Question about Numark DJ/iO Sound Card
MyDJ IO sound card keeps making a horrible ringing sound
My Numark DJ IO sound card keeps creating a horrible high pitched ringing sound when i use it. the sound comes on and off, i'm not sure if it's the USB connection or just the sound card itself. the laptop i'm plugging the sound card into is a 2005 dell inspiron 1501 with windows vista basic. the programmes with which i use the sound card are Atomix vitual DJ 6.0 and propellerhead reason 3.0.
  • 476 Answers
You may need to update the drivers for your device
also check the supplier feed back or reveiws on this model to help troubleshooting for the future
Posted on May 27, 2010
  • Verne Koti May 27, 2010
    no mention of how long the sound card has been working with these programes
    but I would uninstall drivers and reinstall again,
    If problems persist then its a setting thats is needing your attention,
    otherwise its going to be a service pack update already applied to your computer
  • asabielenber Oct 09, 2010
    Try it with your computer unplugged. A lot of times the voltage in the computer is different than the voltage powering your speakers and the excess it that noise. if the problem goes away when it's unplugged, get a ground loop isolater to from the iO and that will take care of the extra voltage.
Dj/io pc issues
Go here and download the driver for your OS and install it :
http://www.numark.com/product/djio
Apr 15, 2012 | Numark DJ/iO Sound Card
I have windows 7 and it is a 64 bit operating system, when i plug the dj io into my usb connection and try to install the drivers it comes up as not recognising the hardware and keeps saying that the...
Good day,
Is your Numark DJ/io soundcard comes with a software cd/dvd. You need to install it first in your system to use it. If you have no cd. Try downloading on the product website for the software. Tnx
Aug 18, 2011 | Numark DJ/iO Sound Card
Make sure you got software with this program that is 64 bit compatible,i heard Numark just released 64 bit support for DJ/IO and your card supports multiple outputs
Mar 14, 2011 | Numark DJ/iO Sound Card
Numark dj io refuses to work. When plugged in it turns on then off. what could b causing this?
It sounds like a power supply/module issue. If you noticed any high-pitch hissing noise recently coming from the device, or noticed some instability in its work then these may be signs of a failing capacitor. Most probably there's one or two capacitors that serve as current stabilizers/filters, and if they break the current that leaves the power modulating assembly is not stable enough to allow the rest of the electonics to work properly. You'll need to open it and see if there are any bulged electrolytic capacitors and replace them... or have an electronics technician/TV repair tecnician to see it.
If this post was helpful and informative please give it a Thumbs Up. Thank you.
Jan 19, 2011 | Numark DJ/iO Sound Card
I have a Numark Stealth, DJ IO and Traktor Pro, I want to configure the Traktor Pro so that one can listen to main track on main speakers whilst I cue new track in headphones separately... how do I do...
I want to do the exact same thing. Just got my dj/io in yesterday and I'm not sure how to connect my stealth and laptop to it. U ever figure it out?
Jul 05, 2010 | Numark DJ/iO Sound Card
Cant hear anything out of my speakers connected to djio
Are you using a Mixer as a pre-amp for this set-up? For example, I have a Numark CM200 where I have all of the inputs and outputs I need to run. DJ IO is connected to Chanel 1 and Chanel 2 Lines in my mixer. The DJ IO is conected to my computer by USB cable. In Traktor souncard settings chanel 1 is set to (3&4) Chanel 2 (2&1) also, devise set up is Numark DJ IO and in External mode. Of course the mixer is conected to my amp and speakers conected to the amp as well.
Apr 26, 2010 | Numark DJ/iO Sound Card
Trying to setup Traktor PRO with the DJ IO and Stealth Control as the mixer... cant get the other deck to play on my headphones, and also having trouble figuring out the OUTPUTS in the properties menu of...
the outputs in Traktor should be set up like this; Chanel 1 (3&4) Chanel 2 (2&1) this set up will give you a stereo sound coming out of Traktor using Numark DJ IO. Make sure the output is set up External and the Audio Devise is Numark DJ IO.
Mar 06, 2010 | Numark DJ/iO Sound Card
Cmi8738 pci sx
Numark DJ IO with CUE ver 4.0 keep getting Error in the ASIO sound driver. how can i fix it?
Jul 01, 2009 | Numark DJ/iO Sound Card
Dj io with Traktor PRO
gvjccçznvcncbdfjcvnmcmxnfbfjgkksdfsd
Jun 30, 2009 | Numark DJ/iO Sound Card
Numark DJ/iO Sound Card Logo
704 people viewed this question
Top Numark Computers & Internet Experts
Mike
aravind shet
aravind shet
Are you a Numark Computer and Internet Expert? Answer questions, earn points and help others
