Question about Mitsubishi MS17TN Air Conditioner
Blowing warm air,not colling - Mitsubishi MS17TN Air Conditioner
  • Jake Gibson
    Jake Gibson Mar 03, 2016
    Sue, I'm sorry to hear that your air conditioning unit is just blowing warm air. My parents had something similar happen to their HVAC system. I believe they ended up getting a few bids from some licensed, experienced, and reputable professionals. I would imagine that getting a tune up before the real hot summer months could be helpful. http://www.airconperthwa.com.au/air-cond...
  • 28 Answers
Sounds like a problem for a tech to solve. Most any residential HVAC service company can handle it. The problem could be anything from a minor electric issue to a leak in the refrigerant line.
Posted on May 26, 2010
Freezer will not hold at freezer temprature 18degrees is dropping is currently at 6 degrees
Any Freezer does not stay at any one temp. If you freezer is part of your refrigerator then it goes through defrost and the temp will rise. When the compressor comes back on it will drop. How much food you have in your freezer will also be a factor. Not much food and the unit will flex widely in temp. too much food and the fan can not blow the coll air around properly and msy cause it to warm up. If you need more help please add additional information being very specific.
Mar 27, 2016 | Refrigerators
How do i replace a fan on a hp6c-6c10us
There is normally more that one fan. I would first blow it out with air. Normally a colling pad helps. Use canned air to blow out the dust balls.
Aug 20, 2014 | HP Pavilion Computers & Internet
I've got a 96 Buick Regal Custom 3.8L V6. It's been running hot for a while. Yesterday the heater worked fine then last night it started blowing cold. I knew I had a cracked radiator, so I replaced the...
the one thing that comes too mind is trapped air-when i do a radiator I always start up and warm engine so thermostat cycles a few times to make sure that you dont trap air in colling system. you did not say so but if you didnt, its really not a bad idea to change thermostat and gasket when digging into colling system. they are usaully fairly cheap.
Jan 26, 2011 | 1996 Buick Regal Olympic Gold
My freeezer on my side by side is not colling.. the fan runns but warm air blows
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 21, 2010 | Refrigerators
Why would my 2002 Jeep Grand Cherokee only blow luke-warm to cold air when the fan is on high? First the heat went on the highest setting, so i used the second highest. Then it started to coll as...
Sounds like you need a blower motor resistor located down under dash on pass side next to blower motor. This is a comon problem and I have changed many of them. thats just the fan speed problem. Ive seen the blend doors break easily on those jeeps. thats inside the heaer core box and moves the flap from hot air to cold air. If it is stuck halfway -or mostly to cold- you may only get luke warm air. If they had the heater core out-maybe they possibly broke it.
Dec 04, 2009 | 2002 Jeep Grand Cherokee
My AC NO COLLING
if your sayin the unit isnt cooling then you need to see if it blows any air at all if so and its just warm or regular air then fist check your run capacitor to see if thats bad and at the same time put your hand on the top of compressor to see if thats running it should feel like a humm if not running copressor is probably bad if it is running then most likely its low on freon and if thats the case you have a freon leak some where in system and the new freon laws these days are requiring the a/c company to find and fix leak before adding freon .some companies will just fill it and the same problem will accur soon again.send back more info ,like is unit blowin air is compressor running and i can pinpoint problem easier thanks and let me know the outcome
Sep 29, 2009 | Bryant 462AJC021BA Air Conditioner
Does not blow cool air
Have your AC "charged" with refrigerant
Jul 10, 2009 | 2000 Ford Expedition
Air conditioning system is not colling the car ? what do Ineed to do ?
i need to know how is not cooling the car?
is the fan blowing air or is the blowing air not cold?
it probably isnt cold.lets try that.
put a set of 134a ac gauges on the system and verify pressures.if it has low freon you may hear the compressor turning on and off.if so for sure its low and you will just need to add freon.
go get a 134a fron fill kit not the conversion kit.
and begin to fill untill the comp stays on and air is blowing cold.then stop filling and enjoy.
do not over fill as this will cause it to not cool again.
Jun 12, 2009 | 2002 Toyota Camry
Radiator colling fan does not run
first thing you need to do is replace the fuse then dissconnect the positive wire from your fan. now warm upp the bike till the fan should turn on .
now if the fuse blows we need to find the short if it doesnt blow you need a new fan.
good luck
paul
Nov 18, 2008 | 1986 Honda VT 1100 C
Mitsubishi MS17TN Air Conditioner Logo
137 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
