We are using a NBX® V3000 phone system with 3Com 3102 phones. The issue we are experiencing is the phones will seem to "freeze up" from time to time. One of three things usually happens... 1. The phone will ring, and I'll go to pick it up but the phone doesn't register that I've picked up the handset. It continues to ring as if the handset is still in the cradle. At this point I would expect for voicemail to kick in... but it doesn't. The call just gets disconnected. 2. When I have completed a call and want to hang up the phone, the phone doesn't always register that the call is complete. I'll put the phone in the cradle but the connection stays open. Usually just clicking on the phone "disconnect" button in the cradle a few times will fix the problem. 3. When I want to make a call, I'll pick up the handset but will not get a dial tone. Usually just clicking on the phone "disconnect" button in the cradle a few times will fix the problem and the dial tone will come back. I'm sure all three of these issues are somehow related. Do you have any suggestions as to what I should do?
  • 560 Answers
Does it happen on all phones or just one particular phone unit?
Posted on May 26, 2010
  • 3 more comments
  • tnicholso3 May 27, 2010
    It happens on most phones... There are some people that work in our office that utilize their phones on a regular basis and probably make and receive between 40 to 50 calls a day. These people see the issue more than anyone else. Then there are others in the office that may make and receive 4 to 5 calls a day. These people report very little to no issues.
    So my thoughts are this issue probably exists on all of our phones but happens so sporadically that the issue seems to only affect those people who are constantly on their phones.
  • Liza Halbrook
    Liza Halbrook May 29, 2010
    I did some testing on my phone. I got the same result as you describe but it only happens when I call an extension but hang up my phone before it rings on the other end, then call another extension/outside lines and after a successful call I get a loopback ring. I did lots of tweaking but I couldn't remove the loopback ring. That's the reason why the voice is not kicking in, the phone is calling itself.
    I would suggest to your heavy users to avoid calling a number then hanging up before they hear the ring.
  • Liza Halbrook
    The phone has a delay like if you press the plunger quickly, you can get a diff function like transferring a call or joining a conference call. Observe how many seconds you can get a dial tone after pressing and releasing the plunger. Do this by pressing and releasing the plunger with 2 seconds interval and increasing the time (2,4,6 secs) you pressed the plunger to find out how long before your system recognize that the call has ended and give you a new dial tone.
  • tnicholso3 Jun 01, 2010
    Thank you for your suggestions. I will definatly give your troubleshooting tips a try. However, in response to your reply about the phone "freezing" while making a call... I understand that if I hang up a call before before the other party answers that call may freeze due to breaking a connection that hadn't been established but how would that pertain to an incoming call that we can't answer. For example, sometimes when the phone rings, I'll go to answer the phone, but the phone seems to be in a frozen state. The phone just rings and rings after the handset has been picked up. This happens with internal and external calls. Both issues seem very similar.
  • Liza Halbrook
    Liza Halbrook Jun 01, 2010
    The loopback ring only happens when you tap the plunger to end the call before it rings on the other end, then make another call. The ring is generated by Asterisk and not from an outside line. I've tested this with Asterisk and Grandstream/Polycom phones and it did the same thing. I don't know why its doing it and I can't find a solution. Most of the users in the company I am supporting that used speaker when dialing did not encounter the problem but those who always lift the handset to dial encounter the problem on rare occasions.
    I will let you know when I found a solution for the loopback ring.
Some 3Com NBX telephone 3102's can access paging but has no audible
If the system is in "IP on the Fly" mode you will need to add IP's to the IP pool on the system. If you aren't using any remote phones you can put the system in "Ethernet only" mode and you won't need to worry about the additional IP's. Also, ihave seen problems where you need to make sure that IGMP snooping is enable on the switches for paging to work.
Apr 05, 2013 | 3Com NBX® V3000 (3C10600BUS)
3Com 3102 phone dial tone but won't dial out
As long as someone hasn't been poking around in the phone system, this is a phone company issue. I have seen this many times and it has always been a carrier issue. Typically with PRI's or integrated access analog lines.
May 08, 2012 | 3Com NBX 3102 IP Phone
When someone call 3Com NBX 3102 IP Phone we cannot hear them talking, but they can hear us. I tried it on three 3Com systems and same thing happens. We get problems like these often and we are just...
If the phones are only 6-8 months old you should be calling 3Com. those phones have a 1 year warranty and once you register them they will help you troubleshoot and replace them if needed. Can you provide more detail? Do you have any network issues while this is happening? Does speakerphone work but the handset doesn't?
Apr 29, 2010 | 3Com NBX 3102 IP Phone
We have a 3Com NBX V3000. The building our office
This was a rather simple fix. When I was speaking about the NBX V3000, I was talking about our 2U NBX Chassis which holds the line card. When our phone system was installed I wasn't shown the 1U NBX V3000 "Brain". I thought everything was contained in the chassis. Long story, short, I restarted the 1U "Brain" and the system came back up with 5 minutes.
Feb 15, 2010 | 3Com NBX® V3000 (3C10600BUS)
Cant connect additional 3102 to nbx. Please help!
3102 phones require group 2 licenses purchased from an authorized NBX reseller. if you don't have enough the system will not allow the phone to be discovered. You can check this unler the licenses tab while logged into the phone system as administrator.
Jun 25, 2009 | 3Com NBX 3102 IP Phone
Robotic voice In several time the external callers are hearing a robotic voice, so it?s not possible to converse with this quality. The problem appears especially with the 3Com phones (3101, 3102 and...
I had a similar problem at a customer and I returned the NBX for a new one. Research had suggested there was a problem with the ethernet controller.
Mar 23, 2009 | 3Com NBX® V3000 (3C10600BUS)
3com NBX phone number of rings setting problem.
Delete the MAc Address from the system and delete the user account. Re add the phone.
Feb 12, 2009 | 3Com NBX 2102 IP Phone
Random crashes of 3Com NBX V3000...
Call 8008763266. Also check 3Com Primus Knowledgebase for savecore procedure.then check nboss.log.
3Com NBX Support Team
Feb 12, 2008 | 3Com NBX® V3000 (3C10600BUS)
Roll back phone software
The phone is in a continuous because it is trying to connect to the NBX. You need to make sure it is on the same network as the NBX. Also, within the NBX you need to make sure Auto-Discovery is enabled. You also need to check how many group 2 licenses you have, as this phone requires one to run on the NBX.
Aug 31, 2007 | 3Com NBX 3102 IP Phone
47 people viewed this question
k24674
jasbo
jasbo
