Question about Whirlpool ACQ158XP Wall/Window Air Conditioner
How many Btu's is this unit - Whirlpool ACQ158XP Wall/Window Air Conditioner
  • 28 Answers
Between 1 and 1.25 tons, 14,700BTUs
Posted on May 26, 2010
Can a Fujitsu compressor unit be connected to multiple inside evaporator units that have different tonnage ratings. 18,000 BTU compressor and 9,000 & 12,000 BTU evaporator units inside.
call fujitsu engineering division direct and ask them about what is connected and if it works ok
logically as each evaporator has it's own tx valve as long as the compressor is large enough to run all together it should work but get the right information from the fujitsu experts
Oct 11, 2016 | Fujitsu Heating & Cooling
What is the BTU of modelM6FQ10F2A
the btu rating will be on the same plate as the model number
if there is no btu rating but a kw rating then there are conversion tables to work it out
for example a 2kw unit is close to 9000 btu and a 8kw unit is around 32000btu
May 23, 2015 | Heating & Cooling
I have a contractor that wants to install a 36000btu outdoor unit(model # mh080fxca4a) and two indoor 18000btu indoor units(model #mh052fnca). What would be the output of the outdoor unit? The contractor...
Yes it rated for a maximum out put of 36,000 btu (3 ton) with the right indoor fan coil units which based on the model numbers should give the 36,000 btu's combined when both fan coil units are on, otherwise 18,000 btu's (1.5 ton)per fan coil.
Aug 23, 2011 | Samsung Heating & Cooling
I have an oddball question. What does a 3-ton A/C unit weigh? I know its not 3 tons.
Not every 3-ton unit weighs exactly the same - they differ in weight depending on how they were manufactured. Most 3-ton units weigh around 150 pounds (I would guess) give or take a few pounds.
The "3-ton" refers to the "cooling capacity" of the air conditioner.
It's actually 'slang' for 36,000 Btu.
Note; 12,000 btu equals 1 ton.
Hence a 24,000 Btu unit would be called a "2-ton unit," and a 12,000 Btu unit would be called a 1 ton unit.
Aug 05, 2011 | Heating & Cooling
I have a Maytag window unit and i am trying to find out how many btu is has. right now it is in a small room and i want to know if it will work in a bigger size room. MODEL M6Q1OF2A SERIAL CR 264327...
that is a 10000 btu unit and a good rule of thumb to go by when 'sizing' a unit is 12000 btu for every 600 sq ft of cooling space (if the place is well insulated) or 400 sq ft (if not well insulated).
So, you have a 10000 btu unit which is 5/6th of 12000 btu - so - can reasonably expect that unit to cool approximately 500 sq feet.
In other words the room it's in now could be only - say - 300 sq feet (and well insulated) - in which case the AC unit is cooling it - well.
However, if you try to cool a 800 sq ft room - it will not work as well.
Hope this has helped.
Aug 05, 2011 | Maytag M6Q10F2A Air Conditioner
How do I find out how many "tons" my Carrier AC units are?
Look in the model number for numbers like 24, 30, 48, or 60....
They represent the BTU's in thousands of the unit....
The BTU's are 12,000 per ton...
in other words a 24000 BTU unit will be a 2 ton unit
heatman101
Jul 29, 2011 | Carrier Heating & Cooling
How many tons is my unit?
divide your btu rating by 12000. (1 ton = 12000 btu)
For example - a 24,000 BTU Air Conditioner is a 2 ton unit. 24000 divided by 12000 = 2
A 18000 btu air condtioner is a 1 1/2 ton unit 18000 divided by 12000 = 1 1/2
you can find out your btu rating by looking on the tag on your unit.
Jun 07, 2011 | Heating & Cooling
What is the meaning of BTU?
British thermal unit: a unit of heat equal to the amount of heat required to raise one pound of water one degree Fahrenheit at one atmosphere pressure; equivalent to 251.997 calories. The amount of heat needed to raise 1 pound of water 1 degree F (equal to 252 calories).
(British thermal unit) Describes the heat value of fuel for appliances - the higher the BTU, the more heat available for cooking.
A Btu is equivalent to 252 calories and serves as the base unit for measuring the heat content of a fuel source.
-The Ugly Pool Guy www.wefixuglypools.com
Dec 09, 2010 | Pentair Minimax Ch 400,000 Btu Propane...
WHAT DOES 12000BTUh MEAN OR REPRESENT IN AIRCONDIONING terMS? eg 12000 or 10000
I found this explanation which I certainly couldn't improve on.
The British thermal unit (BTU or Btu) is a traditional unit of energy. It is approximately the amount of energy needed to heat one pound of water one degree Fahrenheit. One Btu is equal to about 1.06 kilojoules. It is used in the power, steam generation, heating and air conditioning industries. In scientific contexts the BTU has largely been replaced by the SI unit of energy, the joule (J), though it may be used as a measure of agricultural energy production (BTU/kg). It is still used 'unofficially' in metric English-speaking countries (such as Canada, the United Kingdom), and remains the standard unit of classification for air conditioning units manufactured and sold in many non-English-speaking metric countries.
In North America, the term "BTU" is used to describe the heat value (energy content) of fuels, and also to describe the power of heating and cooling systems, such as furnaces, stoves, barbecue grills, and air conditioners. When used as a unit of power, BTU 'per hour' (BTU/h) is understood, though this is often abbreviated to just "BTU".
I located it at this site all credit for this info is:
http://en.wikipedia.org/wiki/British_thermal_unit
Hope this is what you need,
RSMITH972278
P.S. PLEASE RATE ME !
Oct 18, 2009 | Heating & Cooling
Just put in a new ac unit and replaced a old one. old unit was 18000 btu and the new one is on 12,000 btu I used the same power outlet but the new ac unit starts up but then shuts down and seems like it is...
The 18,000 btu A/C is 230 volts, are you sure the 12,000 btu unit is 230 volts most are 120 volts.
Usually 12,000 btu is the biggest 120 volt A/C you can buy.
Jul 10, 2009 | Heating & Cooling
Whirlpool ACQ158XP Wall/Window Air Conditioner Logo
32 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
