Question about Orion 6002 Car Audio Amplifier
Orion 6004 connection problems
I am trying to connect my Clarion Car radio with CD to an Orion 6004. I have tried the High Level connection and the RCA input, but the amplifier switches in both cases with the red and the blue light.
Also I have tried to use the REM input to power it up, but that does not work either.
Kind regards
Peter
psconsul@gmail.com
    Sergeant:
  • 290 Answers
It should be wired up like below:
  • +12V to the battery (through an inline fuse).
  • Ground to a good, close point on the chassis.
  • REM to the remote turn-on of the head unit.
Remove the connections to the speakers and see if the issue still exists. If it doesn't, reconnect the speaker connections and find out which one causes the amp to go into protect mode.
Posted on Apr 08, 2008
Hi I need code for MODEL PU-2294A(C) serial CL040130897281C Thanks
Your radio is made by CLARION and the only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio
Jun 28, 2011 | Car Audio & Video
Clarion car radio model no. PU-2294A(C) seriel number CL0401Y0231904 Peugeot clarion cd code needed for my dads car!! Hellp please
Your radio is made by CLARION and the only CLARION codeavailable for free (using a serial number ) from anywhere on the Internet is ifyour radio also has a BARCODE SERIALNUMBER beginning with C 7000000 + + ++ on a label somewhere on the metalcasing. If not then it will only be available from your Main Dealer or a Decoding Service oryour local Car Radio / Audio Store who will connect a laptop to read/recode thememory chip (EEPROM) inside your radio
Mar 02, 2011 | Clarion Car Audio & Video
Hi have a clarion lost code pu-2294a cl0401z0573097
The only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also  has a BARCODE SERIAL NUMBER beginning with
C7000000 + + + +  on a label somewhere on the metal casing.
Feb 15, 2010 | Clarion DXZ945MP CD Player
Hi there! i have a clarion in my peugeot 406 (2001). anyone know where I can by the removable keys from? thank you in advance!
It depends whereabouts in the world you are
If you do not have a local Car Radio / Audio Store
then  try Ebay
If not successful then try Google with
clarion car radio extractor keys in the Search and make a choice of supplier in your country.
Nov 15, 2009 | Sony XR-C5100 CD Changer
Clarion radio sound flickers
make sure your wirings are rated to handle the current needed by your radio. You might have a large voltage drop when it is at high volume level because it will draw lots of current. You might need to change the size of your wires to your Clarion. Check the voltage near the radio when it starts to flicker if it goes below the source voltage of 12V. hope this helps
Aug 17, 2009 | Clarion M475 CD Player
Power goes on and off-flickers
That is most likely because the radio is drawing more power than the wire can provide. First make sure you have good connections, especially a good clean ground. Next make sure the power wire from the boat is at least the same size or thickness as the power wire on the radio. If that doesnt work, you may want to wire the radio directly to the battery, using an aftermarket inline fuse and wire available at any car audio store.
May 24, 2009 | Clarion M475 CD Player
Orion wcc-6004 it has a burning smell how can i fix this issue?
turn it down your burning out the internal battery from crankin it to loud also check ground to make sure theres good connectivity
Apr 15, 2009 | SNK West Coast Customs WCC-6004 Car Amp
Memory problem
you have connected the power wires wrong make sure the yellow wire is connected to 12v battery continuous and the red is connected to accessories
hope this helps pls rate ppl havent been rating thanks
Apr 10, 2009 | Clarion DXZ428R CD Player
Sub woofer volume adjustment
The gain dial is not a volume control. The gain dial is used to compensate the output level of your car radio head unit. all car stereo units output are not alike. If you set this gain level too high, it will cause major distortion (clipping) to the audio output of you speakers when cranked up. This excessive distortion WILL eventually, or even quickly damage or blow your speakers.
I personally blown speakers this way no not properly setting this. (lesson learned, I guess :| )
Jan 27, 2009 | Clarion DXZ545MP CD Player
Clarion db538rmp
this proble is usually caused by the tel mute cable getting trapped as you push the radio in to the dash, pull the radio out of the dash and see if you can see if any cables have gotten caught in the cage
Nov 25, 2007 | Clarion DB538RMP CD Player
Orion 6002 Car Audio Amplifier Logo
115 people viewed this question
Top Orion Car Audio & Video Experts
Tygh Duval
Tygh Duval
Steve Sweetleaf
Steve Sweetleaf
Are you an Orion Car Audio and Video Expert? Answer questions, earn points and help others
