rubbing against the sheet metal housing. I removed the motor and added 2 washers to the mounting screws. The washers acted as spacers and lifted up the motor/blade assembly with respect to the sheet metal housing. The blade no longer rubbed against the housing and the noise stopped.
Dec 08, 2007 | Broan-NuTone N-8664RP Combination Light...
Tools & Hardware - Others Logo
305 people viewed this question
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Gil Shultz
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
