Question about Magic Chef MCD1311ST Microwave Oven
The light no longer comes on.
I have model MCD1311ST. The light no longer comes on when I open the door or when the food is cooking. How do I change the light bulb, and are replacement bulbs available.
  • Magic Chef Master
  • 9,047 Answers
The owner's manual (online here) does not address it, so it is not intended to be changed by the user.
You would have to unplug the unit, remove the outer case, and located the bulb, usually on the right side in or near the air duct in front of the magnetron.
You can take the bad bulb to a grocery store, home center, or big box store to match it up.
Posted on May 28, 2010
Food not cooking in center
What make and model?? Sounds like it is not a carousel model. Have you tried a "Micro Go Round" ?? Otherwise, try rotating the 'plate' each quarter cycle...ie; every 30 seconds on a 2 minute cook time. Be sure to push the stop button first before you open the door to save wear and tear on the door switches......
Nov 04, 2013 | Microwave Ovens
How to change nightlight bulb on ge advantium 120 oven
Advantium - Interior Light Operation While Microwaving
The Advantium 240 oven interior (cavity) light will illuminate anytime the door is open. However, due to the dark tint on the oven door, there is not a light on while cooking since the food would not be visible using the interior lamp.
Food may be viewed during a microwave cycle by pressing the Microwave/Oven Light pad.
One of the Upper Level Speedcook lamps will come on for 5 seconds. The Microwave/Oven Light pad can be pressed up to 5 times during a microwave cooking cycle. The limit of 5 times is to prevent excessive heat on microwave cookware from the Speedcook lamp.
The Advantium 120 oven cavity is illuminated anytime the door is opened and while the unit is in the microwave only mode. As a result it will not have the Microwave/Oven Light pad.
Aug 25, 2012 | GE Microwave Ovens
Mine is a similar problem - light and fan BOTH stay on when the cooking/heating finishes! The door remains closed and the food/beverage cooks. However, when it's finished the light remains on and the
There are a number of interlock switches that the oven door activates when closed, sometimes one becomes defective causing the main fuse to blow in the microwave or continue to run when time is up.
Nov 11, 2011 | Microwave Ovens
Not heating
Hello
Power Supply
Check whether there is a proper power supply. Look to see whether the cord is connected to a grounded 3-prong outlet and the cord is fully plugged in. If the electrical system is built-in and no power cord is visible, replace or reset the household fuse or circuit breaker.
Microwave Functions
Some basic microwave operational steps may affect whether the microwave is heating. Open and close the microwave door, as the unit will not function with the door open, and push "Stop/Clear" to cancel any previous settings, such as the timer, which do not heat the microwave oven.
Setting the Microwave
Once the power to the microwave has been reset, or verified as working, and the microwave is ready to run, select a new cook cycle and press "Start" to see if the microwave begins to run and cook food as expected. Allow the food to cook for the alloted time and then open the microwave door and check to see if the food has cooked or heated. Choose a longer cooking time and restart the microwave if food is heating but is cooking slowly.
Repair
If all efforts to troubleshoot the function and power to the microwave still do not get the appliance heating food as expected, there may be a repair issue that needs to be addressed. Contact professional technician for advice.
Oct 05, 2011 | Sanyo Microwave Ovens
Hello, We received a Magic Chef Microwave Oven, MCD1110WB / MCD1110BB yesterday (8/31/11) to use in our workplace kitchenette. We are accustomed to having the microwave light come on when any...
We have the same oven, and the light comes on only when the oven is operating. When the door is open, the light is not on. I would be interested in knowing if anyone has done a work-around to make the light come on when the door is open.
Sep 01, 2011 | Microwave Ovens
We own a Panasonic 1100 watt Inverter microwave. It has worked fine until recently - it has now started to "turn on" whenever the door is opened. Now, when you open the door the light...
HI:
You have a faulty door switch, the unit is not supposed to come on when the door is opened only the light.This unit may require servicing as the control board may also be at fault.
Dec 24, 2010 | Panasonic NN-S753 Microwave Oven
Interior bulb needs to be replaced. What needs to be removed to gain access? Thanks
If the light is not operating properly, you will want to have it checked by an authorized service technician. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Check here
http://www.geappliances.com/search/fast/infobase/10000007.htm
Aug 25, 2010 | GE Advantium 120 Convection/Microwave Oven
Cook time button problems
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Please reply back here and let us know if the hard reset doesn't fix it.
It may have a bad door switch, and we can help you check into that. The first test for that is to try it while gently lifting up and then while gently pushing down on the door.
If you don't have your owner's manual, you can download it here:
http://www.mcappliance.com/products/otrdetail.asp?record=yes&modelname=MCO153UB
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 11, 2008 | Magic Chef MCD1311ST Microwave Oven
Magic Chef MCD1311ST Microwave Oven Logo
376 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
charles
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
