Question about Exercise & Fitness
Sportsart 3200 Treadmill Belt motor problem
I have a sportsart 3200 treadmill donated to me. Upon turn on it blew the breakers and fuses in the unit. I pulled the drive board and checked the input bridge rectifier. It was shorted. I replaced the rectifier and unit now powers on and all display lights work, no fuses blow and the up and down motor works. Now my issue is that the belt motor does not move or attempt to move. I have hooked up an external 20VCD source to the belt motor and it does move. I am unsure how to troubleshoot further. I measured the output of the drive board that goes to the motor and there is 5VDC. Any suggestions would be greatly appreciated.
    President:
  • 832 Answers
5v DC equals .5 mph every 10v equates to 1 mph try increasing the speed if the DC voltage increases that means the motor control is working properly, then go back to the drive motor and check the motor brushes even though you have used a DC power source. They sometimes will not seat correctly and cause no belt movement, use a commutator stone a clean up the commutator arm.
Posted on Jun 01, 2010
What is E-1 error in Sportsart Tradmills
ERR1 Definition: The display board CPU didn't receive the optic sensor signal. • Explanation: After processing by the drive board, the optic sensor signal travels the 16-pin cable to the display board CPU, which determines motor speed. Components involved include the optic sensor, optic sensor wheel, 16-pin cable, drive board, display board, and connections. http://www.sportsmith.net/images/product_support/sportsart/Repair%20Manuals/General%20Treadmill%20Svc%20Manual.pdf
Jun 23, 2014 | Sportsart Treadmill Doctor Walking Belt...
Bamix dealers vancouver bc
This could be a bad elevation motor, but could also just be the nylon gears inside the lift motor. I am attaching two links. One is to the service manual and the other is to the parts for this model. This should help you get to the bottom of this and get it fixed. http://www.sportsmith.net/images/product_support/sportsart/Repair%20Manuals/General%20Treadmill%20Svc%20Manual.pdf
SportsArt Treadmill 3200 Parts Overlay Nylon Gear Fuse SPORTSMITH net
Apr 29, 2014 | Sportsart Exercise & Fitness
Sportsart 1060 hr treadmill
please LUBE the deck belt as shown in the video and fix it.
God bless you
May 31, 2013 | Exercise & Fitness
Started making a burning smell, then a cracking noise from inside the motor/unit and stopped. Treadmill now shows error 1
LUBE THE deck belt very well this happen because the schedule lmaintenance. Maybe the deck belt is worn and need replace it
2( LUBE the rollers bearing too. very importante.
3( test the input voltage motor, if there are the motor need repair.
4( test the output voltage board, for input voltage motor, if there are NOT, the board is faulty.
God bless you
Oct 03, 2012 | Sportsart Exercise & Fitness
Hello. My sportsart give's error 7 ? I don't now what the problem is. Can you discribe the problem en the solution for this? Thanks Gert Jonker
When I turn on the machine it beeps and reads Error 7 on the screen. Do you have a support phone number for Australia
Feb 12, 2011 | Sportsart 6300 Treadmill
Sportart 6310 treadmill - check speed sensor
Unplug unit and check the motor brushes they maybe worn and need to be replaced call Sports Art Fitness customer service @ 1-866-709-1750 they will sell you the brushes
Mar 13, 2010 | Sportsart 6300 Treadmill
I have a sportsart 6300 that keeps blowing up Q2 and Q3
The bridge rectifier is shorted with gives Q1 and Q2 the appearance of being shorted and blowing the 15 amp ceramic fuse
Jul 12, 2009 | Sportsart 6300 Treadmill
Exercise & Fitness Logo
169 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
