Hello..I have just purchased a now printerc4200 .It works great but the printing starts with the last sheet and runs backwards.....What can I do so it prints sheet 1 first instead of last.
  • Anonymous Jun 16, 2008
    hmm. my client says he prefers it to print the last page first and the first page last (thus making them come out in proper order for print jobs over 1 page) i guess hat i mainly needed to know was whether it was a setting on the printer, the computer, either, or both.
    Genius:
  • 1,447 Answers
On the driver settting or preferences there is an option to collate print out or option to set to printin reverse order, disable that,on the application when you click file print there should be an option to disable print in reverse order
pls dont forget to rate solution, if you have further inquiries feel free
Posted on Apr 07, 2008
SOURCE:
Do cooling bed sheets actually work?
Yes, off course it works. Cooling bed sheet provides you extra cooling and comfort. If you are going to purchase bed sheets then I would like to recommend you Maspar.com. Here you can buy a wide range of designer and printed bed sheets.
Jan 15, 2014 | Furniture
Riso V800
Riso's are famous for this, i will scrub the rubber timing roll with rubber rejuvenator and clean the steel roll with alcohol.The riso paper feed clutches are weak compared to what they were in this series you may have to replace the clutch. Bud, after doing some research you need to clean the oneway bearings on the pickup and feed rolls, adjust feed table hieght and lastly check/adjust timing in drive and feed roller-you will need a manual for this.
Hope this may help;
Regards,
VOTIT
Jul 25, 2008 | Riso RZ220 Duplicator
I want to print about 20 documents and send the order to printer to do that ,continiously, and paper feed roller always pick up 3 or four sheets at the same time. When I put to print sheet by sheet it...
First off, I would fan the fan the paper (20) sheets without wrinkling them and second,...I would check your print settings to make sure they are set on Normal and not Quick Print.
You can check this by going to Start, Control Panel, Printers,...click on your printer, select properties, check your print speed there.
Need further assistance, please reply back!
Have a Great Day!
Martie
Sep 15, 2011 | Office Equipment & Supplies
Replaced the ink cartridge now it will not print
*** I'll be more than happy to help you on that.
there is a great possibility that the nozzles of your printer are clogged by dried inks.maybe cause by the previous inks that you just replaced. we can check that by printing a nozzle check pattern.
1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX110 Series. 3. Hold down the nx110_tx110_ug.1.98.1.jpg Stop button as you press the nx110_tx110_ug.1.98.2.jpg On button to turn the Epson Stylus NX110 Series back on. When the nx110_tx110_ug.1.98.3.jpg On light begins to flash, release the nx110_tx110_ug.1.98.4.jpg Stop button. nx110_tx110_ug.1.98.5.jpg 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. nx110_tx110_ug.1.98.6.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. Using the Control Panel 1. Load a few sheets of plain paper in the sheet feeder. 2. Make sure the Epson Stylus NX110 Series is on and the ink light is off. 3. Hold down the nx110_tx110_ug.1.99.1.jpg Stop button for three seconds to start the cleaning cycle, which lasts around one minute. The nx110_tx110_ug.1.99.2.jpg On light flashes throughout the cleaning cycle and stays on green when the cycle is finished. Caution:
Never turn off the Epson Stylus NX110 Series during a cleaning cycle or you may damage it. 4. Run a nozzle check to confirm that the print head is clean. You may need to clean the print head up to 4 times. You can also turn off the Epson Stylus NX110 Series and wait at least 6 hours. Then try printing again.
Feb 16, 2010 | Epson Stylus NX115 All-In-One InkJet...
Mis-alignment during printing of labels sheets
Solution!! Use "HP premium Plus Photo Paper" for the paper type setting. Works great with Avery labels & card stock as well. (business cards had the same alignment problem)
Mar 23, 2009 | HP DeskJet F380 All-In-One Printer
Prints come out blue.
You may have a faulty printhead. I just purchased a new one and had a time with it. Awful color in picture. Kodak sent me a new printhead and new ink tanks. Now it works great. You may have printhead trouble also, contact Kodak for help.
Dec 11, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
The printer is printing blank sheet
Hello Shirelle,
Make sure there is nothing covering the jets on the cartridge. Also how long has it been laying around? it might have dried out, and/or expired. On new printers the cartridges have expirations and it will not use them after a certain amount of time. Also try a printer self cleaning and see if that does anything. If none of that works, it might be the printer. - Vincent
Nov 23, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Roller Marks
Try this to clean the rollers:
Put in blank sheets of paper in then print out from microsoft word a blank document.
This should clean the rollers. Also, there might be special cleaning sheets that you can purchase from Epson.
Oct 29, 2008 | Epson Stylus RX500 All-In-One InkJet...
Label Printing
I had the same issue when using Avery labels, here's what resolved it for me.
Go to Control Panel, Printers, go to the active default, right mouse click, click Printing Prefrences..., change the drop down "Type is:" to 'Other Photo Paper" and apply.
You should then be good to go!
Feb 10, 2008 | HP DeskJet F380 All-In-One Printer
190 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
