I have an outside amana air conditioner and the fan runs all the time, even when I have the themostat turned off and nothing is coming out of the vents. The only way I can turn the fan off is to swithch off the circuit at the circuit box
  • Duncan Jones Jul 05, 2010
    I found the solution: outside copressor units have something known as the "contactor". It's purpose is to supply 220 volt power to the fan and compressor. It is controlled by a 24V circuit from the inside unit. When the inside thermostat determines the air condition should turn on, the inside unit sets the circuit to the outside unit to 24V. This causes the contactor to supply 220V to start fan and compressor.
    My contactor was stuck in the "on" state so even when the input voltage was 0 (not 24V) the 220V was being supplied.
    Replacing the contactor did the trick. The Tech support guy at HvacPartsShop.com was very helpful in describing how central air units work and suggesting testing scenarios to home in on the exact problem.
    Genius:
  • 1,417 Answers
Hello
Nothing is wrong with your air conditioner i mean your air conditioner is in good form
what this mean is that there is partial contact from the wire which supply power to the air condition it self i mean your circuit box,
what you need to do from here is that unscrew and check your circuit box and locate the wire that is not well position in this box that supply power to the air condition you will fine two or three wires 1) RED,2)BLUE or GREEN 3) and any other colour in it
you are advice to check on any colour but don't the red wire because the problem is on art not supply.
Good luck and thanks for using fixya.
Posted on May 26, 2010
  • 1 more comment
  • Duncan Jones May 26, 2010
    Thanks - I see three wires( a green, a blue & a black) coming from somewhere within the unit to the actual fan motor. Are these the wires you are referring to or are are you referring to wires coming in from the circuit breaker (which is 220 volts I think). There is a disconnect switch on the wall right next to the unit (and when I pull out the black handle the unit stops). If the fan continues to run, are there other things in it that are also running, like the compressor?
    Thanks,
    Duncan
  • Oloyede Monsuru May 26, 2010
    hello
    if you have check on the and non of the wire is disconnected then you have to check
    on the wire of the fan if there is any disconnected then you will have to do the fixing as
    directed before
    if after this and all remain same this mean that the fan have brig internally which you will
    have to take care of by unscrew it and trace the core
  • Oloyede Monsuru Jun 04, 2010
    hello,
    duncan what is the condition of the fan
Air handler blower/fan wont come on.
open it up and vacuum and blow out the fan and other areas
Feb 28, 2014 | Amana ASPF183016 Multi-Position, Air...
My air cond is running but the air is not coming out of the vents, is there a reset button
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 06, 2011 | Amana Heating & Cooling
I have a Dometic A/C unit that is not functioning. The furnace won't fire up as well. Have checked all fuses etc, and installed a new thermostat and controller in the A/C unit last night ... still...
When you say your fan runs do you mean on the furnace or the outside unit? Double ck your themostat wires if you have a volt/ohm meter ck for 24 v at the contactor in the ouside ac unit. On most A/C units you can manually push the contactor in to make it contact be carefull 220v use an screwdriver to do this and push only on the plastic center if the unit kicks on your themostat/wires/or contactor is bad my bets on the wires. good luck
Aug 11, 2010 | Dometic 57915531 Air Conditioner
The Amana air conditioner is not getting cold.
when is it the last time you cleaned the unit and changed the filters? it may be working good but you need to maintain the unit...clean all filters and see if you can vacum alll parts especially the condensing unit (you may need air pressure) can you move the unit to outside so you can clean it good? if you can use air or water pressur to clean it after you cover the lectrical parts. Good luck. (save your money this unit need cleaning only)
Sep 07, 2009 | Amana PTH093B35AJ Air Conditioner
Ruud heat pump outside fan won't run
Tell him to make tight connections.
Jun 23, 2009 | Ruud UBHC Air Conditioner
Heater air conditioner unit does not expel air
unless you have zones installed i.e. day and night you will probably find that the main duct off the unit has fallen off
Jun 15, 2009 | Heating & Cooling
Small pipe running from outside unit freezing up
SOUNDS LIKE THE FAN SPEED MAY BE TO LOW SO AS THE AIR GOES THROUGH THE COIL IT WILL START TO FREEZE HAVE SOMEONE CHECK THE FAN SPEED MAKE SURE IT IS ON HIGH ALSO MAKE SURE IF THAT IS THE ONLY FILTER ON THE SYSTEM
May 03, 2009 | Heating & Cooling
OUR AIR CONDITIONER DOES NOT WORK ANYMORE. THE FAN BLOWS INSIDE BUT THE OUTSIDE UNIT DOES NOT EVEN COME ON. BUT WHEN WE PUSH THE BUTTON THAT IS OUTSIDE IT COMES ON
Your problem is the brown little wire that connects to the outside unit, Check to see if theres any broken connections (due to rodents,,,, rabbits,,,,, dog chewing the wire in-two,,,,, or HUMAN ERROR-- weedeating too close to the outside unit! Thank you very-- much!
Nov 12, 2008 | Amana Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
