Question about Whirlpool Duet GHW9150P Front Load Washer
Model GWH9100LQ The outer plastic tub is leaking, has a hole in it, rear piece near R/R shock Can this part be replaced?
  • 183 Answers
SOURCE: Hotpoint washing machine outer tub moulding
The only way to resolve is to replace the outer tub, no other permanent sollution, what hotpoint mean is that you would not have to replace whole outer drum only the front half.
Posted on Dec 25, 2007
  • 3 Answers
SOURCE: TOP LOAD WHIRLPOOL WASHER BRAND NEW CRACK IN OUTER PLASTIC TUB.
loosen the screw bolt located at the back cover,it has also a plastic lock in the side to side of the plastic cover,find it by sliding a small flat srew.
Posted on Feb 21, 2008
  • 101 Answers
SOURCE: Frigidare gallery front loader modle #417.39012890
No. with the cost of the parts that you purchase it would almost like buying a new one., and besides the other parts is waring out.
Posted on May 12, 2008
burzerko
  • 254 Answers
SOURCE: Repair to hole in washer plastic drum.
If you find a good plasticizing epoxy it should work great for this most plastic epoxies can withstand temperatures up to 500 degrees F. I dont see the hot water supply feeding the machine getting any warmer than this. Another option would be to find someone with a plastic fusion and filler welder and just weld the hole shut with a base material.
Hope this helps Ya
Posted on Jul 03, 2008
docjohn174
  • 943 Answers
HI the agitator comes off. 7/16 bolt under cap remove pull agitator off. now you take off that big nut in the middle. remove. pull tub out. replace the tub. thanks
Posted on Oct 15, 2008
Washing machine is leaking from the bottom of the tub. model flse60rgs1
Hello there diana and welcome to fixya
Your washer can develop several types of leaks. You can track down a leak based on when it occurs: During fill only During drain and spin only All the time During fill only If the washer leaks only during the fill cycle, check these: Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it. The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak. Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak. During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details. All the time If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Dec 18, 2011 | Kenmore Washing Machines
My washer has leak more and more over the last few months. Model # LW8203W2. What do you think the problem may be? any help appreciated.
Hello there:
Dec 20, 2010 | Kitchen Ranges
I have a whirlpool Duet washer model GHW9150PW0 that began to thump during the spin cycle. I removed the front and it appears the inner tub is off-center or out-of-round. Further, it has worn off the...
There is a lifetime warranty on this main basket. and 10 years on the outer front and rear buckets. My unit is 7 1/2 years old. and had the same problem. One of those 3 spokes connecting the main shaft to the rear bucket cracked and killed the front outer bucket. Whirpool tried to tell me I needed a professional to diagnose it but I told her the rear outer bucket was cracked, leaking water, and shredded the front outer. She sent me all three parts for $0! It took 2 hours to get apart and that was me being super careful. The parts will be here tomorrow morning! I did needd to buy 2 shocks at $21.00 each.
Dec 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water leakage under washer in the rear
It leaks Your washer can develop several types of leaks. You can track down a leak based on when it occurs: During fill only During drain and spin only All the time During fill only If the washer leaks only during the fill cycle, check these: Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it. The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak. Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak. During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details. All the time If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Jan 31, 2010 | Washing Machines
Something rolling inside the Drum
The rear half of the outer tub, with bearing is part # 131525500 and it looks like the back "spider" shaft is not available as a separate part from the inner drum. The "spider" shaft is most likely worn or damaged and in need of replacement also.
131618500
Then, there's that strut
134564200
Now, two pain in the back side hours of your labor and you've got your washer back, at more than what a new one would cost! Junk it and get a new larger capacity front loader.
Please don't rate this, as anything but the top rating will lower my score. I'm just giving you my honest opinion, that your machine is not economical to repair. I've owned a LG front loader for over 6 years and think they are the best, but there are other good front loaders out there also.
May 19, 2009 | Frigidaire GSTF1670A Front Load Washer
Noisey during spin
yes you are right noise during spin cycle is due to faulty bearing. If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly  and the outer shell with the tub bearing.
Sometimes the inner basket support will crack, this can give an clicking or banging noise as well.
Pictures of this job...
A sure indication was the brown junk/gookus leaking out if the rear bearing area and the belt has spewed it around in the drum that the rear bearing and seal was bad...
Picture1 - Picture2
The whole outer shell and basket come out to do this repair....what bad bearing and rusted shaft looked like...
Picture1 - Picture2 - Picture3
I had to remove the back panel. Undo the pump hose & water level hose, remove the 2 shocks, remove the motor, undo the front boot from the outer panel and remove the 2 springs to lift the whole assembly out from the back to work on it.
Picture1 ( boot pushed inside ) Help page1 - Help page2
During fill only
All the time
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
May 07, 2009 | LG WD-16115FD Front Load Washer
The washer leaks from undrneath. It is below the two hoses. The paticular part is plastic and has a metal strap.
Check the easy stuff first, fill hoses tight?- drain hose cracked?
Failing those checks, cut a piece of cardboard slightly smaller than the size of your washer. Slip the cardboard under the washer and run a short load. Look carefully at the water mark on the cardboard. The mark on the cardboard the water leak will leave, will help you tell from which side or front to back the leak is common from. This will help point you in the correct direction to look for the trouble maker.
During fill only
All the time
May 03, 2009 | Washing Machines
Maytag Neptune leaks several hrs. AFTER I finish using it.
if that is checked then ---------------
During fill only
All the time
Apr 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Fisher and Paykel Washer Leaking
For those with water on floor after wash, check my post on "eco smart won't drain, smells hot". It could be something clogging drainage area at very bottom of the tub. I couldn't see the sock that was stuck in my FP's drain when I looked from the top between the white outer tub and the wash tub--everything looked fine. Then I removed the black motor/white plastic housing piece--Tip back washer and you should see this black electric motor/white housing on bottom. see my post for how to remove and check for plugged drain. it's really pretty easy.
don't know about outer tub holes, but glad i don't have that problem.
i hate my fisher paykel washer/dryer. i can't wait to sell this house--i will leave them here and get a new front load Duette for my next house!
May 31, 2008 | Fisher Paykel EcoSmart GWL15
Whirlpool awm 049 washing machine
If the washer leaks only during the fill cycle, check the following:
Air-gap device: The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube:There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout:Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
During spin cycle only:
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Look at the entire hose and correct any problem you find. Also, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make.
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it.
Pump: If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Main tub seal: The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Outer tub:The steel or plastic outer tubs can rust, split, develope a hole in some way. If this happens, you may have to replace the outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Feb 07, 2008 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
41 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
