Question about Kenmore 13853 Stainless Steel Dishwasher
Blinking clean light, will drain with cancel button,wont wash
Blinking clean light will drain with cancel button but wont run any wash cycle
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 26, 2010
    Prodigy:
    An expert who has answered 500 questions.
  • Kenmore Expert
  • 646 Answers
Ah, the famous (or infamous) Clean-light blinking problem. Watch that blinking light.... Does it blink 7 times, pauses, and repeats? Or does it blink 3 times (or some other number). The most common problem is 7 blinks wich means "water not heating error". This could be caused by a bad heating element, a bad thermal cutoff, a bad controller, or by the switches in the door not getting fully engaged.
Most of the time, I find that the cause to this problem deals with the latch, or the switches in the latch. If something (like a soda) gets spilled into the latch, it can cause the plastic parts to stick and not slide to engage the 2 door switches. You might need to take the latch out (unplug the dishwasher first!), remove the switches, and clean the plastic parts with water, dry it, and then re-assemble. The other thing to check is the door strike, which is supposed to push down the latch. The springiness of this metal part may be weak. You can remove it (without pulling out the dishwasher), by using a small screwdriver to release the little catches on either side of the "tongue" or "tang". Bend the center part down slightly more to give it more force, and then re-insert it. Then run the diagnostic cycle (by pressing the following sequence of keys: Heated Dry - Normal - Heated Dry - Normal; or High Temp - Air Dry - High Temp - Air Dry; or Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or High Temp Wash-Heated Dry - High Temp Wash - Heated Dry), let it run for a few minutes, and then press Cancel to stop the dioagnostic cycle and clear the error.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
Posted on Dec 16, 2014
Updated details: Normal cycle keeps blinking
Have u tried unplugging it for about 2m and plug it bk in that will master reset everything like u just bought it and see how that's works out
Sep 18, 2015 | Dishwashers
It won't start. The clean light is blinking but it won't reset to start a new cleaning cycle. the cancel function work and it will drain the basin but that is all.
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Dec 11, 2010 | Dishwashers
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
After re-routing drain hose, how do I reset dishwasher?
Repeat the following button sequence:
High Temp Wash, Heated Dry
All lights will turn on.
Hit 'Cancel'
Now run through a 'Quick Clean' cycle and see if you've still got an error blinking/flashing light at the end of it. If not, you do not have a system/board problem. Just an apparent 'reboot' fix was in order.
You did not indicate they type so this is a generic reset, it may not work for your model?
Mar 20, 2010 | Dishwashers
My kenmore dw just stopped running thru cycles except drain
Hello, With the information you supplied I'm going to assume the light is blinking 7 times and pausing then blinking 7 times and so on. With the door cracked open hit the following button combination: -high temp wash
-heated dry
-high temp wash
-heated dry Then close the door and hit cancel. The pump will run for a few moments and then you should be all set. Hope this helps Mike
Nov 19, 2009 | Refrigerators
''Clean'' light is blinking, ''Cancel'' does not reset the cycle.
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring).
It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Apr 01, 2009 | Whirlpool 24 in. DU1055XTP Built-in...
The flashing light blinks 7 times on the clean indicator area , but the dishwasher will not function and when you press cancel it starts running but nothing washes through any cycle at all. please help
ok well usually it is not sensing a temperature change in the water or not getting hot enough. so you can reset the dishwasher and try running the hot water in the sink before starting the dishwasher. if it fails again there is a heating element and control board kit that would need to be installed. you can reset the dishwasher by pushing "high temp wash" and "heated dry" back and forth until all the lights light up then you can hit the cancel and drain button twice.. put detergent in and run it.
Mar 04, 2009 | KitchenAid Dishwashers
Kenmore Ultra Wash Dishwasher LIghts are blinking....
I suspect for either of these units that the timer control boards are bad.
Jan 24, 2009 | Dishwashers
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
Feb 11, 2008 | Kenmore 24 in. 17262 Built-in Dishwasher
Bosch Dishwasher won't drain, cancel drain lights blink
when you said "I can run a wash", does the machine act normal for that time frame up to the point of drain? if yes, the pump is fine. sounds more like the micro chip on the board is "confused", but not sure why.
Jun 04, 2007 | Bosch 24 in. SHX99A15UC Stainless Steel...
Dishwashers Logo
374 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
