Question about iRobot Roomba 4210 Bagless Robotic Vacuum
I have replaced the battery in my 4210 and reset the charge cycle. It has supposedly been charging for about 55 hours now and I plan to let it charge the full 72. Is it normal for the power light to become VERY pale?
    President:
  • 635 Answers
The power light changes color and on some models goes dim to indicate charge level. It will be ready to go when the light is at maximum illumination.
Posted on May 27, 2010
  • april1957 Sep 16, 2011
    Power light has been red for more than 16 hours, if I put it on the dock it, the charge light will turn green, I pressed the clean button the charge button will turn red and the vaccum will not work. I put a new battery in and charged it for more than 16 hours
Roomba 4210 won't start
  • Lift Roomba off the floor and place it in the center of the room and restart the clean cycle.
  • If Roomba did not resume cleaning, lift Roomba and turn it over.* Inspect the Side Wheels for dirt or obstructions.
  • Test the Side Wheels by pushing them in and out and making sure they rotate freely. Place Roomba in the center of the room and restart the clean cycle
    Dec 22, 2012 | iRobot Roomba 4210 Bagless Robotic Vacuum
    I noticed my run time was getting shorter and shorter, within the first 6 months. I checked my charger and base with a V.O.M. okay. About 4.4 volts on the base about 14 volts on the direct line. I bought...
    To extend Roomba's battery life and keep Roomba cleaning at peak performance: • Always keep Roomba plugged in when not in use. • Recharge Roomba as soon as possible. Waiting several days to recharge Roomba can damage the battery. • For storage off the charger, remove the battery from Roomba and store in a cool, dry place. • Blue or black batteries should be stored after Roomba has been used. • Yellow batteries should be stored after being fully charged.
    16-Hour Refresh Charge If Roomba has been left off the charger for an extended period, Roomba will initiate a special 16-hour charge cycle. This extensive charge refreshes Roomba's battery and extends the battery life. While charging, Roomba's "Clean" button will pulse quickly. Note: For best results, do not interrupt this Refresh Charge.
    Happy Holidays The FixYa Team
    Dec 18, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
    Old or New battery not charging...or so it seems (Discovery 4XXX)
    the charger is not charging its not putting any thing out into the batterys the charger clock is working but your not getting any charge from it
    Mar 21, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
    Clean light blinks then solid orange button i bought a new battery dec
    Remove the battery and hold the power button for 15 seconds. This will restart the charging cycle as if the battery were new. If after 72 hours, it stays orange your battery is either sub-standard voltage or not sold as advertised.
    Feb 19, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
    I have iRobot Roomba 4210 and I have a problem with charge battery. The battery is new. When I charging a battery in other iRobot Roomba the battery was full charged. When I charging in my iRobot Roomba...
    The charging circuit on the main board is fried. This is a common issue. You need some good electronic repair skills, and equipment, to replace the problem components
    Nov 23, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
    Model4210battry won't recharge, is it worth ordering a battery?
    don't buy a new battery yet. you can reset the battery by charging for 16 hours, if this does not work, you need to take the battery out, push and hold the power button on your roomba for at least 15 seconds then reinstall the battery. plug in the charger directly to roomba not the docking station and charge until the battery light on the roomba is green. do not interrupt the battery charging cycle. after, leave the roomba charging for an additional 3 days or 72 hours. after, run roomba in max mode and run it till the battery is completely depleted. this will improve the battery overtime by charging again for 72 hours and depleting the battery. do this 3 or 4 times. and the battery should get better
    Jun 28, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
    4210 and 4230 won't charge-new batteries.
    I've been having the same problem myself. The charger is apparently built into the roomba main board. From what I've read there are two MOSFETs U2 & U4 that can go out and require replacement to fix the problem. More info here
    http://www.robotreviews.com/chat/viewtopic.php?f=1&t=3909
    Roomba 4210 replaced aps battery still does not work
    Try cleaning the silver contacts on the battery as well as the charging station with a small amount of rubbing alcohol such as an alcohol pad.
    Also check to make sure the dirt reserve is completely empty. Also check that the briushes are clear and can move freely.
    This 'not charging' is a very common problem with the Roomba and the manufacturers continue to sell rechargable batteries that are no good even though they are aware of the problem.
    Mar 29, 2009 | iRobot Roomba 4210 Bagless Robotic Vacuum
    iRobot Roomba 4210 Bagless Robotic Vacuum Logo
    272 people viewed this question
    Top iRobot Vacuums Experts
    Are you an iRobot Vacuum Expert? Answer questions, earn points and help others
