Question about Goldstar R1804 Air Conditioner
Air is not coming out
I have an energy saver and its not blowing out cold air, I dont know how to set it in order for it to blow out cold air , its not blowingout any air now.
  • 28 Answers
It sounds like you need a fan motor, but it's very possible there is another issue causing that problem. Having it checked out by an HVAC tech is will give you the definitive answer. It's possilbe your local handyman shop could fix it if the problem is only with the motor. Depending on the age of the unit it might be cheaper to replace it.
Posted on May 26, 2010
My air conditioning unit is leaking water on the ground outside. Also the air upstairs in not coming out. It's working in the basement. What could be the problem?
It is normal for an air conditioner to drain water outside.
The lack of air flow upstairs could be due to closed or blocked registers.
Aug 07, 2017 | Heating & Cooling
Energy Knight comes on but it does not blow out cool/cold air.
I would think there is an issue with the thermostat or the temperature sensor.
Jun 09, 2016 | Heating & Cooling
I have a Hampton Bay AC. It is 18,000 BTU. It is 230 volts. The EER is 9.7 and it is 8.3 to 9 amps. When I use energy mode on the AC it blows warm air. What gives? Just cool mode and it blows cool.
Hi Paul,
  • Energy Saver Mode most likely shutdown the compressor and Fan Only will be running to recirculate Ambient air into the room.
  • Make sure there is no Port or Vent that is open on your unit and would let hot air from outside be mixed in with the ambient air especially if it is hot outside.
  • Also refer to the troubleshooting section of your owner's manual.
Good Luck,
JP
Jun 21, 2015 | Hampton Bay Heating & Cooling
I have the rinnai energy saver 1004f.. Do I have to put water in it for it to work?
Absolutely not. It does help with the humidity but you will find it empty each day because air blows over the water tray when on.
Oct 21, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I cant get it to just blow cold air
seems like the coolant has leaked out
Aug 21, 2009 | Sharp ENERGY STAR AF-S60FX...
Fridge not getting cold enough
The cold from the freezer is piped up to the refrigerator and if that tube gets clogged with frost or ice it will not be able to blow to the cold air into the refrigerator area. I took everything out, unpluged the unit for about 6 hours, till all the frost from the freezer was gone, wiped up all moisture and turn it back on. It worked!
Aug 03, 2009 | Amana ABB1927DE Bottom Freezer...
AC not blowing Cold Air
take ac cage off or ac out of window so insides are exposed take out side and use water hose and clean out side coils and in side coils dont bend these coils or u will be sorry,,,clean out good if not stoped up have freon put in
Jul 03, 2009 | Goldstar M5200R Air Conditioner
Duo Therm 13.5K Won't blow cold air?
needs freon. valve must be installed on unit in order to charge. if you know nothig about freon, call a repairman. Check craigslist.com
May 08, 2009 | Dometic Rooftop RV Air Conditioner
Goldstar R1804 Air Conditioner Logo
71 people viewed this question
Top Goldstar Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
