Question about Refrigerators
I AM WORKING ON AN L.G REFRIGERATOR, MOD#LRSC26925TT SER # 604KRREO2158 FOOD IS FREEZING IN THE FRESH FOOD COMPARTMENT EVEN THOUGH THE TEMP IS SET AT 41 DEGREES
  • papaduck2008 May 26, 2010
    HOW WOULD SETTING THE F.F. TEMP AT 38 DEGREES WHEN IT IS NOW SET AT 41 KEEP THE FOOD IN THE F.F FROM FREEZING?
  • papaduck2008 May 27, 2010
    this makes sense to me,because I have no problem getting cold air,only trying to regulate it. I will get the damper assembly and related sensors.
  • 1,284 Answers
Hi, sounds like the damper or damper belt may be at fault. The cold air enters the refer compartment through the damper in the back. If that damper is not controlled to close/open as needed it is likely stuck fully open all the time. That will let cold air in no matter what the t-stat says. See if you can view with a mirror and see if the damper "blinds" are fully open. If the t-stat is turned all the way down the dampers should close, as less cold air is needed. Then, as the t-stat is turned up, the dampers open to let in cold air from the freezer compartment.
Take care
Posted on May 26, 2010
  • Shehu Pro
    Shehu Pro May 27, 2010
    Hi, you have a bad thermostat and you need to replace it....
    President:
  • 1,561 Answers
I advice you reduce the temperature of the refrigerator to 38 degree Fahrenheit, this might help regulate and reduce the freezing's on the food compartment because the normal refrigerator temperature should be at that range.
Take care.
  • Sulaimon Jimoh Olayemi May 26, 2010
    From the question you posted, you said the fresh compartment is freezing foods, that what you said.
    To your comment now,
    inspect the gasket for dirt or debris that could prevent it from sealing.
    If you find any, remove the large debris, then wash the gasket, using a
    scrub brush and warm, soapy water.
    Check the gasket for cracks or tears that can let cold air escape. If
    you find any, replace the gasket.
    Check the seal: Open the door, insert a dollar bill partway and shut the
    door on the bill. Try to pull out the bill. You should feel some
    resistance. Repeat the test at several points around each door. If the
    bill slips out easily, replace the gasket.
      Power and Controls
    1. When your refrigerator isn't cooling your food and drink items,
      first check that the power cord is plugged into a working electrical
      outlet. If you recently plugged in the refrigerator for the first time,
      it will take approximately 8 to 12 hours before the refrigerator is
      cool. Even though the refrigerator is cool in this time frame, you
      shouldn't place the refrigerator to a colder setting until the initial
      cool down stage, which takes 24 hours.
      If the refrigerator has
      been running for 24 hours, you can adjust the refrigerator to a lower
      setting. The control panel is located in upper portion of the
      refrigerator compartment. Press the up arrow button to set the
      refrigerator to a higher setting, which will decrease the temperature of
      the refrigerator compartment.
    2. Door
    3. If the temperature control is correctly set but the refrigerator
      compartment still does not cool down, check the refrigerator door.
      First, remove any food or drink items that are preventing the door from
      fully closing. In addition, make sure all of the drawers are fully
      closed, as they may keep the door from closing.
      Next, clean off
      the gasket with warm, soapy water and a sponge. Rinse the soapy water
      off of the gasket. If the gasket is not clean, it will not create a seal
      with the refrigerator.
      Another reason the refrigerator is not
      cooling down may be because the refrigerator door is opened too
      frequently or left open for a long period of time. Pay attention to your
      use of the door and try to shorten the amount of time the door is
      opened.
    Take care
Amana AFI2538AES The refrigerator portion keeps freezing the fruits and vegetables. The chiller control is on the warmest setting and the refrigerator temp is set at 43. I have been raising every once...
Our Amana afi2538aes is doing the same thing. Had a repairman out. He called tech support at Amana. They had him adjust the "thermistors" but it is colder than ever running at 28-30degrees in the fresh food compartment despite being set at 46 degrees. Tech support also recommended installing some sort of "ice bin seal kit to take care of the problem" according to our invoice from repairman. Repairman was told that the ice bin in the fresh food compartment puts cold air out (to keep the ice frozen) which freezes the food in the fresh food compartment. I called Amana and the rep I spoke to said he couldn't find record of this being a problem with the model but tech support told our repairman "we've had a lot of problems with this happening."
Mar 31, 2011 | Amana AFI2538AES Stainless Steel (256 cu...
Hotpoint fridge freezer freezer ok but fridge not working temp is always 21 degrees tried to set to 4 degrees but just keeps going to 21 freezer is fine -22 degrees
Merv -
Most manufacturer's fridges are designed for 34 degrees F in the fresh food compartment and 0 degrees F in the freezer compartment. Setting the fresh food compartment to a value lower than 32 degrees will freeze any moisture in foods, fruits and vegetables and freeze water in juices and other beverages resulting in broken containers, exploding cans, etc.
What you need is another freezer. Trying to convert a refrigerator into a freezer is going to be very difficult - especially without ruining it.
Aug 09, 2010 | Hotpoint Refrigerators
Fruits & Veggies are freezing in both lower frig compartments
Good day,
This problem appears in spades this time of year, every year.
The problem becomes more severe when the temperatures in the house cools down and is made even worse if the usage of the machine becomes lighter.
It occurs when the machine is off, not on.
There is an open vent, near the bottom, between the freezer compartment and the fresh food compartment. This opening or vent is necessary when the machine is running, so that the air pumped into the top of the fresh food section, can return to the freezer compartment. This is by design.
Now,
When the machine is off, the zero degree air from the freezer compartment. can drift into the fresh food compartmnet and drop the temps near the bottom to below freezing.
Off time increases substantialy at this time of year.
Some have even recommended turning the controls colder to offset the problem, but I've no proof it works well, or even a little.
SXS and top freezer models experience it more than bottom freezer models.
Dec 14, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer extremly cold, some frost on items. The fridge is also too cold, freezing food in the bottom crisper bin. Kenmore Elite side by side model # 5320902. We have the temperatures set higher to...
The compressor is cycled on/off by the fresh food temperature setting. The freezer setting controls a panel, or door if you will, that allows cold air to be blown into the freezer.
Since both compartments are getting too cold, the most likely culprit is the fresh food thermostat control, since it controls the compressor cycle. Try setting it to a higher setting, even if it's above normal. Use a manual thermometer to check the temperature of the fresh food compartment and compare it to the control setting. The readings should be the same or very nearly the same.
I assume your refrigerator is controlled by a solid state controller (i.e. a printed circuit board). Some of these allow for calibration of the thermostat to coincide with the actual temperature of the fresh food compartment. That would most likely have to be done by a service technician unless you have expertise in the field.
If calibration is not an option, if you can live with the thermostat setting not reflecting the actual temperature, a free fix is to simply set it higher than you actually want it to be, recognizing that the actual temperature is 'X' degrees lower than the thermostat setting.
The freezer compartment temperature will be similarly affected, and can be controlled by the freezer temp setting, which is actually nothing more than setting the position of the panel which allows or restricts air from being blown into the fresh food compartment from the freezer. Again, the compressor is cycled on and off by the thermostat in the FRESH FOOD compartment which gets its cold air from the freezer compartment.
Aug 29, 2009 | Refrigerators
We have a ge side by side and the refrigerator is freesing stuff. the model number is GSS25X SNA BS
Is it all areas of the fresh food side that are freezing your items, or is it the drawer area?
There is a direct connection (on my GE side-by-side, at least) between the freezer compartment and the drawers in the fresh food compartment. The size of the connection is controlled with a wheel or a slider. This could contribute to freezing in that area of the fresh food compartment.
Otherwise, it could be the temp sensor(s) in the fresh food compartment. If the computer thinks the temp is too high in the fresh food compartment, it will continue to cool.
It could be a problem with the motorized door that connects the freezer compartment to the fresh food compartment, located at the top of the dividing wall between the compartment. That door should close when the temp in the fresh food compartment is cold enough. If that door mechanism has failed, is disconnected, or otherwise blocked in the open position, cold air from the freezer compartment will continue to circulate into the fresh food compartment.
Jul 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Top refrigerator not cooling--freezer icy
This has happened in my GE side-by-side (model GSS20IEMDWW). For me, the problem was caused by a faulty temp sensor in the fresh food side. That sensor never signalled the computer that the temp in the fresh food side was cool enough, so the compressor ran constantly.
Since the compressor was running constantly, the evaporator coils (back wall of the freezer compartment) eventually iced over (took about a week). Since the fan that draws air over the evaporator coils could no longer move any air (due to the icing), the temperature in the fresh food side continued to climb. (The fresh food side is chilled through a hole with a motorized door at the top of the dividing wall, so if no air is moving in the freezer compartment, temps in the fresh food compartment climb.)
I replaced the temp sensor in the fresh food side and solved the problem for a while. About six months later I had the same problem again, so I replaced both temp sensors in the freezer compartment - which solved the problem again. (My fridge is about seven years old.)
If you are going to replace any of the temp sensors, replace them all under the principle of "if one failed, the rest will soon fail too".
Jul 28, 2009 | Refrigerators
The freezer temperature is too high. is it controlled somehow? the fresh food compartment is a bit warm too - though the setting is on coldest.
I've made a mistake before with thinking that I was setting the adjustment correctly on a refrigerator before, sometimes those dials are hard to read if there is a graphic scale, or symbols etc. Instead of numbers with the highest number being the coldest setting. Anyway make sure the temp setting is set correctly, these are found in the refrigerator side.(yes even for the freezer, so it does'nt freeze up) I adjust mine all of the time, things only need to be so cold right.(helps my elect bill) Make sure those special compartments have clear air passages to them. best regards.
Jun 08, 2009 | Haier HRF10 Top Freezer Refrigerator
Food and drinks freezing in my refrigerator. How do I adjust?
Inside your refrigerator is a control on left side of the panel. Try to adjust there and try to close the dampers near the lower drawer bins. If that don't work change the temp a little higher in the fresh food compartment. But closing the ducts should do the thing. Let me know, Thanks Sea Breeze
#27 below in pic try ajusting the air coming into fresh food compartment.
seabreezehvac@yahoo.com
http://servicepartstec.blogspot.com/
Apr 21, 2009 | Estate TS25AFXK Side by Side Refrigerator
Fridge keeps on freezing everything inside of it
This refrigerator only has one thermostat located in the fresh food compartment it is designed to activate the sealed system (cooling) until it reaches approximately 37 deg f in the fresh food compartment. The damper controls how fast the cold air can move from the freezer compartment to the fresh food compartment. Allowing you to control the temp in the freezer by controlling the flow of cold air to the thermostat.
You have one of two problems.
#1 your thermostat is no longer opening when it achieves set temp. fix = replace thermostat pn 61005798 $35
#2 your damper arm or assemblie has broken. Fix = Replace damper or broken arm and actuator.
damper assembly pn12001377 $44
damper actuator pn 61002000 $2
damper arm pn 61001999 $2
thermostat actuator arm damper arm
damper assembly both pics
Apr 06, 2009 | Refrigerators
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
