Question about Whirlpool Washing Machines
My whirlpool top load washer is leaking out the front side, no hoses are leaking.
  • Whirlpool Master
  • 3,051 Answers
Hello there:
Your washer can develop several types of leaks. I will post this solution in 2 seperate posts for you ok?
You can track down a leak based on when it occurs:
During fill only If the washer leaks only during the fill cycle, check these: Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it. The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak. Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak. During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details. All the time If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Posted on May 27, 2010
  • Michael Thomas
    Michael Thomas May 27, 2010
    Main tub seal - The main tub seal is located between
    the transmission and the outer tub. It's the primary water seal in the
    outer tub for the transmission-shaft entry point. If this seal leaks,
    you can see the leak by opening up the machine's main access panel while
    the machine is full of water with a small amount of detergent in it.
    The leak appears at the underside of the outer tub, at or near the
    center. This seal is difficult to replace. You probably should call a
    qualified appliance repair technician.
    Pump - If the pump leaks, you can probably spot the
    leak when the tub is full of water. The pump has two or more black
    rubber or plastic hoses attached to it and usually has a drive belt that
    spins the pump. If the pump is leaking, you need to replace it.
3 Suggested Answers
  • 291 Answers
SOURCE: 4 year old Kenmore 110.26442501 top load, 2 speed leaks at front
I answered this earlier but you may not have got it. Again it sounds like a leaking water pump. The easiest way to find this problem is to remove the outer case so you can see where the leak is coming from. This washer has a very cool design to get into the mechanism. Unplug the washer. The top console,(where the controls are), flips up. Usually you have to take out two screws on each of the front corners of the console and then pull the console forward and up until it flips upside down. Disconnect the lid switchwiring harness, this is usually a three wire plastic connector. Don't confuse it with the power cord plug, If you are not sure then follow the power cord where it enters the washer and you will see which one is its terminal connector plug. Take a large flat screw driver and stick it into the left and right hand slots that have the brass retainer clips . You stick the screwdriver straight down and then pry the clips out by pushing back on the screwdriver. Remove both clips, grab the outer washer cabinet and tip it towards you, at a 45 degree angle you can slide the front of the cabinet out from under the base and remove the whole cabinet. Plug the washer back in. Now you can start the fill cycle and look for leaks. Usually it is going to come from the water pump or the fill valve. If the washer fills and agitates with no leaks then you will have to unplug the washer again, jumper the lid switch wiring block, and plug the washer back in so you can test the pump out and spin cycle. Be very careful as you now have a high speed spin with no safeties, to keep you from reaching into the mechanism and getting your arm ripped off. Look for the leak and unplug the unit. Replace the bad part and reinstall the case, making sure that the back side corners of the case are pushed inwards and sitting on the base plate. Reinstall the clips by hooking them into the back panel first and then pushing down on the clip until it clicks in place. Plug your wiring harness back in, flip the console basck down and reinstall its screws. Good Luck, Appliance Specialists
Posted on Jan 03, 2010
SOURCE: Whirlpool Washer Leaking
Opened the Washer and found there was a leak in the pump. Got an M-Seal and just put it on the leak. 45 mins later the machine was in action again.
It took time for me to figure out where the problem was, once you know exactly where it is you should be able to fix it.
Posted on Feb 01, 2010
Maytag washer leaking between cycles or if stopped during fill
lift the top up on the washer and see if the fill hose is crack or broke,hose on right side
Jun 18, 2009 | Whirlpool LSN1000LW Top Load Washer
Leaking washer drain pump
Yes, the drain pump is a common leak area.
2 clips, 2 hoses and it pulls off.
If it has leaked for a long time you will have to get aggressive to get it off.
Feb 21, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool washer leaks
do not remove the top panel. First tip the washer back. NOT ALL THE WAY. just enoough to see under it. you will see a pump. it is attached by 2 hoses. one to the tub and one to the drain. take the 2 clips off with the hoses still attached. tip it downward. Is water leaking oout of it? let me know thanks
Feb 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Water leaks
If there is water leaking from under the washer, then you have a water leak from one of your water hoses. Check the back of the washer, where the water comes into the washer, to see if its leaking water or the hose is cracked. If its leaking water from the intake hose, then unscrew the hose and check the rubber washer, to see if it needs reolaced. Sometimes those rubber washers get cracked or broken. If that doesn't help, unplug your washer from the power cord and unscrew your intake water hoses and flip the washer gently on it's side and check the water hoses under the washer for leaks or cracks. Replace the hoses if cracked. Your local hardware store should have replacement hoses. This should solve your problem, but if not, then you need to call a washer repair person to look at it. I hope this helps.:)
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool fron load Duet washer leaks
Check the easy stuff first, fill hoses tight?- drain hose cracked? Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker.
thanks.
Oct 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine Whirlpool Lsn1000pq1
My washer is doing the same thing. I put it up on blocks so I could see where it was leaking from. On mine it was leaking from the pump which a big white piece of plastic in front of the motor. The pump has two hoses connected to it the **** the water out of the tub and pump it out the drain hose. Disconnect the two hose clamps, remove the hoses (use force). There are two spring clips on top and one bottom. I laid mine on it's side to remove them. There two slots one top, one bottom for you to use when prying the clips off. Place screwdriver under clip and between grove and push/pull until they come off. Carry pump to the sink, fill with water and see if it leaks from somewhere, should be obvious.
Jun 01, 2008 | Whirlpool LSN1000LW Top Load Washer
Cabrio he toploader leaking on towel/sheet cycle only
It is possible that the dispenser is leaking. It is typically the left front dispenser, you may notice a puddle on the left side. ???
Jan 09, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool washing machine
If this is a front loading machine, take the plug off the wall. Remove the screws of the panel behind take off the panel; check to see whether any hoses hav come loose, tighten, refit.
Sep 11, 2007 | Whirlpool LSN1000LW Top Load Washer
Whirlpool LXR94 leaks in front left
Taking the back off any washer rarely helps. Most are accessable from the bottom (you have to flip the machine on its back PLEASE BE CAREFUL, check the pump hoses (normally attached by clips to the motor assembly). As far as calling the dealer, you have to decide if its worth your time and effort.
Jul 08, 2007 | Whirlpool LXR9445JT Top Load Washer
Washing Machines Logo
371 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
