Question about Dell OPTIPLEX GX60 Motherboard
I have optiplex gx60 desktop system running
I have optiplex gx60 desktop system running celeron 2.4ghz in the 478b socket I have a p4 2.6ghz Northwood is there any reason this upgrade will not work?
  • 2 more comments
  • c d holiday May 26, 2010
    Well I tried it It started to boot then on the windows XP start up page the sliding bar froze. so I powerd down then tried the original Centrino cpu again! when swapping out the P4 I noticed the heat sink was was VERY hot and on pwr up the bios reported a over heat shut down and the system powered off. now on power up I get the p/s fan , the cpu cooling fan and the pwr available light on the m/d the p/s voltages are all there but there is no video and absolutely no temp from the CPU heat sink. My next step will to verify the VCC on the socket. Any other ideas?
    You state it will only be 8% faster I was under the info that the True P4 vs the centrino made an great computing difference? it is not about the 2.4 -> 2.6 speed.
  • c d holiday May 31, 2010
    OK I have verified the 1.525v on the cpu socket AF-4 and both the celeron 2.4 and the P4 2.6 chips do not fire up and there is no temp on the heat sinks. Does this indicate the M/B is dead or what else can I look at? all the p/s voltages show good.
  • c d holiday Jun 01, 2010
    MAkes sense. I think I have found my problem ON this GX60 Dell motherboard there is a levered 478 socket and a seating lever fot he heat sink I do not feel comfortable with the cpu seating in the socket properly (THE CHIP IS AFFIXED TO THE HEAT SINK) with old heat compound. so with the socket level down and attempting to insert the chip I do not feel comfortable with the CPU seating properly. It looks like I have to insert CPU the lock in the heat sink (of course with heat compound) then rotate the heatsink locking lever/ IN THIS CASE how is the best way to remove old (hardened) heat compound from between the cpu and heat sink so I can position both pieces separatly & correctly?
  • Dell Master
  • 11,800 Answers
No problem, it's the same generation so it will work just fine.
Posted on May 26, 2010
  • 1 more comment
  • Azrael SRL May 27, 2010
    When putting the new cpu did you smeared it with thermal paste before attaching the cooler ? Its absence is the usual cause for processor overheat. Yes, you should also check the Vcc - it should be set to 1.5 volts
    BTW you will get about 40% more power by upgrading since the difference in performance is ruled mainly by design of the cpu and far less by its actual speed.
  • Azrael SRL May 31, 2010
    1.525v is higher than normal but nothing to worry about, maximum tolerable is 1.55v. What you should worry about is the fact that it fails to work with both processors. Last hope: reset the BIOS, remove the hard disk and try to boot into BIOS - if it fails even now then the mb is dead.
  • Azrael SRL Jun 01, 2010
    Put the cooler on a solid table and ask a friend to hold it tightly.Clean every trace of old paste you can reach(start with a q-tip soaked in thinner and end up with a tooth pick).  Take a very fine razor blade and push it gently between the base of the cooler and the metal cap of the processor from different directions, it will pop out. Then clean it thoroughly.
    Brigadier General:
  • 10,406 Answers
No, it should work. If it does work, then your computer will only be 8% faster.
If it does not work, then inserting the "new" CPU should _not_ damage your computer -- you can "revert" to the old CPU, and continue to use your computer, if your "experiment" with the new CPU "fails" to work.
  • ikkenom Jun 01, 2010
    >> ... it will only be 8% faster I was under the info that the True P4 vs the centrino made an great computing difference?
    >> It is not about the 2.4 -> 2.6 speed.
    Well, it is, and it isn't.
    Take a 6-cylinder automobile engine running at 2400 RPM,
    and compare to an 8-cylinder engine running at 2600 RPM.
    The "extra" RPM will be the 8% improvement,
    but the change in internal architecture (from 6 to 8 cylinders)
    will mean more horsepower. When you need the extra horsepower,
    e.g., climbing a steep hill (or running some CPU-intensive shoot-em-up computer game), you'll notice more than an 8% improvement.
Dell desktop OptiPlex GX60 driver download
Hello you can download the drivers here at dell:
http://www.dell.com/support/drivers/us/en/ussoho1/Product/optiplex-gx60
Download and install first the chipset driver.
You maybe need to unzip the file before you install.
Good luck
Dec 26, 2012 | Dell Optiplex GX60 PC Desktop
Optiplex cpu upgrade
In my opinion the Celeron have been lower performing processors and lower cost. HERE is and article describing the differences between the Celeron and P4
May 08, 2012 | Dell OptiPlex 330 Desktop Desktop Computer...
Does the dell optiplex GX60 have a memory card input?
Here is a link to all the technical specs and it does not list any type of "memory card" input. Although for about 20-30$ you can buy a USB memory card reader that reads almost every type of memory card.
http://support.dell.com/support/edocs/systems/opgx60/en/ug/specs.htm#1112636
Thank you,
Lee
Jan 31, 2011 | Dell Optiplex GX60 PC Desktop
Dell OptiPlex GX60 PC destop has been full system lock. What will i do?
depending on what information you have on there that is saved and want to keep. You might want to think about doing a fresh install of windows by using the system restore disc that came with the computer, if you do not need anything on there currently,
Jun 09, 2010 | Dell Optiplex GX60 PC Desktop
Cpu died no heat sink temp. I have a gx60 SFF
yep your mb has gone to mb heaven and good luck on finding one to replace it I own three and they are extremely hard to find, unless you want to buy it from dell and they will charge you double for it.
May 31, 2010 | Dell Optiplex GX60 PC Desktop
Upgrade processor, unknown socket type.
Here I have found the technical specifications for this system, but for informational purposes it is pentium 4 and celeron 478pin intel only. http://support.dell.com/support/edocs/systems/opgx270/en/ug/specs.htm
Oct 30, 2009 | Dell OptiPlex GX270 Small Mini-Tower...
No Audio Device for my DELL opti GX60. and no multimedia audio controller same as yellow mark ethernet controller.
For that first uninstall driver for ethernet controoler and audio driver from add remove program.
Also uninstall both from device manager.
Right click on my computer then click on property then hardware ->device manager then uninstall both from that list.
Then download driver from below link.
Click here
Click on above link and select yourt operating system and download audio and ethernet driver then install.
Let me know if you need further assistance.
Thanks.
Oct 26, 2009 | Dell Optiplex GX60 Refurbished Intel...
I need drivers for my computer
Have you checked with Dell for the drivers? Try http://support.dell.com/
Apr 21, 2009 | Computers & Internet
No LAN signal on my Optiplex GX60
Just a quick thought: Make sure you are not connected to the uplink port on the router, and make sure you are using a straight-thru cable not a cross over and your card is enabled on your computer.
Apr 03, 2009 | Dell Optiplex GX60 PC Desktop
Dell OPTIPLEX GX60  Motherboard Logo
249 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
