Question about Dewalt D51850 20° Full Round Head Framing Nailer
Round head framing nailer. shoots 2nails
Starts shooting 2 nails at a time, when you get about 2/3 of the way through a clip.
    Sergeant:
  • 233 Answers
Check to make sure the striker bar is not marred or bent. This can cause two nails to be driven at once.
Make sure you have the right kind strip nails.
Some brands (Cheaper bundles) tend to do this alot!
Hope this helps!
Posted on May 27, 2010
Can My FC 350 A used 28 degree nails
The manual for your gun specifies 34-degree nails from 2 to 3 1/2 inches long. 28-degree, wire collated nails are a Stanley-Bostitch thing and they only work in their nail guns, they will not work in your nail gun. You need 34-degree, paper-tape collated nails. I know Senco framing nails will work in your gun and I think Duo-fast makes 34-drgree nails but check that before buying them.
Mar 03, 2013 | Porter Cable Factory-Reconditioned...
My clipped framing nailer will shoot two 2 3/8 at the same time. what do I need to repair this gun?
I would look at the nail collation and nail angle first. If both OK for this tool, remove all the nails and air hose. Bounce the tip and see if the driver falls down on its own and if it does the o ring is worn and would need replaced. When inside the tool look for other wear items.
Mar 04, 2012 | Dewalt Clipped Head Framing Nailer
Shoots 2 or more nails at a time
Happened to me awhile back...just load few nails..it tends to shoot to many when you load it full. break a section in half load it and it should shoot just fine.
May 27, 2010 | Porter Cable BN18200 2" 18 Gauge Brad...
2 nails shoot at the same time
It could be just from using poorly clipped or collated nails. I have noticed that with some cheaper nails, the clipped heads are not all lined up properly. If a nail has rotated slightly during the collation proccess, the unclipped portion of the nail head protrudes over the previous nail in the clip. This causes the heads of two nails to be struck at once. Another problem I've encountered is collation wire that doesn't shear off with each nail. An ever lengthening strand of wire protrudes into the nail chamber and eventually the driver snags this wire as it drives a nail. This jerks the clip forward forcefully forcing more than one nail into the chamber or causing the next nails in line to rotate slightly, thus exposing the unclipped portion of the nail heads to the driver.
Mar 13, 2010 | Tools & Hardware - Others
Need to know size nail that it shoots and do you have new lables for the gun
This gun takes 2"-3 1/4" .113" - .131" Paper striped 34 degree clipped head nails.
This is the Tool Card provided by Hitachi. Follow link:
http://www.hitachipowertools.com/product/files/pneumatics/framing_nailers/NR83AA3toolcard.pdf
Sep 07, 2009 | Hitachi NR83AA3 3 1/4" Clipped Head...
DeWalt d51822 framing nailer, shoots 2 nails at once 1 in 5 times
I worked at at tool rental center while attending college and learned from the old tool masters about nails and nailers. Rental stores have many different brands of nailers to rent and customers would bring their own nails of all brands. You will notice on the case/box that your nails will /should work on many other brands however the degree or angle of the nails is not always exacly as stated on the box. You should check with protractor the exact angle of your nails and also check the exact angle of the nailer. Use straight edge on travel path of the piston and another on guide rails to check angle of the gun. You will discover that all is not as stated as in a perfect world. If the angle is off slightly, the head of the second nail will get into the path of the driver. This happens mostly with clip head because the nail heads are so close together. The full round head is spaced further apart with less jamming. If angle is off slightly, take a look at other brands of nails with protractor in hand, the angle will be different slightly or choose a slightly thicker nail. Look for the nails to fit with bottom of nail hitting the barrel first. This will move the head of the nail slightly away from the center line. Finally do not release pusher with force as this will jamb nails closer together. Good Luck!?
Jun 03, 2009 | Dewalt Heavy - Duty 31° Clipped Head...
Nails ride over each other and don't shoot straight
Check and make sure your using the right nails. Are they held together with plastic? This should be a 21* full round head nail with plastic collation
Mar 10, 2009 | Hitachi NR83A2S Framing Nailer, Full Head,...
Craftsman 16 guage finish nailer. shoots 2 nails at a time. what
wrong gauge nails or wrong head type nails check that the magazine is not loose
Jan 09, 2009 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Dewalt D51850 20° Full Round Head Framing Nailer Logo
164 people viewed this question
Top Dewalt Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dewalt Air Tool and Compressor Expert? Answer questions, earn points and help others
