Question about British Telecom Response 75 Digital Answering Machine
My response 75 since having ablip in power was
My response 75 since having a blip in power was displaying a 8 and now its displaying a y. I have unplugged everything and removed the battery, but when i plug power in the Y comes back. You can`t do anything with it.
We found the problem was with the power. In our case, plugging the adaptor into the power outlet directly, bypassing an extension and checking the outlet was working with a lamp. The error lights you describe were the exact same that we were getting, caused by low battery levels.
Hope that helps someone.
Posted on Jul 15, 2010
Zone 2 Amplifier Need
Reread the detailed answer provided in response to your earlier post on this issue
Jun 10, 2013 | Pioneer VSX1020K Receiver
No buttona work on the board just says 88
The 88 in the display most likely means you have a stuck or shorted keypad.
If the control senses a keypad pressed for more than 75 seconds then it will display an 8 error.
There is a membrane/interface test that you can enter and run if you don't mind a little do-it-yourself.
The image below will show you how to enter and run the membrane test.
If you can not enter the test or some keypads are not responsive then you will need to replace the console/membrane. You can obtain the console from this link.
Dec 05, 2010 | Maytag Neptune MDE5500AY Electric Dryer
What is the voltage polarity ac or dc of the power adapter for SP-613 speakers?
this is actually the product description for your speaker
Product Description
Front
Speaker Unit: 1inch +6.5inch *2+8inch
Power: 10-100W
Sensitivity: 88 dB
Impedance: 4 ohm
Frequency Response: 45-20K Hz
Production Size: (H*W*D) 1087*210*336mm
Package Size: (H*W*D) 1162*500*400mm
CENTRE
Speaker Unit: 1inch +4inch *2
Power: 10-60W
Sensitivity: 86 dB
Impedance: 8 ohm
Frequency Response: 75-20K Hz
Production Size: (H*W*D) 160*500*179mm
SURROUND
Power: 10-60W
Sensitivity: 85dB
Impedance: 8 ohm
Production Size: (H*W*D) 225*160*158mm
Package Size: (H*W*D) 550*273*415mm /3PCS
ACTIVE SUBWOOFER
Speaker Unit: 10inch
Impedance: 8 ohm
Crossover Point Control
Handling Power: 120W
Production Size: (H*W*D) 405*328*350mm
Package Size: (H*W*D) 465*330*465mm
Jun 24, 2010 | Juster SP-615 Computer Speakers
I am trying to find the output power, watts?
bad transformer. A $10 part at most electronic stores. U fried it when you dropped it. Happens all the time.
Jun 08, 2010 | Audio Players & Recorders
Need 1996 escort 75 stereo wiring diagram please the wires are odd colours
iam colour blind ,quickest way i have found is a test light for the feed wires ,and the speakers are easy ,just use a plus and minus off the battery and when you have the blip sound then you know what speaker it is
Apr 25, 2010 | 1997 Ford Escort
Toshiba PA3362U laptop wont start up ? My son left it turned on for 10 days without my knowing. I try to start uo but the inly response is alittle flashing light at the front and that stopsafter a few...
Make sure your plugged in and the battery is charged up. Usually the laptop won't stay on for ten days because the battery needs recharging. Press the power button for about 5 seconds then try pressing the power button again to restart what happens?
Jan 09, 2010 | Computers & Internet
The display panel want work.
LOOK MIN TH EBACK ON THE MAIN CONTROL BOARD AND THERES A FUSE THAT YOU MAY HAVE BLOWN
Mar 07, 2009 | Samsung RF265AA Bottom Freezer French Door...
What are the correct spaekers for the gm 5100t ?
    CEA-2006 Compliant Amplifier Power Standard:
  • 125 Watts x 2 @ 4 ohms <= 1% THD+N
  • 380 Watts x 1 @ 4 ohms BRIDGE <=1% THD+N
  • 75 dBA Signal-to-Noise Ratio
  • Peak Music Power: 250W x 2 (4 ohm) / 760W x 1 (Bridge)
  • 2 Channels
  • Continuous Power @ 4 Ohm: 125W x 2
  • Continuous Power @ 2 Ohm: 190W x 2
  • Continuous Power Bridged @ 4 Ohm: 380W x 1
  • Frequency Response: 10Hz-50kHz
  • THD (1kHz, 4 Ohm): <0.015%
  • Signal to Noise Ratio: >95dB
  • Dimensions: 11 13/16” x 2 3/8” x 12 7/8”
  • PWM Regulated MOSFET Power Supply
  • Balanced Isolator Input Circuit
  • Oversized Screw-Type Power/Ground Terminals
  • 2 Channel RCA Inputs
  • Speaker Level Input
  • Screw-Type Speaker Terminals
  • Hi-Volt Input Level Control (200mV-6.5V)
  • Bass Boost (50Hz, 0/6/12dB)
  • Selectable LPF (80Hz, -12dB/Oct.)
  • Pioneer 1-Year Warranty
I'm assuming the subwoofers were bridged and couldn't handle the power. Make sure you have atleast 300 watts peak power wattage.
Feb 05, 2009 | Pioneer GM-5100T Car Audio Amplifier
Amplifiers esc200
Hi! The fact that the LCD has power implies that the fault is in the Power Amp-Speaker stage.
Check 1: Check that your speakers are connected to the amplifier output properly.
check 2: If connection is proper check for power on/power off blips. If blips are heard the Power amp /speaker stage is ok .
check 3: If power on/off blip is heard then you have to check the source stage i.e CD/radio etc
Check 4: if blip is not heard. Disconnect the speaker and try with another. eliminate the case of a blown speaker by testing speaker on another system.
check 5: if speaker and source are ok. Treoubleshoot the amplifier Power supply stage with the followinghttp://www.howtodothings.com/electronics/how-to-fix-the-fuse-on-your-guitar-amplifier
check 5: if the power supply to power amp stage is ok troubleshoot the power amp stage with this guidehttp://www.howtodothings.com/electronics/how-to-fix-your-guitar-amplifier
If you still face problems feel free to contact me
Jul 01, 2008 | JBL ESC200 Shelf System
British Telecom Response 75 Digital Answering Machine Logo
159 people viewed this question
Top British Telecom Lands Phones Experts
honeybun1986
Are you a British Telecom Lands Phone Expert? Answer questions, earn points and help others
