Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
Trying to set up my wireless router after moving.
I have yellow wire going from my modem to the wireless router and then from the router a yellow line going to the computer. Not working.
    Brigadier General:
  • 10,406 Answers
Modem <-- cable --> WAN port on router.
LAN port #1 on router <-- cable --> network-port on your computer.
Turn the modem off.
Turn the router off.
Turn your computer off.
Turn the modem on.
Wait until its lights "settle" down to a regular pattern.
Turn the router on.
Turn the computer on.
Wait until Windows has booted completely.
You should now be "up", with Internet access.
Posted on May 26, 2010
    President:
  • 676 Answers
Hello my name is Israel and I will be glad to help. First be sure that the modem is up and running. You should have green lights on your modem. Once you are sure that the modem is up and running, you will need to contact your interent service provider. Ask them to remotely reset your modem. They will ask you why, explain to them that you are setting up a router and need to have it reset. Once they complete the operation you should be able to continue your network setup. Good luck, Please rate.
The router keeps cutting off. I have another one and am trying to get the Yellow wire off, How???
The RJ45 connector on your network cable is like a big Phone plug (RJ11). It has latch on the top that must be pressed down to remove it from the socket.
The wire should go between your cable or DSL modem port which should only have one to the WAN port on your router. It probably has 5 ports. Some numbered 1-4 and the WAN or Internet port.
The router restarting maybe set up wrong, could have a bad power adapter or it could be defective.
Apr 05, 2014 | Linksys Wireless-G WRT54G Router
I just moved and trying to hook up my laptop to modem and wireless router but can't get the modem to work without the wireless.
When you move somewhere else you have to configure the laptop for that region's phone line.Go into control panel and into internet connections.Go to" set up an internet connection"This will take you through the set up procedure.THE IMPORTANT THING IT WILL ASK YOU IS YOUR REGIONAL CALLING CODEI.E. 0208 IS THE OUTER LONDON CODE.
Aug 07, 2010 | Arris SURFboard® SB5101 Cable Modem
I just starting using this wireless router and when I set it up the router software keeps saying I don't have a connection to the internet but I'm on the internet on that computer right now. ...
Make sure that there is not direct connection between your desktop and modem ( USB ). If there is any USB connection from the modem to the computer then it will go on linee but the router will not be on line.
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
Apr 30, 2010 | Linksys Wireless-G WRT54G Router
I have recently moved from Pittsburgh, PA to Charleston, SC. My linksys Wireless G 2.4 gHz router worked great with the ISP in Pittsburg (Comcast). Now, with Time Warner's Road Runner, I get an error and I...
Connect your main cmoputer directly to the time warner modem. make sure that your computer will be able to go on line when connected directly to the modem. If not then call Time warner.
If your computer is able to go on line when connected to the modem then your modem is working properly. You will need to change the settings of the router.
First reset the router for 30 seconds. On the router you will find a small reset button. Hold it down for 30 seconds. release it. wait for 1 minute. now unplug the power to the router and plug it back in. wait for 30 seconds till the power light on the router will be solid.
Now connect the modem and the computer to the router.
Now you will need to clone the MAC address of your main computer to the router. you will neeed to open the set up page of the router.
once your main computer is online , you can change the wireless settings of the router and connect to the wireless network on the laptop.
Click here for step by step solution
Apr 10, 2010 | Linksys Wireless-G Broadband Router
I am trying to reinstall a netgear wgr614v9 router. when i hook it up to my modem the internet light stays yellow and i can't connect to the internet. i did change the DNS settings in the router a couple...
Mar 13, 2010 | NetGear WGR614 Wireless Router
I had to move and I took my NetGear WGR614v9 Wireless router with me. How do I hook it back up? I have DSL, which is what I had at my prior residences.
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
Then you need to connect the computer to the router and the modem to the router.
Click Here for step by step by instructions
Feb 16, 2010 | NetGear WGR614 Wireless Router
Dsl modem network cable attached modem icon
Are you trying to set up the router ?
First make sure that your computer is online when connected directly to the mdoem. ISP is DSL.
If not online through the modem then you should have user name and password for the ISP.
try to reconfigure the router.
Click Here for more info about router set up.
Nov 19, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Can't get a wireless router to work with a speedstream 4200
This may actually be an issue with your ISP. There is a good possiblity that your ISP has bound your connection to the MAC address of the network card on your computer. This is a common occurance which is why router manufacturers give you the option of having your router clone your computer's MAC address. Go into your router's management an perform the clone, sorry I cannot give you more details but I don't know the specific model of your Belkin router.
Jan 05, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Belkin N Wireless Router doesn't connect to Modem
If router is brand new you should have a set up disk. the set up disk will walk you through it or you might log onto Belkin site to see a walk through set up. If you can access internet from modem to router to internet. That means router is functioning properly. To go completely wireless you will need to secure your network and setup your access codes. Definitely use the setup disk to do this. A unsecured wireless network is a nightmare waiting to happen. Good luck
Sep 01, 2008 | Belkin Modem connector (R6G064-R-50)
We bought a wireless router can you help me set it up where do the wires go
Hello, The wire from your cable modem plugs into the WAN (labelled "connect to modem") port on your wireless router. You then need to install the software on your PC to set up the router.
Sep 30, 2007 | Belkin (F5D9230-4) Wireless Router...
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
90 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
